Question about Poulan Featherlite Gas Blower, with Low Emission Engine, 150 M
Pull cord stuck all the way out.
Is there a fix I can do at home for this problem?
  • philjent Nov 18, 2008
    Thanks scrodamoon I will take a look at it and see if I can figure how to remove the rear caseing. philjent
  • frogisimo Dec 07, 2008
    I took my FL1500 apart to clen it and lubricate it. The starter spring came unwound and now I can't figure out how to rewine it. Any suggestion?
    KJ
  • 3 Answers
The Sears model 358.797200 appears to the FL1500LE marketed under the Craftsman name. Go to the searspartsdirect.com site and enter the Sears model number. This blower may be prone to develop binding in the pull cord rewind spring compartment, which can be fixed by adding washers to increase the spacing. Open the rewind starter page on the sears site for an exploded view. I found that by placing 2 washers on each of the 5 screws (no. 7 on the diagram) which attach impeller housing (12) to the motor, I increased the spacing enough so the pull cord operated and retracted normally. The washers must go between the impeller housing and the motor. To complete the repair, you need to add a washer between the spacing flywheel (14) and the impeller(15) to keep the impeller from binding against the housing. The gasoline tank screws won't line up as well with the holes, but will fit. Install all 3 screws for the at first loosely, then tighten them down.
Posted on Mar 27, 2010
I took off the bottom plastic casing .Then put on a long shaft socket (with ratchet).Turned clockwise until it stopped,gave it a sharp whack (the ratchet handle ) with a hammer and the rope snapped back in.Working fine since.
Posted on Apr 05, 2010
  • 659 Answers
Yes there is but it would call for pulling the rear of the caseing out and then rewinding the unit for it to have the springback which sounds like it either slipped out or the wheel inside is stripped and broken but even then it should wind back up it just wouldnt turn it over when trying to start it.
I will see what I can do as far as finding more info for you on fixing this. I have done this with mine but its a bit harder to explain then it is to show so if I have to take mine apart and video tape it maybe that will help as well. let me know and I will get back to you as soon as possible if you are not comfortable with taking it apart without a guide of some sort.
Posted on Nov 18, 2008
I have a ryobi2cycle blower /vac I pull the cord and it just spins how can I fix?
Leaf Blower : Pull-Start Cord - YouTube
? 7:26
https://www.youtube.com/watch?v=0bbHtbcNZ-o
Mar 25, 2011 - Uploaded by Repairs101
I'm loading the spring into the housing just by winding it in. ... Push the pull cord out first and then the pipe ...
What Stops a Pull Cord for a Gas Weeder? ' Home Guides ...
Nov 29, 2015 | Garden
Trimmer pull cord stuck in pulled position. How do I go about finding and fixing problem? Not sure exactly which screws/bolts to remove to get at the assembly.
How to Fix a Weedeater's Stuck Rope ' Home Guides ' SF ...
homeguides.sfgate.com > ... > Mortgage & Loan Payment Basics
A gasoline-powered string trimmer has cords on both sides. Most people ... In order to troubleshoot and fix a stuck cord, you have to remove the starter housing. ... Swivel each plate until it locks into position and then tighten the screw to hold it.
WeedEater string pull repair STRING WON'T RECOIL ...
? 6:35
https://www.youtube.com/watch?v=eIcj4KFmp4A
Aug 8, 2013 - Uploaded by AdamDIY
WeedEater string pull repair STRING WON'T RECOIL - FeatherLite XT260 ... How To Properly Replace Fuel Lines On a Weed Eater Trimmer
Nov 26, 2015 | Garden
Pulley is stuck how do you resolve problem?
Pulley ? What pulley?
If you mean the recoil starter pull cord is stuck it might be a simple fix. Did your machine tip over on its side?
If it did oil often flows into the cylinder. Just remove the spark plug. The recoil cord should pull easily and oil will spurt out the spark plug opening. Pull until oil stops coming out. Check your oil level. Replace your spark plug and see if she starts.
Sep 23, 2014 | Psi Blue Max 2200 High Pressure Gas Power...
Pull cord stuck on lawn mower
Pull cord stuck on lawn mower YouTube
https://www.youtube.com/results?search_query=Pull+cord+stuck+on+lawn+mower
Sep 06, 2014 | Toro Garden
Pull cord is stuck
This happens all the time. To fix it is not to bad. You have to take off housing around where then pull cord is, then when you get to the pull cord pulley, sometimes you can just untangle where cord is. The pull cord is in like a spring housing , this is what retracts it. It is all spring designed to pull and retracted. You will notice that when you take off pulley, there our little tabs that are bent in, that is designed to hold rope pulley in. There is a spring set up behind that. If rope is just tangled or crisscrossed then can carefully untangle and put back together . If not take that whole piece in and they can replace spring that has worn out or jammed. Hope this helps, I had it happen to me on a edger , was not to bad of a home project. Thanks, mike from fixya
Jun 13, 2011 | Garden
Pull cord getting stuck
Pull starter rope wheel is Jamming against casing usually some lube n check for ware will fix it
Mar 21, 2010 | Karcher 2500 PSI Pressure Washer
Pull cord stuck on my pressure washer.
Need to remove assembly to find problem.
Mar 10, 2010 | Briggs & Stratton Garden
Starter cord only pulls 1 foot
Most push mowers have 3 bolts on the side of recoil shroud. One in front, (where plug is) and two on side.
Apr 12, 2009 | Garden
Pull Cord Broke
the pull cord is same as the regulare pull cord lights.(real cheap one).
bring the fixture to any home center ot hareware store, they should be able to get you what you need.
Nov 12, 2008 | Electrical Supplies
Poulan Featherlite Gas Blower, with Low Emission Engine, 150 M Logo
1,841 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
