Question about ViewSonic NextVision N2010 20 in. LCD Television
Black lines I have black lines streaming down from the top of the screen on my 32in. viewsonic tv. I have digital sat. but, the lines or visible on every channel. what do I do. tv is a year old. The lines are not bold in color.
  • 286 Answers
Have the lines always been there?
If yes, but a line conditioner or rerout your cable from where it comes into your house to the TV.
If no, you should check your power supply board. The capacitors on the power board are likely going bad. Don't keep using it like this. Either check the board, buy the same value caps and replace them, or order in and replace the entire power board. The latter is the easiest to do. Remove rear case and inner shield, replace the power board and reassemble.
Posted on Nov 26, 2008
Blurry picture in top quarter of screen
this is caused by the panel's edge contacts coming loose(delaminating). would have to replace panel(approx. 1500.00 usd.)
Mar 01, 2014 | Sony KDL46EX520 - Bravia Kdl-46Ex520 46"...
I have thin white lines that run across the top of my picture. They are only visible when picture is full screen. The wide screen picture (with the black areas at the top and bottom) do not show this. The...
sounds like bad capacitor in vertical circuit. It's not a hard fix if you know where to look. Repair shop should not have hard time repairing it.
Aug 10, 2009 | Televison & Video
Tv went double and green and black lines appeared at the top and bottom of the screen
tv has a condition common in rear projection. the geometry and coincidence of the screen is called convergence. this is regular repair in the workshop. I expecting the fail stops in convergence amplifiers (first step of this critical area) because total convergence out of sinc as you are posting can lead to the control of the convergence previous to the amplifiers (is called digital convergence unit). It can increase the cost of the repair. some testing in the bench can divide this decision. But usuallly a simple damage is one color or two colors distortion, your tv shows three of them because this black area visible top and down.
Apr 16, 2009 | Sony KP-51WS510 51" Rear Projection...
Sony Bravia 32in ... vertical gray line on right side of the screen about 4in from the edge of the screen. The line is about 5mm thick and present on all inputs. More visible over brown and blue...
The line should be visible, even with the television off. It is called "de-lamination" of the LCD panel, and occurs in lines, usually vertical, on the screen.
The panel does need to be replaced. You can contact Sony at 1800-222-SONY. They are good people, and should be able to help you.
Hope this helps...
Jan 05, 2009 | Sony BRAVIA KDL-40S2010 40 in. LCD...
We have a Toshiba TP50H95/TP55H95 Color Stream Projection TV that is 10 years old and we recently switched cable companies. Since then the picture is not filling the screen completely on bottom or on top...
A to expensive to fix part is going on the projector. Suggest you get a new one. I've owned 3 projectors over the years. The best one is a Viewsonic 7820hd. 3000 to 3200 lums brightness, short throw lens (104" screen at 12 feet from the projector) 1 HDMI input 1 RCA input 1RGB input and 2 computer inputs. Price varies- but I got mine at Tiger Direct 3 yrs ago for $488 bucks- the Viewsonic 7822 (2 HDMI inputs) is on the Viewsonic website on clearance or refurbushed for around that price. AND- They do a full 1080 HD and also 3D.
Jun 02, 2017 | Televison & Video
Purple color band at top of TV screen
If the problem is visible on all inputs (DVD, sat, etc.) you have a bad optical block. That model has a two year warrnty on the block but you'll have to pay labor to get it replaced
Oct 16, 2008 | Sony KDF46E2000 46" Projection HDTV
Lines?
If this is a new to you monitor, then you may need to update the video driver for this model. You can do that online from Viewsonic's website.
Good luck, and let me know if you are able to fix the problem, or provide more info!
Jan 01, 2008 | ViewSonic VA1912w 19" LCD Monitor
Philips wide screen 32in Digital TV
You probably have a component breaking down on one of the circuit boards. It would have to be checked out to find out which one. Stargazer
Feb 13, 2007 | Philips Magnavox 20MT133S 20" TV
ViewSonic NextVision N2010 20 in. LCD Television Logo
182 people viewed this question
Top ViewSonic Televison & Video Experts
Are you a ViewSonic Televison and Video Expert? Answer questions, earn points and help others
