Question about Canon PIXMA MP210 Photo All-In-One Printer
?color's Hey friends can u tell me what colors go into a CL-31 cartridge 1 hole top 2 bottom Thankx Jeff...
Thankx fixed the problem my self...
Posted on Nov 18, 2008
How I can refill my HP 27 Cartridge at home...
please follow the instructions........
  • 1
    Purchase an ink refill kit that is specific for the HP 27 color ink cartridge. Look over the packaging to insure that it states that the kit is for the particular make and model. Using other types of cartridges may not work properly.
  • 2
    Place several paper towels down to prevent any ink residue from damaging other objects. Place the ink cartridge onto the paper towels. Put on a pair of rubber gloves to prevent ink from staining hands.
  • 3
    Peel off the top label gently from the cartridge.
  • 4
    Observe the three holes that are located on top of the cartridge. There is a solo hole located near a rectangular tab that protrudes and two other holes located next two rectangular indentations into the plastic on the top of the cartridge.
  • 5
    Take a toothpick and gently stick it down inside each hole to verify the color. Take a sharpie marker and mark next to each hole with the correct coloring for ease. Use "M" for the magenta color, "Y" for yellow and "B" for blue.
  • 6
    Take a piece of masking tape and place over two of the holes to prevent ink spillage from mixing into other color positions.
  • 7
    Read over the ink cartridge refill kit for the appropriate amount of ink needed to fill the syringe with the correct color for the uncovered hole.
  • 8
    Expel any excessive ink from the syringe. Insure that you have the correct amount of ink by following the markers on the side of the syringe.
  • 9
    Place a paper towel over the end of the syringe and while holding the tip upwards, gently press or tap the syringe plunger to expel any air.
  • 10
    Insert the syringe needle into the appropriate color hole until the tip hits the bottom of the cartridge. Pull the syringe up a little from the bottom of the cartridge to prevent blockage when expelling ink.
  • 11
    Expel the ink into the color hole slowly. Stop if ink begins to protrude out of the color hole. Take a cotton swab and gently wipe the outside of the color hole and then cover with tape.
  • 12
    Take the syringe apart and rinse thoroughly to prevent ink colors from blending. Take a cotton swab and dry out the inside of the syringe.
  • 13
    Repeat above steps for the remaining two color positions that are left.
  • 14
    Gently take a needle and put a hole in each tape that covers the color holes for ventilation. Allow the cartridge to sit for at least one hour after completing refill instructions.
  • 15
    Reattach the original top label.
  • Please post your feedback and Vote if the problem resolved as per your satisfaction.
    Sep 22, 2010 | Computers & Internet
    Tip
    How to refill the INK Cartridge ?
    How do i refill my INK Cartridge ?
    There are 2 distinct method
    1) Black has a bladder
    2) Color contains sponges - we need 3 sirenges with needle
    to fill the Color cartridge with sponges - simply punch
    COLOR CARTRIDGE
    1. If you see the Cartridge turn it round and locate the filler holes by removing the plastic top cover of the cartridge.
    You may need to pry plastic top or hole cover off using a thin metal blade.
    please make sure that you do not damage the sensors on the back of the cartridge whilst doing this.
    2. Using the picture(on the cartridge which shows you the 3 differed colored spots), fill syringe with the corresponding color ink.
    3. Insert the syringe into the correct hole of the color being filled and push all the way down.
    Notes : You will feel resistance as there is a sponge inside.
    So Slowly inject approximately 8ml of ink until you can just see the ink surface on the top of the sponge, any more and it is over-filled.
    If this happens simply draw back on the syringe a little.
    4. Rinse the syringe and needle thoroughly before proceeding then repeat the process for the other colors.
    8. Re-attach the cover securely with adhesive tape and continue using the cartridge.
    BLACK CARTRIDGE
    1. Fill the syringe with approximately 20ml of black ink.
    2. Push the syringe all the way into the filling hole and SLOWLY inject all the ink into the cartridge or until the reservoir is full.
    3. Replace the cartridge and run 1 - 3 cleaning cycles as per printer instructions.
    4. If necessary leave cartridge in printer for up to 24 hours. (This allows ink to flow to the print head).
    on Jan 04, 2010 | Office Equipment & Supplies
    HOW TO REFILL
    I love to give the answer for your question but we don't know which printer model you are talking ?
    Following the the common procedure for refilling the Ink Cartridge
    COLOR CARTRIDGE
    BLACK CARTRIDGE
    Jan 22, 2010 | HP Office Equipment & Supplies
    Is MP210 and MP240 the same? can i use the same cartridge?
    no both are different
    Here are the list of cartridges u can use
    MP210
    PG-30 Pigment Black
    PG-30 Pigment Black Ink Cartridge
    PG-40 BLACK
    CL-31 Color FINE Ink Cartridge
    CL-41 Color
    MP240
    PG-210 Black Cartridge
    CL-211XL Color Cartridge
    CL-211 Color Cartridge
    PG-210 XL Black Cartridge
    Nov 28, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
    Instructions on color fill holes. For HP 1350 xi all in one
    this printer uses a HP 57 color cartridge. INSTRUCTIONS are : 1) place a paper towel over surface you will work on. 2) get disposable hand gloves , 3) remove carefully the top label of cartridge (do it slowly to avoid tearing) put it aside , your going to need it to put it back. 4) with the electrical golden dots strip side facing you , the top LEFT side hole is CYAN color , RIGHT side hole is YELLOW , and middle hole (close to you) is MAGENTA . Push the FILLING TUBE about halfway down into the cartridge, be careful not to damage the ink chamber at the bottom of cartridge. squeeze bottle (tube) in a slowly manner until the chamber is full . hope this helps AJ
    May 03, 2009 | HP PSC 1350v All-In-One InkJet Printer
    Ink and printer
    You'll need to either put it back in or replace it.
    You need to have both color and black cartridges in for your printer to work.
    Never throw away cartridges, save money and refill them or you can take them to most any computer store for recycling.
    Mark
    Apr 14, 2009 | Canon Pixma iP2600 Photo InkJet Printer
    I NEED TO KNOW HOW TO REFILL INK FOR A CANON MX310 #41 COLOR.i DON,T KNOW IF YOU PRY THE TOP OFF OR IF THERE ARE SOME REFILL HOLES SOMEWHERE.SHIRL85@EMBARQMAIL.COM
    Your printer uses the following cartridges:
    canon-pg-30
    Black Pigmented
    canon-cl-31
    Color
    canon-pg-40
    Black Pigmented
    canon-pg-50
    Black Pigmented canon-cl-41
    Color
    canon-cl-51
    Color
    ou find the refill instructions for your cartridges in the book at the link below:
    Download Inkjet Refill Instructions
    You can also buy refill kit here: inkjet refill products.
    You also need to reset the cartridge after refill, see: Reset Ink levels for canon mx310 - FixYa
    Mar 02, 2009 | Canon PIXMA MX310 All-In-One Printer
    Canon pixma mp145
    It's arranged C M and Y. Meaning Cyan on the left and Magenta on top and Yellow on the right. If you are not sure, stick a needle or if you've enlarged the hole, a toothpick. When you pull out the needle wipe it on a piece of tissue the residue will show the color. On a toothpick you'll see the color as you take it out. Good luck.
    Aug 04, 2008 | Canon PIXMA MP150 All-In-One InkJet...
    HP 95 Tri color inkjet cartridge refill
    Yellow Top
    Megenta, Bottom Left
    Cyan, Bottom Right
    (leave the middle two holes alone)
    Jan 05, 2008 | Office Equipment & Supplies
    Canon PIXMA MP210 Photo All-In-One Printer Logo
    21 people viewed this question
    old marine
    old marine
