Question about Iomega 33089 250 GB Hard Drive
External HD won't mount
Hi I have an external hard drive (p/n = 31686100, model = RPHD-U) that will not show up on my Finder.  I use a MacBook Pro with OS 10.5.5.  I can see my hard drive on the disk utility application but it won't let me do anything to it.
tasha
  • 6,831 Answers
Hello
Okay , so there are some steps to figure out what is wrong with your external.
Firstly , if your computer makes a sound when you plug in your external , go to Start-Control Panel-Administrative Tools-Computer Management-Disk Management , and see if your external drive is listed here with your local drives. If it is listed , right click on the drive and change the drive letter to make it appear in "my computer".
If your drive does not make a connection sound when connecting to your computer and also does not show up , please follow the next step.
Remove the hard drive from the casing if possible and install it in your computer case or another external case.If the drive works , the problem is with the casing and you can ignore the drive.
Now , if the problem is with the casing , there are still 3 possibilities.
  1. The USB cable between the drive and the computer may be damaged.
  2. The circuit board which connects your drive to the interface of the external may be blown.
  3. The power supply (if applicable) may have a blown transformer.
The latter is the easiest to diagnose , does your external light up at all when you plug in the power? If not , then this is probably your problem. On the bottom of the adapter is a label which you will be able to use to have a new adapter made at your local electronics shop and this will cost about $30 max. They will also be able to test the adapter with a clamp meter to see if this is really the problem and this should be free.
The second component you want to test is the USB cable. If you have a printer , swop out the cables and see if your printer functions normally. Most externals use the same connector so you should be able to test it in this manner. If the cable works go on to the last step. If the cable is defective , replace it with a new one which you can find for about $10 at most electronics and chain stores.
The last component to test is the circuit board. This is a bit of a grey zone as you probably won't be able to spot the blown component unless it failed really badly. With the casing already opened , locate the external's circuit board and check to see if you have any blackened components or fluids leaking from some components. If all the other components of the external worked perfectly , then this is the faulty part. It is not really economical to replace the circuit as most of the time it is out of production by the time you need to replace it and it still costs a lot even if it is available so if your drive is working perfectly when connected via sata or IDE on your computer , the best is to buy a new casing and place your old drive in the new casing.
A casing costs about $50 and you could get it at most tech shops and big chain stores like Best Buy.
I hope this solves your problem and please reply if you need more help.
Kind Regards
Andrea
Posted on Sep 29, 2010
Drive does not appear on macbook pro
You need either need a driver to detect the hard disk or you will have to format hd.
Jul 25, 2014 | Western Digital WD Elements Portable...
Adata superior SH93 on macbook pro cant see drive
If the drive is formatted for anything but a MAC, for example Windows, The drive will be seen but not data will show as the mac cannot read most Windows file systems. Try connecting the drive to a windows machine and see if the data can be read.
Mar 10, 2014 | ADATA Superior Sh93 500 Gb External Hard...
My Toshiba 250gb external hard drive model hddr250e03x is not recognized by my macbook pro but the light turns on. It works on my friend's macbook pro but not mine
I'm assuming you mean it doesn't appear in Finder. Open up disk utility and it should appear there if you say the MacBook is providing power to the hard drive light. You may have to reformat or reset your Mac if you want it in finder
I’m happy to help further over the phone at https://www.6ya.com/expert/tarik_f88885a87e319a0d
Oct 14, 2013 | Toshiba Canvio 500 GB USB 3.0 Portable...
Hi, guys. Just received your Iomega eGo Helium 500 GB external hard drive and successfully backed up the HD on my MacBook Pro. My question is whether your HD can be formatted/configured so I can also...
Yes all external drives can be formatted but formatting will always wipe off everything on it. If you want to format it you can right click on it when it appears in Windows Explorer. You are usually offered the choice of file system FAT or NTFS. FAT is limited to a file size of about 4 GB, so usually choose NTFS, I am presuming you are talking Windows system. Then you would have to copy your files to it once again.
Nov 02, 2017 | Iomega 500GB eGo Helium Portable 500 GB...
How can i save my files from a macbook pro to an external hard drive if the hard drive is not formatted for mac? Do i have to use he ntfs-3g?
Yes, you will have to format that hard drive so it can read and write on a mac. you can do this by going to Disk Utility in the Finder, and selecting the drive that you wish to format.
Feb 14, 2011 | Apple MacBook Pro Notebook
G tech hard drive not recognized by my macbook pro
Hi Evan
The fact that you have tried all three connectors suggests that the fault lies with the drive. Either the interface board or the HD itself. If you have access
to another computer you should be able to prove it one way or another.
Over the years I have seen many external drives fail (I had two identical drives of my own fail on consecutive days one proved to be the firewire board in the box, the other was the circuit board built into the HD), and it's quite difficult to decide where the fault lies.
Do you hear the HD spinning when it powers up (press your ear against the case)? You should be able to differentiate between the HD and the noise of the fan. Is there any clicking?
Is it still under warranty?
Thinking about it, if you get nothing with the USB and the Firewire then it's a good chance that the HD inside has failed.
Jun 17, 2010 | GTech G-Tech G-Drive Combo 500GB...
MacBook Pro often will not recognize commercial DVDs
Go to MAC's website and see if there are any driver updates for your MACBOOK Pro.
Oct 25, 2009 | Apple Genuine Pioneer "SuperDrive"...
Hi, my WD hard drive is connected to my macbook, but can't access
check under the system profiler which can be found in the applications folder and then in the utilities folder. See if under usb whether the drive is showing under there. If it is, open up disk utility and use the verify disk to see if there is a problem with the drive, if there is use the repair disk to repair it.
Other things to check try a different usb port on the macbook or a different usb cable.
Hope this helps
Oct 21, 2009 | Western Digital 250GB MyBook External USB...
Hard Drive not mounting
Check the jumper on each hard-drive.
My guess is that the WD drive has the jumper in the "correct" position, for mounting inside an external case, while the other drives have their jumper set to an "incorrect" position.
Set the jumper to MA(ster), not to SL(ave), nor to C(able)S(elect).
Sep 08, 2009 | Macally 1 Bay PHR-250CC (0701107485355)...
WD 500GB MyBook stopped mounting on MacBook Pro
Have you tried it in another computer? I think these kind of problems can sometimes be caused by USB voltage problems, especially if your MBP has an old battery (I believe the battery is used as a power buffer to keep size of transformer down). If that doesn't work, see if you can find someone with the same HDD power supply and try switching that over. Failing that it's data recovery, you may be able to do this yourself by switching the actual hard drive into a new enclosure.
Aug 23, 2009 | Western Digital 500GB My Book Pro-External...
Iomega 33089 250 GB Hard Drive Logo
526 people viewed this question
Top Iomega Computers & Internet Experts
Arora Singh
Arora Singh
Starnley Johnwells
Starnley Johnwells
Marvin
Marvin
Are you an Iomega Computer and Internet Expert? Answer questions, earn points and help others
