Question about Fuji FinePix E550 Digital Camera
Unknown I dont now the specific part name, but the thing that extends out that also has the lense on it wont extend when i push power. All i can do is acess my pictures, but when i flip it to take a picture it wont extend out, and the camera turns itself off. I already tried replacing batteries. Could someone help me?
Easy just grab it pull and twist and pull it to full out and power it on and off
Posted on May 11, 2008
How do I set up a Belkin N300 model F9K1015 V1 range extender?
I Will Help You Setup Belkin Range Extender With Your Main Wireless Router in Easiest Steps Possible.
  • Existing Wireless Router With An Internet Service Provider.
  • Power Source & Ethernet Cable ( Optional )
  • SSID (Network Name ) & Password (Network Key) of Your Main Router.
FOR MORE
https://wirelessrouterexpert.com/extenders/setup-belkin-range-extender
Mar 01, 2015 | Belkin Computers & Internet
Canon Extender EF 2x II
There are 2 Canon fittings, EF for all EOS cameras and EF-S for 'crop' cameras. The Canon extender does not fit crop cameras. Whichever make you look at, make sure it will fit the type of mount you have.
If you have not yet bought your lens of choice, Sigma are good and do their own extender compatible with their own lenses but not Canon's. This may be a good option for you
Mar 07, 2010 | Canon EF 2x II Extender Lens 6846A004
Lense error
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
May 26, 2009 | Canon Cameras
Canon G7 lense does not extend fully but it is NOT e18
Maybe lens needs adjustment. The info on this page may help. Copy and paste this link for more info.
http://www.fixya.com/PostAnswer.aspx?thid=1841738&prdid=447928&ctgid=67
Mar 22, 2009 | Canon PowerShot SD500 / IXUS 700 Digital...
Lens compatability
Apparently, the extender is designed to work only with specific lenses. B&H Camera has a chart available here showing which lenses it is compatible with. Note that even if the extender will fit on a specific lens, autofocus capability is not always possible. All the lenses listed are professional series ("L") lenses, and I don't see any 75-300 or 18-200 listed.
Jan 26, 2009 | Canon Extender EF 2x II Lens Converter
Battery died while lense extended and now will not power up.
Some of these cameras that have a lens that extends use gears to extend the lens. The gears can strip or get clogged with fine debris and jam the lens. Usung good quality rechargable batteries NOT ALKALINE will usualy have the power to drive the lens.
Ask yourself, how many cycles do you have on the pack? could the pack be weak and not power the camera fully?
Have you tried pushing firmly in on the battery while you power it up? If the camera will not power on with the door open, try and fold a small trip of paper and sit it between the battery and the door. This might push in on the battery enough to better the connection and solve the issue.
If the battery is fine then you may have a lens problem. The lenses can be jammed easy, dropped or an impact when extended is all it takes.
Jan 26, 2009 | Sony Cameras
My KODAK EASYSHARE M1033's lens will not extend.
your lense isnt extending because u need to charge your battery i gaurentee as soon as u let it charge it will extend once again
Jan 20, 2009 | Kodak EasyShare M1033 Digital Camera ...
Dropped Sony Ciber-shot when lense was extended. Will not fully extend or retract now. How do I remove lense assembly to reset position.
sir,
open your camera,beside the cam part u can see the small gearbox, un screw this part and disconnect it from the base, then slowly turn the lense assy to both side carefully, dont give force. if the lense assy becom loose, fix the gear unit give a 3volt to the motor bring the cam to retracted position,then fix whole unit, it will work properly
thanx,
gulshanclt
Sep 03, 2008 | Cameras
Lenses
No, the wide angle and telephoto extension lenses are specifically designed only to extend the focal length of the existing E-10/20N lens. Their specific purpose is to be a fixed focal length.
Aug 31, 2005 | Olympus Camedia E-20N Digital Camera
Fuji FinePix E550 Digital Camera Logo
139 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
KJ Soni
Level 1 Expert
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
