Red light on power fades on and off but won't turn blue and power up
I see so many here with no sound/nopicture issues:
ISSUES:
1. IF sound main fuse/s are good.
2. If no power or standby check main fuse, standby power supply and any signsof damage you can see---burnt parts etc.
3. almost all these sets the troubleshooting involves checking voltages on the main power board to narrow down theproblem.
4. Be safe and if you do not know what you are doing don't open the set.
Answers to issues:
1. RE:fuses---if a blown fuse is found get a good replacement(not the genericones like Radio Shack). Many fuses are special even aside from amperage--Don'tput a higher rated amperage fuse in the set for any reason.
2. RE: power supply in set: if total dead aside from main fuse the set uses astandby power supply that runs 7/24 and a main supply (some are combined andsome not.
Here aside from checking fuses you want to examine all the filter caps on thepower/standby to see if any are puffed up or buldged up in some fashion--Iattach a photo of a good one---top should be silver metal and PERFECTLY flatand have no brown material coming out on top or bottom.
What happens in the standby area is they use caps with too low a voltage rating(saves money) which causes them to fail in a year or two---the standby runs7/24 and the heat dries out the caps and they fail.
3. Trouble shooting consists of the above and then at some point you have to buyand try a board to see if it fixes it or not.
4. Safety first--no TV set is worth getting injured or even killed over.If set is opened at least look for puffed up and bad caps like in thisphoto.
SOURCE: My 42"LG 50 TV will not turn on
One important step to see if you are having an internal problem is to perform a power drain.
1. Unplug the product's power cable so that the device is not grounded to the house. Do not simply turn off the power-bar if one is in use.
2. Press and hold in the products power button for 1 minute to release the retained electricity from the capacitors and circuit board.
3. Plug the product back into the wall outlet rather than a power-bar to rule it out of contributing to the problem and turn the device back on.
If this does not work but you are still seeing a LED lit up, there is probably a problem between the TV's power supply and the mainboard and service maybe required.
SOURCE: lg 26lg30 light blinks red blue wont turn on.
you have a bad cap in the power supply
these are can shaped device thet if bad will vent anf put up on the top the valoue is wrtten on the side trplace them and you should be good to go
SOURCE: LG 26LG30 screen suddently went blank. Light flashing blue/red
There are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
SOURCE: 61" plasam TV will not turn on
This is one of two problems, Bad capacitors in the power supply or your Y Sustain board has failed, I would go for the first, take the back off your tv and look for swollen or domed shaped capacitors on the power supply, They may also leak a brown liquid like substance.
Replace all that you can see and this should cure the fault.
SOURCE: No Sound, No Picture on LG 42LC7D
I do not have a solution but I have the same situation with my tv
