Question about Canon ZR800 Mini DV Digital Camcorder
Video camera will not accept the tape
Hi, first i want you to know that the camera was not dropped/forced or anything improperly--I was replacing a full tape and when I put the next tape in (the small ones) it will not accept it, after a few seconds it will beep several times ---the strange part is that the part that holds the tape will go back in when its empty. I have tried several different tapes/and it is fully charged, I even tried it plugged in to the wall. I would greatly appreciate your help. Thanks
canon --the rest of the numbers/letters are NTSC ZR85 in case that helps
After reading further on this site about other people with a similar problem, I gently smacked the side of the camera and it shut with a tape in it!! Thank the Lord & thanks for this site--I will reccommend it!!!
Posted on Nov 18, 2008
Canon zr700 won't play tape
That is the pinch roller. If it does not press the tape against the capstan, then the tape will not pass the read/write heads. Replace it.
Jun 25, 2017 | Canon ZR700 Mini DV Digital Camcorder
Sound dropout
hi, the problem could be because of the problem with the pinch roller ,either it has some wear or the supporting spindle needle has some improper orientation. Is this with a specific tape or all tapes? if it is specific to a tape then it can be because you kept the recorded tape near magnet which causes this rythmic sound drop out. i guess the first one may be mostly happened. all the best sreejith
Aug 13, 2007 | Sony Dvcam DSR-PD100 Camcorder
Hi8 won't eject cassette
There is a broken plastic part inside the cassette and needs to be replaced. Mostly due to cassette tape improper position and camera jam (tape jam).
Apr 03, 2010 | Sony Hi8 CCD-TRV138 Camcorder
Canon ZR200 -- I can no longer get the camera to accept a tape.
it could have been forced at some time and has bent the loading door,,, maybe a bit of cassette broke off inside it and is jamming it up best bet is to drop it off at the repair shop let them fix it for you,,
Oct 27, 2009 | Canon ZR200 Mini DV Digital Camcorder
Grey lines across video display
pls rate me WELL if i have helped u !
Regards
Zohail
May 20, 2009 | Canon ZR200 Mini DV Digital Camcorder
C:31:23
Hi Tariq,
Please see the detail below for the said error codes C31:23.
According to the symptom and self diagnostic system the problem is in mechanical section (tape loading section) Therefore camera just need mechanical adjustment and will work fine again. This problem aries when the insertion of the cassette is improper or forced insertion.
Thanks for using fixya.
Apr 11, 2009 | Sony Handycam DCR-TRV240E Digital...
Sony video8 won't accept tape (door won't finish closing)
Sony DCR HC 42
I have the same problem as gskillman
Sony says it qualifies for a fla rate repair -- $201 plus taxes!!! Say what? This camera is only a couople of years old and has hardly ever been used.
Jan 11, 2009 | Video Cameras
Sony PC101 will not eccept a tape
It might be the dew sensor, try blowing it shortly with hot air using hair dryer, if still the same, entire mechadeck should be replaced. thanks
Feb 13, 2007 | Sony Handycam DCR-PC101E Mini DV Digital...
Accept the video tape
The unit may be locked due to the head needing cleaning. Try removing the battery for 30 minutes or so and then resetting it.
Sep 16, 2017 | JVC GR-AXM25 Camcorder
Canon ZR800 Mini DV Digital Camcorder Logo
122 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
