Question about Bose 901 VI Main / Stereo Speaker
I connected the Bose 901 VI EQ to the Tape input/output jacks but for some reason it doesnt seem to work. I currently have, connected to the amp....two 901 speakers, two 201 speakers and a sony center channel.
All the speakers are on, but i cannot get the Bose EQ to work at all. When playing music thru the DVD player the sysem sounds GREAT, but when using it for home theater, it is lacking that wow effect. Can anyone help?
Similar problem...I came up with a solution with
help from Onyko. For my receiver, at least, the bottom line was that
the output from the equalizer MUST go to 'Receiver, Tape In'! Since
that is the ONLY input source from the equalizer, you must combine
elsewhere. Part of my setup included the Radio Shack Audio/Video
Selector box which costs $21.99...you might not need it, but in my
case, I couldn't plug all components into the back of the receiver and
have them go through the equalizer.
Since I have a satellite
receiver, DVD player and TV, that I want to route through the
equalizer, here is the way mine is set up and working:
Satellite receiver and DVD player out to Radio Shack audio/video selector
Audio/video selector out to VCR in.
VCR video directly to TV
VCR audio red/white (audio) out to equalizer
Equalizer out to Receiver Tape IN (Receiver Out not used)
Hope this (or a variation of it) helps.
Posted on Dec 21, 2008
Jan 15, 2015 | Bose Audio Players & Recorders
Nov 22, 2013 | Bose Audio Players & Recorders
Aug 23, 2011 | Audio Players & Recorders
Jul 07, 2011 | Marantz SR7005 Receiver
I have a setup similar to what I think you're trying to do and it works great!
You're in luck because you have a full complement of pre-outs. You'll need a separate amp for the 901's.
First some background.
The use of 901's Active EQ (or any external proxcessor) in any digital AV receiver setup for anything EXCEPT STEREO listening through the 901's alone requires you to have a separate amplifier for them and to avoid having to use a Tape Monitor which could introduce proprietary and potentially damaging Active Equalization back into anything in the AV Receiver with its conventional speakers.
In an AVR, if you activate any Tape Monitor circuit at all, you will kill any digital sources. That is a function of AV receivers in general, nothing to do with 901's. Your Pre-Outs get us around that possibility and limitation but it also means you need a moderately powerful amp for your 901's. I use a Carver MT-200.
Run it with the Active EQ between the receiver Front L and R Pre-Outputs ** and the 901's amp channels. ** Front Pre Out (or one of your analog Tape Outs) >>> Bose EQ Amplifer IN, then Bose EQ Amplier OUT >>> new amplifier IN.
Then set the new amp's volume control (if it has one, mine doesn't) to something HIGH and leave it alone. Run through your speaker setup routines on the AVR. After levels and distances are set the AVR will be the boss of the 901's. With 901's don't even need subwoofers but they don't hurt. If you do have subs I recommend sharing the LFE with the 901's.
I've done this in my own setup once. Turn the 901's around so the rear faces point into the listening area. Crank up a movie like Master and Commander and when the waves are crashing or cannon are firing you WILL FEEL A BREEZE from them. Now THAT is multi-media!
I advise having the 901's share LFE with any subwoofers you might have.http://www.retrevo.com/support/Harman-Kardon-AVR-230-Receivers-manual/id/386bh145/t/2/
Feb 04, 2011 | Bose 901 VI Main / Stereo Speaker
Nov 28, 2010 | Bose 901 VI Main / Stereo Speaker
Oct 15, 2010 | Bose 901 VI Main / Stereo Speaker
Sep 15, 2010 | Bose 901 VI Main / Stereo Speaker
Jan 06, 2009 | Bose 901 VI Main / Stereo Speaker
Dec 24, 2008 | Bose 901 VI Main / Stereo Speaker
582 people viewed this question
