Question about Jensen's VM9312 Car DVD Player
Vm9312 in dash will not play video
It plays sound an the screen shows the caution sign saying the park brake needs to be down but it is bypassed and the pink wire is hooked up to a constant ground
Go to your radio tuner screen and go to your set up page then use your remote and press 5,4,3,2,1,0 and hidden menu will pop up then you will have to press the tool looking button on the left side of the screen and it will give you an option to it off so you dont have to hook up the pink wire.
Posted on Dec 21, 2008
  • 3 Answers
Theres a quicker way. take the pink wire and touch it to the ground wire and tape it. then the blue screen will go away and you can play dvds all the time.
Posted on May 10, 2009
Can i run my pink wire on my jensen vm9312 to the ground
yes, that will bypass the safty feature and allow you to play a DVD while the car is in motion.
Note ; you can also just enguage the park brake ONE CLICK and achiev the same.
Nov 01, 2011 | Jensen's VM9312 Car DVD Player
Video
Here is the code:
I did this with the remote
Press stop twice(which is also the BAND button)
Press 1,2,6,4
Press down 1 time(button below the Play/Enter)
Press Play/Enter 1 time
(You should now see the menu)
Brake override should say No
I was told to change macrovision to No
Hit sys setup twice to save and exit
Hope it works like mine did!
Jul 18, 2008 | Jensen's VM9312 Car DVD Player
How to by past the brakes wire for the dvd to play
According to the owner's manual, the pink wire is your parking brake wire and it has a label 'PRK SW' on it. It requires a negative signal to show that the parking brake is engaged. If it is currently hooked to your parking brake, you will need to trace it to where it is connected and remove it first. Be sure not to leave any wires exposed that can short out. Then connect the wire to a source of ground. this can be the black wire coming from the head unit, or a convenient screw nearby that is mounted to the vehicle chassis.
The manual can be found here:
http://www.crutchfield.com/S-x3LxzvPnGLv/p_110VM9312/Jensen-VM9312.html
Please note that it is likely illegal to have video playing where the driver is in view of it. Check your local laws before considering making this modification.
Feb 16, 2010 | Jensen's VM9312 Car DVD Player
When I try to play a movie, I only see the warning sign on the screen. I can hear the movie playing, but the warning will not go away. This is even when the vehicle is in park. Any ideas what may be wrong?
Bypass Code
1. Go into Am/Fm mode
2. Hit "setup" on the remote control
3. Enter 543210 on the remote, listening for the beep for each number entered
4. A new menu will appear. Touch the button that has the hammer/screwdriver on it in the upper left-hand part of the screen
5. Select Brake bypass to "ON" and hit the "X" near the bottom of the screen
Aug 18, 2009 | Jensen's VM9312 Car DVD Player
E brake wiring problem no video
Do this, and don't worry about the parking break wire.
The parking brake bypass procedure is as follows:
1: Go into AM/FM mode
2: Hit "setup" on the remote control
3: Enter 543210 on the remote, listening for the beep for each number entered
4: A new menu will appear. Touch the button that has the hammer/screwdriver on it in the upper left-hand part of the screen.
5: Select Brake bypass to "ON" and hit the "X" near the bottom of the screen.
6: Use the unit wisely and above all safely. A ticket is one thing, causing a fatal accident due to negligence is another.
Aug 09, 2009 | Jensen's VM9312 Car DVD Player
PARKING BRAKE DISABLE my jensen in dash doesnt want to play dvds its displays a blue screen saying something about the breaks
yes its saying in toorder to play dvd's u must engage parking brake which means the wire is suppose to be hooked up to the parking brake....BUT i know the trick to make it work where u can play dvd's and drive
May 31, 2009 | Audiovox Jensen In-Dash DVD/CD Receiver w/...
Jensens VM 9312 car DVD player problem
Just go to the set up menu ( Your screen should say setup at the upper center of your screen ) Then press 5, 4, 3, 2, 1, 0 with your remote control and a second menu will apear, on your left side press the second option and select parking bypass to on.
Sep 03, 2008 | Jensen's VM9312 Car DVD Player
How do i bypass the parking brake switch in order for my video to play
ITS just a ground cable hook it to the radio ground i did and mine works fine
Aug 21, 2008 | Jensen's VM9312 Car DVD Player
Linear uv7
GROUND THE PARKING BRAKE WIRE DIRECTLY TO GROUND OR 12VOLT WHICH EVER IT CAUSE FOR WHICH IS USUALLY GROUND. U MAY ALSO HAVE TO INSTALL A TOGGLE SWITCH TO . CONSULT UR USERS MANUAL ON THE PROCESS FOR ACCESSING THIS FUNCTION
Aug 16, 2008 | Car Audio & Video
get a toggle switch hook to a ground then to the e-brake wire flip on and off 3 times 4th time leave on worked for me
Mar 19, 2008 | Dual XDVD8265 Car Video Player
Jensen's VM9312 Car DVD Player Logo
280 people viewed this question
Top Jensen's Car Audio & Video Experts
Richard Foster
Richard Foster
afairman1927
Jose Velazquez
Jose Velazquez
Are you a Jensen's Car Audio and Video Expert? Answer questions, earn points and help others
