Question about Cyberhome Televison & Video
Problem with CH-CVR 2500
Unit has seems sluggish to respond to commands recently. Finally got DVD player to open and played DVD but now cannot get DVD player to open, to retreive my DVD. Have tried shutting off power and restarting...sometimes unit will not power up immediated and when it does, it is slow to respond to command to open disc. Sometimes shows "loading" but no disc sounds and still will not open...what do I do?
  • 231 Answers
SOURCE: Tray Opens and Closes Repeatedly After Disc Jam
check to see if tray is out of alignmnet ..also check to see if 5 or 7 pin flat ribbon cable form servo drive board to tray got dislodged from connector or is bent,cut etc...
Posted on Dec 03, 2007
  • 9 Answers
SOURCE: DVD players not always beinvg able to load DVDs
You have bad filter caps in the power supply c10 and c11 need replaced and unplug unit when not using as power supply stays on always,,,,as long as its plugged in its on(P>S>) that is
Posted on Mar 15, 2008
  • 85 Answers
SOURCE: can't load disc
as there is a small gears on both the sides of the door which gets a command to spin when you press the eject button as that gears are either worn out or got craked internally or are getting blocked due to any dust collected in between .if cracked or worn out replacement is necessary.but if got blocked due to dust particles just will have to open the unit by removing the screws from its top and back body and then cleaning the gears which will be easily seen internally.
Posted on Feb 26, 2009
wiznet2000
  • 86 Answers
SOURCE: pioneer deh-p3950mp
Just follow this link for manual
http://www.pioneerelectronics.com/PUSA/Products/CarAudioVideo/In-Dash/CD-Players/DEH-P4950MP?tab=D
Posted on Aug 17, 2009
  • 610 Answers
SOURCE: My sharp photocopier is AR.5316E,and recently is showing "Ch"
Ch means the side door is not closed or the toner is not installed correctly.
Posted on Dec 07, 2009
During my recent transfer to a new flat i lost my remote control for my panasonic dvd recorder type DMR EH67. I bought a universal remote control but i did not have the full functions of my lost one. In my...
You can try changing the command mode of the (genuine Panasonic) remote itself, press and hold [ ENTER/OK ] and the number [ 3 ] button together for 5 - 10 seconds, then release. Then try the remote with the unit. If it still shows DVD 3 on its display, no matter which button is pressed, reset the main unit to factory default as outlined in the user manual (assuming this model recorder has a tuner, there would be channel buttons on the front - try pressing and holding [ CH/UP ] and [ CH/DOWN ] together - for 5 - 10 seconds, until 'SETUP' appears, then release). This may or may not restore your DVD unit to the default (DVD 1) command mode. (Don't forget to reset the remote back to DVD 1 if you do reset the main unit - press and hold [ ENTER/OK ] + the number [ 1 ] button together as above).
Your new remote may be set to DVD 1 by default while your unit is DVD 3 = different remote command modes.
May 02, 2011 | Panasonic DMR-EH67EG DVD Recorder/HDD...
At the last use the DVD player was plpaying and someone' shut it off. It now won't open, and it kept saying no disk found so I thought it was empty. BUT one disk of a series of 3 is missing. I...
You can try 1 of 2 possible options;
1) while the unit is in standby (showing clock only) - on the main unit (not the remote) press [STOP] and [CH UP] button together - for 5 - 10 seconds - this should force the tray to eject any discs that may be in it.
or
2) you can do a hard/power reset - the hard reset - press and hold [POWER ON/OFF] button (again on main unit) for 10 - 15 seconds (this helps if the unit freezes or fails to respond to remote commands).
Other things you can try include; press and hold [CH UP] and [CH DOWN] buttons on main unit (again while unit is in standby) together to reset to factory defaults.
Or you can switch off at the wall, and wait an hour, then switch back on.
Let us assume a disc IS in the tray; try the above suggestions first before going down the expensive and heartbreaking road of either submitting this one to a service centre or buying another unit.
Mar 16, 2011 | Panasonic DMR-EZ47V DVD Recorder/VCR
Ihave a Cyderhome dvd player, and i cannot get it to play.The green light on but cannot get the tray to open,what can i do ?
You seem to have two different problems. The tray won't open and a DVD won't play. First use the emergency eject slot on the bottom of the unit to eject the DVD. Now test the drawer by seeing if the drawer will auto close when you push the drawer closed without a DVD. If you hear the loading motor running but the drawer will not close than check the loading motor drive belt. Also check the 12V and 5V power supply outputs. Low voltages are caused by bad filter caps.
Nov 20, 2009 | Cyberhome CH-DVD 300 DVD Player
Can't load disc
Feb 26, 2009 | Cyberhome CH-DVR1500 DVD Recorder
LCD TV/DVD PLAYER COMBO - DVD WON'T ACCEPT A DISC
Turns out my suspicions wre correct about the DVD player being "sluggish" from lack of use. By continuing to exercise the drive motor by hitting play and eject while simutaneously attempting to insert a disc finally paid off. Now it readily accepts the disc and everything is functioning as designed. Trust me, I'm not going to let it sit idle for anymore extended periods...................baltogas
May 28, 2008 | Akai LCT3201TD 32 in. LCD Television
DVD stopped playing all DVDs
Reset you player by doing the following:
With the player on, hooked properly to your television, and on the correct station:
Open the tray
Close the tray (with no DVD inserted)
Hold the stop button down for a full 5 seconds
The CyberHome screen should appear. You should be able to play your dvd's now.
Feb 20, 2008 | Cyberhome CH-DVD 300 DVD Player
Universal remote control
I have CyberHome DVD Player CH-DVD-300. I want to download the user manual. Can anybody help? Thanks.
Feb 15, 2008 | Cyberhome CH-DVD 300 DVD Player
DVD problem
I have a cyberhome CH-300 my player running 50mins and next stuck the move .
Feb 12, 2008 | Cyberhome CH-DVD 300 DVD Player
Multi region for CH DVD 300
There's a tricky process to follow with the remote control to set the region code. It is: -Open the player. -Remove any DVD. -Close the player. -Power off the player. -Wait for 30+ seconds -Power on the player. -Press Menu,1,9 on the remote [this frequently takes a few tries]. -When the region screen appears, press enter to change region (Every time you press enter, the region code on the screen will increment by 1). -When the proper region code is displayed, press Return. -Open the player. -Insert DVD. -Close the player. -(Maybe just my player) If the player doesn't start the DVD, repeat Open/Close until the DVD starts. If it still doesn't start, power off for 10 minutes. Good Luck!
Jan 21, 2007 | Cyberhome CH-DVD 300 DVD Player
Televison & Video Logo
Top Cyberhome Televison & Video Experts
zappal
Demonic-2011
Demonic-2011
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
