Question about Kenmore 23822 Top Load Washer
I have Kemore top load. Door switch needs to be replaced. How do I get to this switch? This is 9 years old
  • 367 Answers
You need to take the case off the washing machine. You can do this by taking the 2 screws out of the front corners of the control panel (Panel with timer). Then that panel will pull forward and flip back. Next there is 2 brass clips holding case on, you pop those out and then you are good to go. Change the lid switch.
Posted on Nov 17, 2008
Broken switch on Kenmore washing machine
If you are referring to the lid switch, you will need to remove the exterior washer case in order to access it. This is a lot easier than it sounds. The following link explains step-by-step how to access and replace a lid switch:
http://www.fixya.com/support/r3557193-replacing_a_lid_switch
If you have any questions, or if you are referring to a different switch, please post back and let me know. I hope you find this information helpful.
Mar 30, 2010 | Kenmore 24032\24036 Top Load Washer
How do I lift the top of a kemore 90 series washer
you don,t.unless its over 20 yrs old.the whole cabinet comes off.console folds up and away then 2 clips hold the cabinet to the frame
Jan 15, 2010 | Kenmore 24902 Top Load Washer
Kemore washer will not spin
Is your drain pump blocked?
The machine will not spin until the water is drained.
Some models have a small door at the front bottom of the machine. Open the door and unscrew the coin trap. There maybe some debris in there?
Also check the end of the drain hose where the water comes out. Sometimes the foreign material goes through and blocks at the end there.
Hope this helps!?
Jun 19, 2009 | Washing Machines
Door switch problem top loader
I fixed mine with a toothpick and a piece tape. Make the tab on the door longer that activates the switch. Try triming the lid bumpers
Apr 09, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Replace a damper door on a side by side
you havew to slid itm back from the front piece after you remove the two 1/4 inch screws that hold the piect in.
Apr 05, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
I have an electric wall-mount double Whirlpool self cleaning accubake oven. Can't fnd my manual, so I don't have the model number. It is 9 years old. Put on self clean feature, and it shorted out, and...
If you can see through a grill just above the door, then you might can see the lock linkage, and get something to push the linkage over (be sure to disconnect power first.).
If you can't, you'll need to pull the unit out from the cabinet and access it from the top.
The problem is often a thermal fuse in the top of the oven. But if you can provide more detail info on the oven, I can investigate further.
Jan 29, 2009 | Kitchen Ranges
Kenmore 23822 Top Load Washer Logo
32 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
