Question about Sewing Machines
STITCH WIDTH/ZIG ZAG DIAL WOULD NOT MOVE. IT IS STUCK ON #1
Hi There:
I have a PFAFF 332-260 which I recently acquired from EBAY. I have not been able to test all the functions because this is my first sewing machine. The straight stich seems to be OK. However, I noticed that I'm unable to turn the "stitch width/zig zag" dial/knob to the left. It is completely stuck/glued to #1. I can't move it to 2, 3, 4 or even 5. It just won't move. I tried to spray/soak it with WD-40 and that didn't work either. The lever next to it "needle position" seems to be OK---it's just that freakin' stitch width dial---it won't freakin move :(
Help!!! Somebody please :(
5 Suggested Answers
  • 32 Answers
SOURCE: My machine stiches in zig-zag only. What did I do
Do you have a manual...if not White will email one to you at your request. Make sure the stitch width is slid or turned all the way over to as narrow as possible. Good luck.
White's toll free # 1-800-331-3164
Posted on Feb 04, 2010
  • 1116 Answers
SOURCE: Bernette 75 won't Zig-Zag
Is there a stitch width setting and has to be set to a number greater than zero?
Posted on May 15, 2010
SOURCE: White sewing machine won't stop the zig zag stitch
my suggestion is take the machine in to a sewing machine shop
to be check to see if something inside is broken or come loose
knowing the machine is in good working order gives peace of mind
instead of wanting to through it out the window
and get a instruction manual
Go to the singer website for a free pdf manual
Go to the home page
Go to customer service--click on it--it will show a small menu--click on instruction manual
In the box put the model number (example w265) & click search
Posted on Jul 30, 2012
  • 1564 Answers
SOURCE: needle position
Hmmm sounds like an issue I had/have with a singer stylist. There is a knuckle part that connects the zig zag mechanism to the needle bar. Mine had a pin that kept slipping out. When I took it apart (and lost the pin) I also discovered that the "round" holes the pin went into were work out and were more like ovals. The machine is now a parts machine.
Posted on Dec 10, 2012
Pfaff 360, how do I stop the zig zag stitch on my machine?
could you explain more about what the machine zig zag stitch is doing or not doing?
Mar 13, 2016 | Sewing Machines
Setting stitch length
Get some scrap fabric. One dial is for the width of the zig zag stitch, the other dial is for the length of any stitch. First set both to ZERO. It won't move then set one to half way. This will show you which dial is which. If it is the width dial. You'll get a bar tack. If it is the length dial you'll get straight stitches.
Aug 01, 2012 | Sewing Machines
I can not figure out how to set a straight stitch. I don't want a zig zag or a decorative stitch. How do i set my machine to do this?
First, make sure you select the straight stitch setting on the round dial. It is the one that has the dashed lines, looking like the stitch itself. Then, you may also want to be sure that the stitch WIDTH (dial with the picture that looks like a straight line gradually turning into a zig-zag) to the lowest setting, which is generally 0. With some machines, even after selecting a straight stitch setting, moving the stitch width can change needle position. Sometimes it will initiate the zig zag, other times it will move needle position left to right. Does that fix it?
Jun 24, 2011 | Simplicity Denim Star SW210
Don't remember how to set it to do a zig-zag stitch
Generally on most machines you would set the stitch length dial to 2, and stitch width dial to 2. And the stitching selector to the zig zag icon.
If you give your make and model other experts may provide more specific info for your machine.
Jun 04, 2011 | Sewing Machines
May 14, 2010 | Bernina Bernette 75
What are the settings for regular sewing, I do not have a manual. It has 3 knobs on the front and 1 on top? This might have something to do with my problems.
The three front dials are as follows....left to right-Stitch width, type of stitch, and stitch length. The dial on the top adjust the top tension.
For straight stitch you want 0 stitch width, straight stitch, 3 for stitch length.
For zig zag you want turn your stitch width to how wide you want the zig zag, choose zig zag stitch, and choose how close you want the stitches to be on the stitch length dial. Practice on a piece of fabric. Usually for zig zag you will want to loosen your top tension a little bit.
Aug 11, 2009 | Brother XL-5130 Mechanical Sewing Machine
Pfaff 360 automatic slows and stops after only minutes of use
Pfaff 360's don't like to sit, they like to drink. . .. oil.
Set top knob "C" to 0
Right top (zig-zag knob) set to 4, lever below but on the same dial points straight down. Set stitch length to 4. Run 5 minutes medium speed.
After that lift off the top cover and spray inside with "Tri-flow", then run a hairdryer on it for 20 minutes to warm up or set near a warm lamp overnight. Run daily 5-10 minutes and exercise the right knob between 0 and 4 (zig-zag). It should come back to working with oil, time, and heat.
Apr 13, 2009 | PfaFF Creative 7570
I have a brother vx1065 and don't know how to get it off zig zag
i have a brother vx1065 put big dial to 1 stitch length 1-4 stitch width 0 needle position any presser foot zigzag or straight hope this helps
Mar 28, 2009 | Brother XL-5500 Mechanical Sewing Machine
Need to know how to the zig zag stitch on the 132 featherweight machinge by singer.
By turning the bottom dial on the righthand side of the machine, you can change type of stitch. For zig zag, you need to set it to B (seen on the front of the machine). You can adjust the width of the zig zag using the same dial.
Mar 04, 2009 | Singer Featherweight 132Q Mechanical...
Sewing Machines Logo
140 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Marvin
Marvin
Are you a Sewing Machine Expert? Answer questions, earn points and help others
