Question about Dishwashers
Hotpoint Aquarius DF61 Dishwasher & Food residue remaining
Irrespective of the load type (i.e. plates with food residue or without) my dishwasher continually fails to clean the items on the lower and upper trays. Cups & plates are left with food residue on them. I have cleaned the rotating arms, filled the salt intake & rinse aid solution and have also used some of the ''dishwasher cleaning aids'' available from supermarket,,,,but nothing seems to work. Any help welcome or do I just need to get a new dishwasher.
  • mizzfizz Dec 05, 2008
    I HAVE THE SAME PROBLEM BUT I AM ALSO MISSING THE FILTER THINGY FROM THE BASE OF THE MACHINE (SOMEHOW WENT OUT WITH THE RUBBISH?!) DO YOU KNOW WHERE I COULD PURCHASE ONE FROM PLEASE?
  • Anonymous Mar 04, 2009
    See if the washer is actually performing it's 'Rinse' cycle, by opening the door and seeing if the Spray Arms have moved and are wet.
    The electo-mechanical controllers can fail such that they do not make te contact to 'switch' the solenoid to open the water inlet for the rinse cycle.
    The problem with the electro-mechanical controller is that it is assembled onto it's mounting frame BEFORE the frame is spot welded to the stainless steel door, and the mounting screws are mounted inside the frame and inaccessible.
    Even if a new controller was economically viable to replace, and generally they're not, you have to get a complete new door section with everything on it - I haven't even bothered to check for a price.
    Mine's done around 12 years worht of washing for a family of 5 so I reckon I've had my moneys worth out of it.
I have cleaned the filter on my hotpoint aquarius DF61 on cant put it back together.
Posted on Sep 02, 2009
Dirty glasses dishwasher
1st thing is make sure the dishwasher is heating up the water.
if it is heating... you spray arms may be blocked up with food particals.
Mar 21, 2014 | Hotpoint Dishwashers
My hotpoint aquarius df61 do not clean properly cannot find the problem all filters cleaned .all of the crockery comes out dirty
Just had same problem. Checked and cleaned spray arms filter and impellor. Still had problem. Noticed that it appeared to be expeling water to drain at wrong time. Openned mid cycle and noticed water level low.
Took off left side panel to reveal pipework. Main pipe route big oblong in clear plastic had a red valve at the top which was gunged. This was the air release so when water is pumped in air has nowhere to go so it pushes water out through the waste so ther is too little water in machine. Removed this component and used caustic soda to dissolve food waste blocking valve as there is no access. Put it back together and now it works fine. Took about 2 hours (1 hour for caustic to work) no special tools other than star screwdriver required as it all unclips.
Nov 14, 2010 | Hotpoint 24 in. FDW60 Free-standing...
Says model # shu9915 not cleaning well .leaving residue on glasses almost easier to wash by hand and some food stuck on plates etc. and soap tablets not dissolving completely
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Feb 14, 2010 | Bosch SHU9950 Dishwasher
Dishes do not get clean- residue remains
heatman101
Dec 22, 2009 | GE GLD5900NWW / GLD5900NBB / GLD5900NCC...
Food residue on all dishes
The filter systems on the Maytag line of dishwashers which includes Jenn Air is very fine. In most causes the pump needs to be torn down and washed in a sink and a shop vac is also a great tool I use to clean the rest of the pump out that will actually stay in the dishwasher. The spray arms also need to be cleaned in the sink. Check your drain line under your sink as well and make sure that the drain line coming from the dishwasher has a high arch or bend that is higher than the base of the sink. This will prevent sink water from backing up in the dishwasher which can be nasty. Also make sure to run your hot water to the sink before starting a cycle to assure hot fills and the water temp. is best if set at 130 degrees on your water heater instead of 120 or 125 degrees. I hope this is helpful. This kind of problem can be agrivating to solve at times. Scott (North Caolina)
Apr 20, 2009 | GE Nautilus 24" Built-in Dishwasher
Poor cleaning with Hotpoint NDA300Y 73BA dishwasher
be sure rinse aid dispenser is full ..also ck water level after fill should be almost to bottom of float
Nov 01, 2008 | Hotpoint Aquarius WD640 Front Load...
Food odor builds up if dishes not washed daily, even though we rinse evrything thoroughly before loading dishwasher. No water remains at bottom - nothing appears to be stuck in drain. Any thoughts?
No matter how well you rinse wares, some food particles will always go into the machine. Sometimes these particles can build up and lead to what you describe. I would start by inpecting the wash tub area; remove screens, remove wash arms and clean as needed. You are looking for any residual food soil which would harbor bacteria. If all else fails, follow your nose!
Once everything is as clean as you can make it, then purchase a product for cleaning/deliming your machine. One I know of is called "Dishwasher Magic" which should be available at most appliance repair stores. Run this through the machine on a long or heavy cycle. Once complete, run a second cycle with nothing but water to rinse any lingering chemistry.
Lastly, for a 3rd (and final) cycle, add a cup of bleach to kill off any remaining odor-causing bacteria. But, DO NOT SKIP THE RINSE CYCLE mentioned above.
This should take care of the problem,
Kermit
Aug 23, 2008 | LG LDF6810 Built-in Dishwasher
Salt tray full of water
Just pour a bag of dishwasher salt in water will come out.Then light goes out.
Jul 25, 2008 | Hotpoint 24 in. FDW60 Free-standing...
Food particles on washed plates
Sometime food particles stick near the door gasket. First, try changing the DW soap brand.
Nov 16, 2007 | Hotpoint 24 in. FDW60 Free-standing...
Dishwashers Logo
1,233 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
