Question about Health & Beauty
No life at all in classic 4wheeled mobility scooter
The batteries are fully charged but nothing else will work no lights on dashboard ignition no life
  • Dan Hudson May 11, 2010
    How do you know they are fully charged? The batteries should read 27 or more volts for the scooter to operate.
Have you checked your fuses with a continuity checker, they all my look OK, but Looks can fool you especially with the new type of two prong square colored fuses!
Posted on Nov 27, 2008
2013 EW36 ewheel scooter. Why doesn't it start?
I think the the fuse is under the head light cowling glass type 25 amp fuse. Your throttle, motor wiring, or controller maybe causing this problem.
Oct 24, 2015 | Electric Wheels Ew36 Mobility Scooter Red
My scooter will not fully charge
This could be the charger socket is worn and not making a good connection when charging or it could be the charger itself at fault. Now you have changed the batteries, I presume new and both the same type, you need to look at the charging side.
Apr 03, 2013 | Rascal 600 T Electric Scooter w Seat Lift...
Have 2 lights on charger. One power, the other says charging. Both come on but after about 15 mins the charging light goes off. Does this mean the battery is charged?
so no lights go green, it depends on the charger however in my experience all of the charger i have repaired have a green light to show fully charge, is it possible to try another charger ? this could imply a faultly charger , can you check the battery voltage anywhere from 26 volts DC to 28.3 volts DC no more otherwise you shorten the life of the battery. You really want the voltage level to be near 28 volts that way you will get maximum distance as well as prolonged life of the batteries in question.
Please leave feedback.
Dec 19, 2012 | Pride Mobility Products Go-Go Elite...
Battery is fully charged but when I turn ignition key nothing happens, on light does'nt come on and needle does'nt move battery level
Has the scooter been sitting unused for a while? If so, the gel inside the rechargeable batteries may have gone solid. When you connect the charger, the light shows green indicating the batteries are full, but instead of being full of power, they are full of crud. The scooter can sit for just a few weeks and this will happen. If the batteries are new or have been properly maintained, try checking your fuses and all the connections/leads as this certainly sounds like a power problem.
Oct 18, 2010 | Health & Beauty
Suspect the charger is shot on a seldom used like new Companion II. The batteries are at 3 volts but the charger red light wont illuminate when plugged in. Green light comes on, but not the red. I did see...
MStrong The charger will not charge batteries that are reading that low Replace the batteries and try the charger again. Remember to always charge before use and never charge longer than 12-16 hours. Get into the habit of charging overnite on scooters used everyday and once a week on seldomly used scooters always sore the scooter fully charged and if storing for a longer time remove the batteries and store fully charged. ope this helps you
Oct 03, 2010 | Golden Technologies Companion II Travel...
Battery full on Ascot Mobility scooter but wont start
mcdevito75 here, Double chek the connection at the battery and motor.
Jun 22, 2010 | Electric Strider Maxi 4 Wheel Mobility...
Lights work but scooter will not run
have you pressed the reset button .Also make sure the scooter is in drive before turning on the ignition. Another thing could be badly worn brushes on the motor or even a plug connector not fully home. The most common is not fully charged batteries. IF IT IS NONE OF THESE GET BACK TO ME PLEASE.
Jan 02, 2010 | Pride New Mobility Legend 4 Wheel Scooter
My invacare auriga 3 wheel scooter will not work got 2 new batteries but will not power light flashing on charger as if charging but when put key in not even lights comne on
Can you clarifly what happens you plug in the charger in ?
Are you sure the fuses on the battery leads are okay ? the is one for each battery like a glass container ? check they have not blown, check the connections to the battery , are they tight ?
Nov 14, 2009 | Pride New Mobility Legend 4 Wheel Scooter
Health & Beauty Logo
280 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
Are you a Health and Beauty Expert? Answer questions, earn points and help others
