Question about Canon PIXMA MP780 All-In-One InkJet Printer
Black Line printing on copies
Every time I copy something, it prints a black line down the side, about 3 inch from the left side... Both the printers we have of this brand does this. Please help. Thanks
  • Anonymous Mar 26, 2014
    When printing sometimes it has black lines across the page they run side to side about 7 inches across the page and about 1/4 inch widestarts out just a few on the page but gets worse and sometimes all the way down the page. But if you stop the print job and make copies they are fine.The customer has changed the print cartridge and made no differenceCould someone please help.Thanks
  • 26 Answers
Just clean the glass top of the scanner and the slit of glass on the left hand side of the scanner.
Posted on May 20, 2007
Clean glass, the big glass and the scanner glass - works like a charm!!! yeah yaw!
Posted on May 27, 2007
SOURCE:
Getting black strip about 9/16"
it may be due to either malfunctioning of the scanner tube within the printer itself or whenever you copy a certain page the lid is not properly pace resulting to excess light on that side giving you black line when the copying is in process
Mar 06, 2011 | HP Officejet 5610 All-In-One InkJet...
Black line is present when copying document; not
This sounds as if you have some ink/contamination on the small scaning glass that sits to either the left or right of the main glass on the copier.(Depending on the model/make)As your original is scanned over this thin piece of glass the scanning device will see any spots and this will result in a black line down the page.Please clean the glass with a soft rag.
Oct 12, 2009 | Office Equipment & Supplies
When copying or printing a fax, a vertical black line 2-3 mm line
try cleaning the rollers with water in the feeder at the top check the glass too too see if it's dirty
Jun 27, 2009 | HP Officejet 6310 All-In-One InkJet...
Black vertical line (1 inch wide) appears while scanning/copying
For this kind of problem you need to call the tech support because the printer is already messed up and it is in need of replacement
Hope this help
Byron
Jun 15, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Black streak down side when making a copy
Hello sir; I believe you need to replace drum cleaning blade.
Mar 12, 2009 | HP Office Equipment & Supplies
Mfc-7420 Black Line horizontal across paper in 3 places
try moving the small blue slider on top of the drum cartridge side to side 10 times.
Mar 10, 2009 | Brother MFC 7420 All-In-One Laser Printer
Black line down the middle of my copies
It sounds like you have a dead spot in your imager.
Feb 20, 2009 | Dell All-in-One 968+ Wireless Network Card...
Black line down page when coping from copy feed
The small glass surface at the top of the scanner bed had some gunk on it. I scrapped it off and the line went away! Yay!
Jan 01, 2009 | Brother Multi-Function Center MFC-240C...
Black line down the paper on copy mode. Ok in print mode.
There is most likely something on your scan glass that is blocking the scanner. Clean of both pieces of glass that are there when you flip open the ADF, or top cover. Try to copy again. If it is still there then there is either something on the scanner piece that moves back and forth to scan or one of your scan LEDs is burnt out and the scanner will have to be replaced.
Dec 17, 2008 | Brother MFC 7420 All-In-One Laser Printer
HP 3050 Black Line
I was getting a verticle black line and I had to clean the glass, the long white bar above the glass, and the white and black rollers before my problem was solved.
Mar 12, 2008 | HP LaserJet 3050 All-In-One Printer
Canon PIXMA MP780 All-In-One InkJet Printer Logo
570 people viewed this question
Clive
Clive
old marine
old marine
