Question about Dewalt DW824 5" Electric Angle Grinder
Why does my dw831 grinder keep tripping circuit breakers?
When you plug in the dw831 grinder, and then pull the trigger, the grinder runs for maybe five seconds, makes a terrible noise in the process, almost like a three phase motor that is single phasing, then the circuit breaker will trip. what is up?
  • 23 Answers
Try checking the brushes.
to do this: remove the 2 small covers on the left and right side of the tool and push aside the coil spring holding in the brush. the brush should freely pull out of the holder.
when you have the covers off, look for charring or melting. and after the brushes are out, rotate the arbor to move the armature inside and look to make sure it's not charred.
if that doesnt help, take apart the handle and look for melted or exposed wire. dewalt likes to pack the wires in tight among the screws and sometimes the normal vibration of the tool will cause a screw to cut into a wire and short the wire.
new brushes and holders (if melted) are usually around 20 dollars US
Posted on Nov 18, 2008
Why does the circuit breaker keep tripping?
Need more information is it dryer,stove,ac ,heat, water heater,bathroom plug, garage plug ,outside plug, other
Lighting circuit with plugs
Oct 19, 2016 | Dryers
Makita grinder keeps tripping circut breaker
FIRST OF ALL !!
Control where the tool is used first for undervoltage on the mains supply group.
If it is everywhere a problem FIRST replace the circuit breaker.
After that control all connectors last check interference suppression capacitor.
If all are controled , relace armature or electric field or both.
Aug 19, 2016 | Makita Saws
Whenever I switch it on at the flick switch it trips the mains circuit breaker now. Any idea how to fix this
Yes it is Pulling more juice through the wires than the breaker is set for just up your breaker size or you will have to move it to another outlet that don't have a lot of stuff plugged in to it .....
Mar 05, 2015 | Coffee Makers & Espresso Machines
Breaker
What is this on? If it is a breaker, the grease is to coat the feed wires to keep the corrosion and resistance down
Apr 14, 2013 | Electrical Supplies
Lg microwave oven trips circuit breaker
The magnetron probably has a partial short pulling more current than normal as it runs, the other two items that give trouble is the high voltage diode, "sometimes cracks" to the high voltage capacitor, "usually shorts"
Mar 29, 2012 | LG Microwave Ovens
My Hobart Handler 120 stopped working during a welding process. Now when I pull the trigger, the 30a 110v circuit breaker trips. The machine can be turned on and the breaker holds (cooling fan in the...
Please don't give me a bad rating for this. Its just a little extra info. you didn't mention that may help you find the problem. Depending on your specific model, there should be 1 or 2 breakers on the unit it self. If there is only 1, it will shut down the entire machine when tripped. If there are 2, the top one is for the whole unit and the lower one is for the wire feeder motor only. There is also a thermal overload that will shut down everything except the cooling fan. Secure the trigger closed and let the fan run for a while to see if it re-starts when cooled. If the depth of the weld was stable before the problem occurred, I would suspect a short in the motor and not the rectifier. That is not a sure bet though. If the transformer does not start when it cools, UNPLUG the welder and short the transformer to ground to be sure the capacitor is discharged. Then isolate the feed motor and transformer and use an OHM meter to test them individually to ground for a short. With a little luck, it will be the feed motor. Please let me know if this helped at all. I am new and still learning how to explain what I am thinking. Thanks for writing us.
Roger
Apr 02, 2011 | Welding Tools
My ryobie bench grinder keeps tripping the rcd within a second of turning it on?
Assuming your local tech confirms that your bench grinder tests ok. The problem is probably that the grinder draws too much current for the RCD and is therefore detected as an earth leakage. High amperage devices often do that. Your best bet would be to plug it in to a socket which is on a non-rcd circuit. Maybe you have an RCD on the whole house though? I would start with returning the grinder and trying a different brand with a lower amperage/wattage rating. If that doesnt work, I would call an electrician to discuss installing a different RCD or running a separate circuit for your power tools.
Mar 03, 2011 | Jet Industrial Bench Grinder 6in new
Cooler keeps on triggers breaker
If it is tripping the breaker, stop plugging it in. The breaker is tripping because something is wrong, and continually resetting the circuit WILL cause a fire. Either return the unit, or have an electrician look at it. You can also try plugging it into another circuit in your house to isolate the problem, but please don't repeatedly reset the breaker, there IS a problem somewhere.
May 27, 2009 | VinoTemp (VT60GNV) Wine Cooler
Fridge keeps tripping the circuit breaker
get an inexpensive clamp amp meter (Harbor Freight has them). Turn off power to the plug. Remove plug from wall but do not disconnet wires. turn fridge OFF. plug the unit in the recept. turn on the power. set the meter for the higest reading (amps) & clamp it around the black wire. turn the fridge ON & observe start up current & the "run" current. If the fridge is within limits on the data plate the problem is in the wiring circuit, maybe a loose connection either @ the plug or the breaker. if there are several plugs in the circuit, the problem could be in one of them. In addition, if there is a gfi plug in this circuit, it could be faulty also.
Mar 01, 2009 | Refrigerators
Dewalt DW824 5" Electric Angle Grinder Logo
526 people viewed this question
Top Dewalt Saws Experts
Parson's Repair...
Parson's Repair...
JOHN LAPIER
Are you a Dewalt Saw Expert? Answer questions, earn points and help others
