Question about Toshiba 1360 Black and White Copier
Toshibe Copier 1360, Error light
______
I have a Toshiba 1360 copier. The above shown error light is on. I don't have the owner manual. The white plastic container was full of black ink powder. I emptied and clean the plastic container but the problem is not fixed and red error light still on. What else should I do?
  • stevenm50 Feb 03, 2009
    I also have a Toshiba 1360 copier with same problem.
    The jam/error symbol is flashing red which is indicating E5.
    The jam/error symbol comes up when you press the copy button.
    The optical unit goes through the normal cycle, but does not pickup
    the paper and thats were the jam/error symbol comes on flashing.
    I have not yet figure out the problem.
    Please notify if solution found.
    Steven
  • graham waddell May 11, 2010
    What light is on?
    but if your waste container was full and you have emptied then also push in a few times the rubber cover above it to clear any blockage of old toner.
  • 4 Answers
You need service technicien to maintenance your copier, because it is full with used toner.
Posted on Dec 09, 2008
Wrench light on will not photo copy
You most likely have an internal error. Bad news is that your 1360 is a little beyond obsolete and chances are parts are unavailable. You may indeed be very much out of luck. Time for a new one, sorry to bear the bad news Margaret.
Feb 13, 2013 | Toshiba 1360 Black and White Copier
Just been given this 1360 toshiba copier 2nd hand. worked 1st time but not now. I have no manual & have red flashing light in shape of figure 8 with line coming out from & will not copy anything....
open the machine and lift the red fuser cover and check the exit sensor make sure that that the flag moves easly then makr sure the registration sensor flag moves easy as well the sensor is located at the black roller in the bottom of the machine there is a cutout in the plate you should be able to see the flag if not it is stuck in the open position the figure 8 is a paper jam error
Mar 07, 2011 | Toshiba 1360 Black and White Copier
Toshiba 1360 Copier
"C7" Faulty thermistor, thermal fuse, or heater element
Sep 16, 2008 | Toshiba 1360 Black and White Copier
Error c7
You can reset the C7 code, hold down 0&8 power machine up. Then push 87 & print, change the number to 0 with number keys press interupt key, then press 0&9 @ the same time to exit. This should clear the C7. Let me know if you need more help.
Oct 26, 2007 | Toshiba 1360 Black and White Copier
Toshiba 1360 C7 Error Code
TOSHIBA 1310 C7 Fusing unit warm-up error, defective thermistor, fusing lamp or thermofuse
The codes are good for several models.
Oct 25, 2007 | Toshiba 1360 Black and White Copier
Toshiba 1360
You should be able to retrieve a code for a malfunction by pressing down the clear/stop and 8 keys. then let me know what you get, and we will go from there.
Oct 22, 2007 | Toshiba 1360 Black and White Copier
Toshiba 1360 Black and White Copier Logo
275 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
