TV shows only a thin horizontal light whenever i turn it on
Please Help!!!
My TV screen remains like it is still switched off whenever I switch it on, with the exception of a bright horizontal light across the middle of the screen.
It started about a week ago. it wasn't that serious at first. once in a while the picture would shrink a bit towards the center( making the picture look wide) and become darker. Picture would also become a bit shaky. It usually returned to normal after a while or when I hit the TV.
  • 4,234 Answers
Since hitting the set "fixed" it initially, the problem may have been poor connections. At this point it is likely that the vertical IC is now defective. Since you have not posted a make and model, I can not give you specific details, but look for a small flat IC attached to a heat sink with about 11 pins. Try resoldering the pins first. If that fails replace the IC. It should be marked LA7837 or something similar. Feel free to post the marking here and I'll confirm you have the correct part.
Keep us posted.
Dan
Posted on Nov 17, 2008
  • 67 Answers
There seems to be a problem with the vertical deflection ic or deflection yoke . try resoldering the vertical ic joints look for other loose solder joints around the vertical area on the circuitboard
TV screen screen's blank but it's on stand by. whenever using a remote it does not show anything.
Switch off TV manually, switch off power, remove plug and retry after 48 hours.If problem persists, please refer it to a qualified service technician.
Jul 25, 2012 | Televison & Video
1.My toshiba 32wlt66 has a display of thin light green colour line showing from the screen from the left end to the right end, very visible in dark pictures, 2. The TV power on by itself whenever I plug...
1. there is porblem with the lcd screen. if it is in warranty, have it replaced or repaired
2. some tvs save the last state it was in in case of power outages. taking it out of the power source will have the same effect. so turn off the tv before unplugging it.
hope the above answers your questions
thank you for visitng fixya.com
Jul 06, 2011 | Toshiba 32WLT66 32 in. LCD HDTV
Screen displaying a thin white very bright horizontal line.... plz help
problem in vertical section.
1. Solder the vertical ic
2. vertical ic supply capacitor problen.
3. dry points in neck board.
Aug 08, 2008 | LG Studioworks 45 14" CRT Monitor
WHARFEDALE LCD2610AF WHEN I TURN ON DIGITAL I HAVE PERFECT PICTURE &SOUND.AFTER 10 TO 30 MINUTES THE PICTURE FREEZES AND THEN SCREEN TURNS WHITE WITH AGREEN HORIZONTAL BAND LOWER HALF OF SCREEN.WHEN...
Hi.
If the picture & sound are ok in analogue mode then chances are you have problem with digital tuner.
This may be expensive to repair so I would advise connect external freeview box or sky etc to get digi channels using scart to connect to your TV.
Jul 16, 2008 | Televison & Video
Remove dry solder at Vertical IC if problem not solves replace VERTICAL IC and pf104
Darshan
Jul 05, 2008 | LG Studioworks 552V 15" CRT Monitor
Dell 1503FF flat panel monitor is blank
If you power switch does not light up. It possible that the Horizontal Output Transistor (HOT) is shorted.
Mar 31, 2008 | Gateway FPD2275W LCD Monitor
Sony Trinitron K29 inch CRT TV screen shows green shade!
i have the same problem with my sony trinton tv 36 inch if you know how to fix this please email me on amir.dhawan@gmail.com
Dec 30, 2007 | LG Flatron 295LM 22" LCD Monitor
Several dozen thin horizontal white lines across the top of screen, all channels
These beasts are monsters to get into and service without the proper extenstion cables and a service manual. there are no user replaceable parts inside this set. if you know solid state serviceing, you can try and fix it. There is a bad capacitor or capacitors in the vertical sweep circuit and or the vertical output IC is bad also. If you can solder and unsolder go for it. But if you do not or know how the circuit Works Please find a trained tech to assist you with this repair. Good Luck. PS please do not forget to rate this.
Oct 14, 2006 | RCA 27F500TDV 27 in. TV/VCR/DVD Combo
Hitachi 32CX39B
We need to know more details,Disconect the xbox and see if you get a full screen or the problem remains?,Please post a new question. Please dont rate this as a solution.
Oct 12, 2006 | Hitachi 32CX39B 32" TV
Televison & Video Logo
101 people viewed this question
Top Televison & Video Experts
