Question about Samsung HCN653W 65" Rear Projection Television
Double vision on Samsung HDTV 1080i Model PCN542R Need a convergence amp board. Where can I purchase one, and how much is it
  • 70 Answers
Hi .
Its much cheaper to replace the stks on there own.
It may also have a couple of 3.9 ohm resistors cooked.
Posted on Dec 28, 2008
Panasonic rear projection 52inch cinema vision 1080i hdtv looks 3D with double vision red, blue and green how do I fix
Replace the convergence chips--should be stk-392-110's in the Panasonic.
I have start to finish free instructions for this repair based on the model number----a email address will get them for free.
Jun 06, 2012 | Panasonic Televison & Video
How do i fix my samsung 1080i hdtv. It has a double picture and is red and blue, and also looks like a bow tie effect
The tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all it resistors are dead too.These parts on the tv convergence board,must be replaced to solved pictures convergence problems.The shop,will cost u like $300-$350 for parts and labors.
Nov 21, 2010 | JVC AV-48WP74 48" Rear Projection...
My sony kp57ws510 model tv has double vision and the double vision that shouldnt be there is in blue and red..whats wrong with my tv?
The tv have a problems known as a convergence problems,it dead.The tv colors lines R,G,B mis alignment,have shadows pictures or 3D pictures look alike.The tv convergence board have dead parts.The 2 STK convergence ICS and some or all it resistors on the tv convergence board are dead.These parts on the tv convergence board,must be replaced to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Oct 29, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
My tv suddenly went to red and green double vision. Looks like 3D without the glasses. I want to repair myself. Samsung 1080i model HCR5245W. MFG July 2005.
That would be your Convergence, Encompass Parts Distribution
has Convergence Module for $50.00 that goes to a HCR5245WX/XAA 1-800-638-3328
Or you can just replace ICs will have STK on them
Mats has ICs 1-800-628-1118
Sep 27, 2010 | Televison & Video
My smasung hdtv 1080i is about 8-10 yrs old. it
you have a convergence problum. The convergence ics go bad about every 6 years
Apr 15, 2010 | Sony KP-53S65 53" Rear Projection...
Double Vision & Bowed Screen
Chances are that the convergence amps are bad.
If those are mounted on a separate board, replacing the board would be the easiest thing to do. Running the magic focus or touching up the convergence in the customer menu may be required.
May 04, 2009 | Samsung HCN653W 65" Rear Projection...
Double vision on my samsung HDTV 1080i
If one or more of the colors, red, green or blue have separated from each other and you can`t correct the problem using the convergence procedure as described in the users manual, that would indicate you have a convergence problem. Bad solder connections on the convergence output chips are common. If the set had a rough ride down the stairs while moving, that may have facilitated in exposing a preexisting condition. However, the most likely cause is the natural failure of one of the convergence output chips and or related components and not the move. The fix is to have a qualified technician address the problem. This is not a do it yourself job.
Feb 22, 2008 | Televison & Video
Blurred/double vision Samsung HDTV 1080i projection
Your convergence ICs are bad and maybe the two resistors right next to them. This is an easy and inexpensive repair if you can solder. A repair shop will run about 400.00 The parts are readily available for about 10.00 each you will need two ICs STKXXX-XXX
Look inside your set for a large aluminum heat sink that's where hey are located they will have an STK number like above stamped on them. Those are the part numbers. Let me know what type of TV and model number you have and I can help you locate the proper parts.
Jan 24, 2008 | Televison & Video
Replace the convergence ICs. you will need two of them. They are located on a large aluminum heat sink with STK numbers. They cost about 10.00 each. They need to be soldered in. Its an easy repair if you can solder. Let me know if you need any additional info.
Sep 16, 2007 | Sony KP-53S65 53" Rear Projection...
Double Vision
Unfortunately, the complete convergence amp board is no longer available from Samsung. But the board is available from ptscorp.com. Go to the website, get the telephone number, ask them what convergence Amp board you need and if they have it. If you know how to solder and unsolder, you can simply change the convergence amp IC's, on the main convergence board. The IC number if the IC's is STK392-040 Good Luck.
Jun 16, 2007 | Samsung HCN473W 47" Rear Projection...
Samsung HCN653W 65" Rear Projection Television Logo
264 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
