Small piece of paper stuck in machine - Office Equipment & Supplies
  • 3 more comments
  • rochelle709 Nov 17, 2008
    Paper is jammed in outgoing mode
    I do not understand
    You are not helping me at all
  • rochelle709 Nov 17, 2008 took my credit card info but I am not getting any help! I have a MP730 and paper is stuck in the outgoing mode,,what can I do?
    Very helpfuln thanks
  • 101 Answers
Use something small, pins for example to get the paper out of the machine and restart it.
Whats the model of your printer? brand also so I can give you better paper jam clearing instructions.
Thank you
Posted on Nov 17, 2008
  • 2 more comments
  • That is very helpful of you..
  • Can you tell me the brand and model of your printer so I can help you?
  • Remove foreign object from paper feed path
    If [CLEAR PAPER JAM] is displayed, follow this procedure to remove paper or obstructions from the interior.
    1. Press and hold for 1 second. Faxes in memory will be lost.
    2. Press .
    3. Lift up the scanning unit.
    4. Look in the print area for an obstruction (such as a paper clip, staple, tape, etc.) and then remove it.
    5. If no obstruction, look in the print area through the front of the machine and remove any obstructions.
    6. Close the scanning unit until it locks into place.
    7. Press to power the MultiPASS back on.
    8. Press .
    9. If printing from a Windows application, follow the instructions displayed on the computer monitor.
  • Thank you, let me know if you need anything else!
Repair of a Staples shredder EPS-1200X
Unplug it from the wall unit. Check to see if there is any tiny piece of paper stuck in the machine, if there is you can use
tweezers to pull the small pieces out. Then you can put it in reverse and let any paper that my be stuck in it come out.
Make sure that there is no paper caught in the teeth at all or it still might not work.
Jun 11, 2017 | Cars & Trucks
Ml-2160. How can I remove small pieces of paper from inside?
Generally paper is stuck either in the middle section or at the back near the fuser. Remove Toner cartridge and open rear door, if it's stuck coming out of the fuser, pull paper through from the back. Make sure to let the machine cool down first as the fuser is very hot. Remove any small pieces of paper from the front if before the fuser.
Jul 01, 2012 | Samsung Office Equipment & Supplies
How do I get the stuck paper out of a copy mashine?
You will need to take the machine appart. There are usually access pannels for all areas that paper go through for this exact reason.
Apr 13, 2012 | Office Equipment & Supplies
The machine keeps saying paper jam, there is no paper in there. I do not know how to clear it. I've pressed cancel numerous times.
Most likely there is a small piece of paper still stuck in the path somewhere. This happens often when you remove a jammed sheet. Sometimes a piece of it will rip off and remain stuck in the path. Try looking closely
Aug 25, 2010 | Office Equipment & Supplies
Paper jam, removed paper but still says jammed. Is there any way to tell where the jam is or reset machine ?
You should be able to have a piece of paper feed all the way without hanging.
Most of the times, you can see a small piece of paper stuck in a corner.
I have used a cut piece of plastic ( from a file folder ) and worked small pieces out that way.
Good luck, Happy Holiday's
Nov 30, 2009 | HP Officejet Pro L7590 All-in-One InkJet...
Reads "machine error af"
There is something wrong with the document feeder. Check if there are no pieces of paper stuck somewhere, and that any sensors are not stuck (sensors are usually small plastic pieces, that are lifted up when a sheet of paper moves below it).
Nov 07, 2009 | Brother MFC 9180 All-In-One Laser Printer
I had a paper jam. I removed the paper jam already but computer says it still there. How do I reset it?
It's possible there's still a small piece of paper or dust stuck in the paper feed. Try blowing the area out with compressed air.
Aug 31, 2009 | Brother IntelliFAX 2800 Laser Fax
Small piece of paper might be stuck somewhere.
bullet_s.gif If the paper tears and a piece remains inside the machine, turn the machine off, open the Scanning Unit (Printer Cover) and remove it.
Be careful not to touch the components inside the machine.
After removing all paper, close the Scanning Unit (Printer Cover), and turn it back on.
bullet_s.gif If you cannot pull the paper out, turn the machine off and turn it back on. The paper will be ejected automatically.
(2) Reload the paper in the machine, and press the OK button on the machine.
If you turned off the machine in step (1), all print jobs in queue are canceled. Reprint if necessary.
Apr 10, 2009 | Canon PIXMA MX310 All-In-One Printer
Showing paper jam but no paper in machine help!!!!
please confirm that all paper detecting switches are in normal position and can move freely and no small pieces of torn paper inside-clean all switches with dry cloths or brush.-reset your copier off-on-operation.
Jul 22, 2008 | Office Equipment & Supplies
Paper Jam/Kyocera C850/C850D
There will be a piece of paper stuck in there follow the instructions again opening every door on the left side. If there is not some paper the likely thing is that the paper sensor is jammed open or the light reflector sensor is dirty or the last thing is one of the sensors are faulty.
But I know these machines very well and the sensors rarely go faulty so I'm 98% sure there will be just a small piece of paper stuck in there. (It may be between the two doors or stuck behind a guide.
Oct 18, 2007 | Kyocera Mita (km-c850d) All-In-One Printer
16 people viewed this question
