Question about Dell Inspiron 1501 Notebook
Dell Inspiron E1705, Faint Black Screen on Battery Power
I have two batteries for my Dell E1705. The first is standard with laptop purchase. The second I purchased 1 1/2 years ago. While using the newer battery, my laptop screen went blank (black with barely visible screen). I can hear a poping/sizzling sound just before it happens. I close screen lid, reopen, log on and it work for a few minutes and repeats the same problem. This only happens when I'm on battery power, never when on AC power. I installed the original battery and get the same result. Additionaly, the left side of my screen steady dims within a few minutes of starting, battery or AC power.
  • Anonymous Mar 28, 2009
    I thought my laptop inspiron E1405 has the some problem. Is that prossible the chip on the motherboard has a problem cause the screen dark with battery power only. By the way, I put my new battery on the laptop, still it is not work.
  • Anonymous Mar 30, 2014
    power up after dead battery and got black screen and sounds like hdd only runs a few seconds??????
  • Dell Master
  • 4,806 Answers
The first thing i would do is do a bios update for the machine whilst using AC power, that may well iron the problem out, if not then there is a problem with the laptop itself i.e. a power drain, sizzling and popping noises is not good at all and could damage the machine further, remove the battery and check the connections on the laptop, dust and hair conduct electricity, it could be as simple as that, it is also a known fact that some lithium batteries are faulty and have been known to blow up whilst in use.
Go to the laptops support website to find out if they have been having problems with batteries and if there any returns proceedures
best regards
Posted on Nov 17, 2008
Can the Dell Inspiron E1705 be operated on household power without a battery in place?
Yes it can. Just remember that if the power cord comes off, then it will shut off immediately.
Apr 17, 2012 | Dell Inspiron E1705 Notebook
I purchased a battery from that said it was compatible with my inspiron 9400. It must be good because my computer will power on with it. I also purchased a new targus charger from Wal-mart which...
Return your power adapter to Walmart and replace. I'd suggest taking the laptop with you to further test in the store with the adapter you buy. Be certain that the new power adapter is compatible with the specific Dell Inspiron notebook series that you own.
Hope this helps.
Dec 24, 2010 | Dell Inspiron E1705 Notebook
Won't power on
Hi friends,
please check the dc adapter voltage,And battery also.
Ensure the adapter light is gong on, if ok condition, please measure the voltage.
Voltage will be E1705 DC Car Adapter (20V/6A 120Watts) check it.If not work please purchase from
For battery
Hope it will help you.
Dec 17, 2010 | Dell Inspiron E1705 Notebook
Dell inspiron e1705 did factory restore then screen went black now what do i do?
Since you did factory install, Might probably that's the recovery partition you used, Try to restart computer, if does not work, turn it off, unplug ac adapter and battery then drain residual power of laptop by pressing the power button for 5 secs, then put the ac adapter and battery again. If it still doesn't work, try to run diagnostics first if it fails then you'll need to replace a part, if it passes then you'll need to do operating system re-installation manually.
Feb 12, 2010 | Dell Inspiron E1705, Intel Core 2 Duo...
Dell Inspiron E1705 battery light flashes 4 amber lights, then 1 green. The battery seems to charge.
The ambar lights are warning you the battery is becoming to dead, it means in a short time, if it has not happens now, the battery won't retain the charge anymore, it is time thinking in a replacement if you use your laptop without plug in the power outlet.
Dec 29, 2009 | Dell Inspiron E1705 Notebook
Yes, it does, 'evidence' below.
Specs of the Dell Inspiron e1705 Being Reviewed:
  • Processor: Intel T2500 2.0GHz Core Duo
  • Motherboard Chipset: Intel Calistoga i945GM/PM
  • Hard Drive: 100GB 7200RPM SATA (Hitachi TraveStar)
  • Memory/RAM: 1GB (1,024MB) Dual Channel DDR2 SDRAM (667MHz)
  • Screen: 17.0" UXGA TrueLife (1900 x 1200 pixel resolution glossy screen)
  • Graphics: nVidia GeForce Go 7800 256MB
  • Optical Drive: DVD +/-RW with DL DVD+R write capacity
  • Battery: 9-cell (standard size 6-cell, 9-cell extended life optional)
  • Wireless: Intel PRO/Wireless 3945ABG (802.11 a/b/g)
  • User Input: Touchpad
  • Dimensions: 15.5" x 11.3" x 1.6" (Width x Depth x Height)
  • TV Tuner: Optional external USB TV Tuner with remote control upgrade for $104
  • Weight: 8.1 lbs
  • Ports:
    • 6 USB 2.0 ports
    • IEEE 1394 (FireWire)
    • Digital Video Interface (DVI-D)
    • VGA out (monitor out)
    • S-Video Out
    • RJ-45 (Ethernet LAN)
    • RJ-11 (56-Kbps Modem)
    • Audio line out for headphone/speakers
    • Microphone
  • Slots:
    • 5-in-1 Multi Card Reader (MS, MS Pro, SD, MMC, xD)
    • 1 ExpressCard 54 slot
  • Buttons:
    • Power on/off
    • Volume up/down/mute (3 buttons)
    • Media buttons (play, forward, back, stop)
    • Battery charge test button
    • Battery lock and release
May 03, 2009 | Dell Inspiron E1705 Notebook
Power indicator light blinking
it looks like the battery is defective. try reseat the battery while the power cord plug in to see if that help. if you remove the battery and leave the power cord plug in, the battery symbol indicator light will turn off. Time to order a replacement battery.
Nov 24, 2008 | Dell Inspiron E1705 Notebook
Problems with Dell Inspiron 6000 Battery ? DELL Inspiron 6000 laptop battery is popular, why ?
You can also pick up the batteries less expensive than most computer places at batteries plus. And yes it sounds as though it is the batteries charge is getting low, especially if it runs fine when the battery is out and you have it plugged in.
Mar 13, 2008 | Dell Inspiron 6000 Notebook
Dell Inspiron 1501 Notebook Logo
353 people viewed this question
Alun Cox
