Question about Pullman Holt HEPA 390 Canister Vacuum
Parts diagram pullman holt 390 hepa
Where can i get a parts diagram for the Pullman Holt 390 hepa Vac
3 Suggested Answers
reddevil6
  • 1673 Answers
SOURCE: pullman built-in vacuum cleaning system
Is the suction poor at all inlets? If so, you may have a clog in the hose. If just certain inlets, then you may have a clog in the piping. Run a small slip of paper with a number on it (number for each port) then see which one didn't make it to your cannister. Then you will know which section has a clog. Disconnect the pipe at the cannistor, turn it on and see if the suction is good there, if not then you have a problem within the main unit.
Posted on Feb 22, 2008
  • 694 Answers
SOURCE: I have inherited a pullman power wash carpet
If this is a Pullman-Holt, you should be able to find the manual at the below link.
http://www.pullmanholtdirect.com/owners-manuals-c-71.html
Posted on Jan 29, 2011
  • 794 Answers
SOURCE: we have a pullman steamcleaner
Hi brian_goldma,
May I have the exact model of your Pullman Steam Cleaner?
Thankk you for ausing Fixya.
Posted on Apr 16, 2011
Pullman vacuum model AS5 user manual
Hi There, The Pullman AS5 is exactly the same machine as a Cleanstar Hypervac AS5. If you email us on the VacuumSpot contact us page I can forward it to you.
May 25, 2013 | Vacuums
We also have bought a Pullman Carpet Washer with no instructions. Our Gosfreys sold it to us, but they cannot supply a mnaual
I have the manual you are looking for. It's about 4 A4 pages, i could possibly scan it or photograph it and email you a copy.
If you or someone you know is handy enough to remove the back cover of the machine you could do me a big favour and send me a couple of photos in return. Mine has a faulty and now missing part and i'm trying to identify it to the spare parts guy so i can fix it.
Let me know...
hootcloot@hotmail.com
Cheers,
A.
Nov 16, 2010 | Vacuums
I have a kenmore cannister vac - model 27514. Do I have to use hepa bags in it, or can I substitute another type, and which would that be?
You know, any bag made for the unit should give similar results. You can buy a cheaper bag and that number is 50558. You can get them at your local vac shop or you can let me know, I will send you some. The price per 3 pack is only 4.95. The canister vac is made in such a way that it doesn't have much leakage. It is quite efficient with or without hepa bag. If you or anyone in your family suffer from asthma, I would recommend the use of the hepa bags. tThanks, Rene(The Vacuum Doctor)
Nov 10, 2009 | Vacuums
Water leaking from out of the heppa filter
Reasons for that to happen:
a) You have tilted the vac while vacuuming
b) Used the Rainbow without separator (basket like thing on the bottom of the motor)
c) Overfilled the rainbow tank with water (may have happened when shampooing with AquaMate)
Clean and install back the separator, remove HEPA, Set the Rainbow on empty water pan (with HEPA removed) turn it on for a while so everything will dry. Install new HEPA.
You will have to get a new HEPA filter (you can find them HERE)
Good Luck,
Rocky
Mar 18, 2009 | Rainbow E series Canister Wet/Dry Vacuum
Replacement filters for Durabrand Canister Vac with HEPA Model# DB9191
The Durabrand filter can be found at http://www.totalvac.com/accessory/parts/H19030.html
Mar 19, 2008 | Vacuums
Cleaner won't dispence cleaning solution
I have the same problem and each time I have to get the thing sent to Sydney to get the hose cleared out. Costing me $60 to $80 a pop.
Mar 10, 2008 | Pullman Holt Vacuums
Hoover Z-400 - Hepa Filter
These filters should be changed at least once a year, they get clogged up and won't clean out. So I would try a new filter and go from there, make sure there are no clogs in the hose and down below where the dirt inlet is.
Feb 20, 2008 | Vacuums
Pullman built-in vacuum cleaning system
Nov 17, 2007 | Vacuums
Wet vac has no suction
check for clogs in hose. maybee clogged filter, clean or replace.
Nov 09, 2007 | Pullman Holt EVAC II 15 Gallon Wet/Dry...
Pullman Holt HEPA 390 Canister Vacuum Logo
Top Pullman Holt Vacuums Experts
Roger Potts
Are you a Pullman Holt Vacuum Expert? Answer questions, earn points and help others
