Question about Directed Electronics 1100f Ford Pats Securilock Data Remote Start Interface Module
Bypass Computer PATS
I need to replace my 1998 Ford F150 Computer with a newer 2000 Ford F150 computer due to an engine and transmission replacement. The problem is the 2000 computer is PATS and my older truck does not use the PATS transponder key, PATS module in the steering column, and PATS instrument cluster. Do you make a module or way that I can enable the 2000 computer? How can I bypass or enable the 2000 computer without having to replace the instrument cluster, steering column, keys etc? Thanks in advance,
James
In search of my own PATS related issue, i've seen quite a few documents with relative info. from what i've been able to gather from these, the EEC and PCM must be replaced together ('98 and newer) as they are coded to each other as well as a key coded to them. to do this, assuming you did get both replaced as new units and not pulled from junkers, you must also aquire a ignition cylinder equipped for reading a PATS key (might as well be a 2000). this is all speculation, but i believe you could mount the new cylinder somewhere in the dash, perhaps behind the glove box, many models have extra room back there. then run the PATS related wiring to the new cylinder, and tow it off to a dealer. coding the key in that year model computer requires the proprietary ford scanning tool and about half an hour minimum. once coded, you can leave the key installed in the dash and use your old one to start the truck as normal. if you were unfortunate enough to get your PCM from a junker, be prepared to pay quite a bit, since you'll need yet another PCM and EEC. i've seen many a forum post with claims of $1200 bills for replacement and coding of a key. i dont believe your instrument cluster will be 100% compatible either but theres something to hope for.
Posted on Jul 28, 2009
How do I bypass / remove the anti theft system
They make a module to bypass the PATS system. It is needed to install after market remote start but it should work on your Ranger. Here is a link to Amazon webpage.
Amazon com Directed Electronics 555P Ford Pats Bypass Module Automotive
May 26, 2016 | 2000 Ford Ranger SuperCab
What would make the theft light not come on at all
99 F-150 ignition/anti-theft question - Ford F150 Forum - FordF150.net
www.fordf150.net > ... > Electrical (Everything except audio systems)
Sep 16, 2009 - I had 2 keys for the truck, one worked perfectly fine, the other wouldunlock the ... over but the anti-theft light flashes and the engine won't actually start. ...Should I just spend the $80 for the switch and hope that is all it needs? ... for Fordkeys (Later 1998-newer Ford, Lincoln, Mercury) ... Mustang 1998 - 2001
electrical - Can I disable antitheft (PATS) on 03 Mustang ...
mechanics.stackexchange.com/questions/.../can-i-disable-antitheft-pats-o...
Jan 4, 2012 - So my question is: Is there a way to just disable the anti-theft system? ... This will make the car always 'see' a key with a chip. ... as they are usually intertwined with the anti-theft system to ensure the engine will not start. ... Where is the Wiper Relay/Control Module located on a 1994-1998 Ford Mustang??? 7.
How to Turn off Theft System on Cars: 7 Steps
www.wikihow.com > ... > Cars > Car Maintenance and Repair
wikiHowJump to Questions and Answers - Be the first to ask a question about this topic: ... Itwill not start and your battery will die. ... Reset a Check Engine Light ... Thanks to allauthors for creating a page that has been ... How to. Make Oat Flour. Cook Bacon in the Oven ... People are incredibly helpful and open to new ideas ...
Jan 27, 2016 | 1998 Ford Mustang
How can I bypass the pats system on a 1999 crown victoria
Ford P.A.T.S system bypass - YouTube
? 2:05
www.youtube.com/watch?v=CvRKZ-DHjGk
Mar 13, 2013 - Uploaded by Ryan Dubyak
Ford P.A.T.S system bypass. Ryan Dubyak ... Transponder Chip Key Bypass How To For Any Car! - Duration ...
Bypassing the PATS ' 4.6L Based Powertrains ' Crownvic.net
www.crownvic.net > ... > 4.6L Based Powertrains
Jun 27, 2011 - 15 posts
They have an entirely different PATS system that does not have an .... I've had a '99CVPI PCM in my '98 MGM for about 10 months now, even ... For ANY of you 1998-2000 Grand Marquis or non-police Crown Victoria guys, ...
Oct 31, 2015 | Cars & Trucks
How to reset pats on 2000 ford ranger
Several things could be wrong/bad. The key/transponder, the receiver in the column, wiring, the security module, and the ecm. You need to have the codes read. This narrows things down. I replace the entire system. I get them at junk yards for $1500 to $200. But you need them all and they have to fit your car, year amke and model, engine size and transmission.
Oct 14, 2014 | Ford Ranger Cars & Trucks
I have a 2001 ford f 150 the anti theft is giving me trouble i try to start and it shuts right off if you place the key in the on position for about 30 sec all gauges power up then the truck will start and...
If the engine starts and runs, it is not the PATS holding things up. PATS is only prior to starting the engine, with the start enable parameter from the cluster. Once this is past, it is not longer involved in the process ( you can use a remote start with a correctly configured PATS bypass module, with a normal straight key to turn the truck to the on position.
Do you have an after market VSS installed ?
Apr 08, 2011 | 2001 Ford F150 Styleside SuperCrew
I put in a car starter in my 03 f150 the truck turns over but will not start. I put the tach wire on a white/pink on the pcm harness that did not work then i put it on a green/white on the coil this does...
Is this a crank no start issue ? If so, is the theft light in the cluster flashing ? No mention about the PATS bypass. One try is to put a functioning key in the ign ( in the off position is fine ) and try to remote start the truck. This would satisfy the PATS check, to know if the PATS bypass is programmed correctly, or if you do not have one, if everything else is installed correctly and you just need to add a PATS bypass module.
Feb 04, 2011 | 2003 Ford F150 Regular Cab
I want to bypass my 99 ford f150 alarm system
If you are talking about the PATS system, no way to do it. There is no factory alarm from Ford, if it is a Ford OEM system, it was added at the dealer. The 97 & 98 has a factory alarm system, but this was deleted after the introduction of PATS in 1999.
Mar 07, 2010 | 1999 Ford F150 Regular Cab
2000 f150 will not start,replaced computer ,fuel pump,try to start and theft light keeps flashing, acts like there is no spark.
If you replaced the PCM, the HEC ( instrument Cluster ) needs to have the PCM_ID cleared. The HEC and PCM are paired at the factory, if this is changed a WDS / IDS diagnostic tool needs to be used. Higher end mechanics and Dealers have the equipment to do this.
If the PCM_ID in the cluster does not match the PCM, the fuel pump is shut off, the same as if an un-programmed PATS key is used ( Crank no start with flashing theft light ).
Mar 05, 2010 | 2000 Ford F150 Flareside SuperCab
Will a 1998 ford winstar transmission fit a 2002 ford windstar? both engines are 3.8L.
yes it will but u may need to change the powertrain control module (computer) to make it work correctly.
Jan 15, 2009 | 2002 Ford Windstar Cargo
Directed Electronics 1100f Ford Pats Securilock Data Remote Start Interface Module Logo
1,665 people viewed this question
Top Directed Car Audio & Video Experts
Colin Stickland
Colin Stickland
Libran Moreno
Are you a Directed Car Audio and Video Expert? Answer questions, earn points and help others
