Question about Whirlpool Gold 24 in. Built-In Dishwasher Dishwasher
Whirlpool God dishwasher Model GU980SCGB2 blinking lights
The lights on my dishwasher blink, usually during the dry cycle. It happened once during the last drain. Sometimes the water heating or add a dish light does not go on. Other times it works just fine. If I leave the lights blinking it tries to reset itself. Sometimes it is successful, other times it just shuts down. Is this a control panel issue?
markevans
  • 148 Answers
SOURCE: problems with Whirlpool dishwasher model GU1500XTKB0
will these units (silo and jtrip) start back on their own? if so, it is likely they are heating the water.
otherwise it sounds like a logic board, unless there is a defective door switch or sensor issue.
electronics seem to be a recurring problem with whirlpool.
i would ask whirlpool (electorlux) to either buy it back or fix it.
good luck
mark
Posted on Dec 28, 2007
  • 65 Answers
SOURCE: Whirlpool gold dishwasher leaves film on dishes
are you in a hard water area such as florida ? do you have a water softener? if so take a can of frozen concentrate orange juice and put the frozen hunk in the bottom of dishwasher and run for one cycle. the citric acid will dissolve undisolved soap . this works much better. than vinegar which will only remain through the first cycle and then drain out as for the already grey glasses wash them in a solution of equal amounts red wine vinegar and water with just a touch of dish soap using a sponge.
Posted on Feb 16, 2008
  • 1073 Answers
have they checked the thernals on the bottom of the tub
Posted on Apr 12, 2008
SOURCE: My Whirlpool Quiet Partner 111
Disconnect your circuit breaker for 20 minutes and then reset. It should reset your dishwasher.
Posted on Jan 28, 2009
  • 38 Answers
SOURCE: whirlpool dishwasher is not fully drying dishes
Are you using jet dry or a similar drying agent? If not you should be. Also check to make sure the heater is getting hot in the dry cycle, just place your hand over the heating element to see if it's generating heat, don't touch it as it will burn you.
Posted on Feb 23, 2009
Whirpool dishwasher quiet partner 2 clean light blinking wont cancel or run a cycle
press normal heated dryer normal heated dry normal the dishwasher should reset and start. You will need to check the heater this happens because the heater normally fails. Let me know,
http://www.appliancerepairlesson.com/
Mar 07, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
The wash light and the start/cancel button keep flashing. How do I fix it? I have a Kitchen Aide dishwasher model KUDS02FR
The clean light usually will blink due to a failure to heat the water properly. This dishwasher looks for a temperature rise of the water during a heating cycle if it fails to see this rise for multiple cycles it may shut down and blink the clean light.
There are a few things to check before resetting the control.
-The unit not being level so both door switches do not make contact
The sump plugged up so water is not pumping across the heater (see sump clean out below)
- Not enough water filling the dishwasher
- The heat element is not working
To reset the control use this key dance within 5 seconds press:HEATED DRY, NORMAL, HEATED DRY, NORMAL
This will cause you to enter the diagnosis cycle once this is finished or you hit cancel the control should be unlocked and ready to use.
Thank you !
Aug 02, 2010 | KitchenAid 24 in. KUDS02FRSS Stainless...
The lights are blinking and I can not turn on the dishwasher.
To reset the control use this key dance within 5 seconds press: HEATED DRY, NORMAL, HEATED DRY, NORMAL
Thank you !
Jun 22, 2010 | KitchenAid 24 in. KUDI02IRBS Stainless...
I have a Whirlpool Dishwasher Model #GU240CXTPB1. The normal light won't stop blinking. Tried turning the breaker to reset, but still blinks. No other button works.
Whirlpool dishwasher reset sequence is usually to hit the heat dry then normal then heat dry then normal buttons within 5 seconds and it usually resets.
Mar 22, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
How do I get the clean light to stop blinking on my whirlpool quiet partner 1 dishwasher
A clean indicator that flashes/blinks 7 times and then repeats, indicates a problem in the dishwasher which should be investigated and not just the control 'reset'! That is why the control will not let the dishwasher start once such a condition is detected.
If the dishwasher's electronic control doesn't detect a water temperature increase during the main wash cycle, that symptom can occur. No water temperature increase could be caused by a problem in the heater element, its in-line thermostat, the related wiring or a problem in the electronic control.
It is also possible just the washer not spraying properly (possibly from blockage in the filter or problem in the pump), the dishwasher not filling sufficiently or draining prematurely or even a problem in the door latching mechanism's switch(es) could cause it.
*Some actual investigation should be undertaken to isolate and correct the cause of the symptom.*
Once corrected, the error display may have to be cleared from the control manually. That can usually be done by putting the unit into diagnostic mode by pressing the key sequence 'Heated Dry, Normal, Heated Dry, Normal' and then pressing cancel.
This was taken from "http://www.appliance411.com/faq/blinking-clean-light.shtml" But is common D/W repairman knowledge
Mike
Jul 12, 2009 | Whirlpool Dishwashers
Light flashing
reset the dishwasher by touching heated dry and normal let it run through that cycle then through a normal cycle got the error blink again. Reset dishwasher by touching heated dry and normal, ran the test cycle, next ran a normal cycle but turned off the heated dry. This allowed the dishwasher to run through a complete cycle did not get the error blink and confirmed that the heating element was out.
Aug 30, 2008 | Whirlpool 24 in. GU2500 XTP Built-in...
Problems with Whirlpool dishwasher model GU1500XTKB0
Mar 14, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool DU1145XTPPB7
These dishwashers normally have a "Control Lock" mode.  It's in the manual.  It is provided for child safety.  It's often controlled by holding the "No Heat Dry" button for 4 seconds or more -- same procedure turns it on or off.
Feb 25, 2008 | Whirlpool 24 in. DU1100XTP Built-in...
good luck
mark
Jan 09, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool gu2400xtpt3
I too had Flashing Clean light and only responded to Cancel light by trying to drain. Whirlpool Model DU1145. I too got problem to clear by pushing High temp,Heated dry, High temp and Heated dry. All lights on display lit up then it went through sequences of all cycles.
May 14, 2006 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool Gold 24 in. Built-In Dishwasher Dishwasher Logo
161 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
