Question about Vizio L30WGU 30 in. HD-Ready LCD Television
No power on my Visio 32 flat screen
The TV does not power up. I checked to see if I have 110 to the powerboard and I do. The visio light does not light up. The TV is a year oldand I can't find the reciept to get it covered under warranty. It slidoff of the small table that it was sitting on but did not hit thecarpet hard. I looked for loose wires and found none.
  • shawn98275 Dec 05, 2008
    I have a two year old Visio and it will not turn on . No lights, no picture.
  • toongirl02 Jan 06, 2009
    our 49 inch vizio does not light ou or turn on any suggestions. past the warranty it is 1 1/2 yrs old
  • 734 Answers
There is no reset button on these new sets,your set has complete power problem since you have no lights no clicks,this might have happen because of lightning or power surge,either one creates a lot of damage,if you are familiar with tv service you can check the main fuse,he should be close to where the power cord comes in,if you find the fuse blown it needs to be replaced with an exact replacement for AMPS rating and VOLTS rating as well as size,if the fuse is blown black we might have more problems ahead in the circuit and it will blow up again as sonn as you plug the tv back in,if it blows again it will need a more involved repair,the problem could be in the primary side of the power supply,if you are not too familiar you should seek the help of a servicer a least for an estimate but if you suspect power surge or lighting damage dont invest any more on this set and get a new one.
Posted on Dec 02, 2008
Just had the same problem with my Visio TV. Power light was blinking, but no picture or sound. Tech at Costco talked me through disconnecting the power supply and holding the power button for ONE MINUTE. I then tried to turn it on again, and still had the blinking light. After about 30 seconds, the light went out. When I turned the TV on again, IT WORKED!
Posted on May 29, 2011
T'Con board fault. Check and replace it. If you wish to get some details; check the site linked here. Pull up older posts.
Dec 09, 2016 | Vizio VW32L 32 in. LCD HDTV
VISIO E550i-B2
The main board of the tv is faulty. Can be a hardware fault or software error. You have to replace the mother board or can consult the service center.
of you wish to get some details about television repair then check the following link
Aug 18, 2016 | Televison & Video
Visio 1080p screen went light
Our Visio 42" flat screen TV did the same thing. It didn't happen that often but sometimes it would go darker or the sound would go off until I changed the channel or turned TV Off then back On. I contacted Visio through my warranty and they sent me a flash drive to install info on my TV. Did not fix the problems. A year later before warranty ended I contacted Visio again. They sent a huge box for me to pack my TV in to send to the warehouse where they fix everything. It took about 2 wks. to get it back. Worked fine for about 4 months and the problems continued. I will not buy another Visio TV. I found out that they had many problems with several models.
May 03, 2014 | Televison & Video
Our 42" visio flat screen, bought in 2007, is
Yes this can be fixed, it is probably caused by a some faulty capacitors either on the power supply board or the inverter board. Have a technician come out and check the capacitors in both of these circuits.
Sep 08, 2011 | Vizio 42 in. LCD TV
Visio model sv320svt will not turn on....visio logo in front flashes on and off..what could it be?
Hi after the logo flashes does it turn off completly or do you see the power light still on or any other lights?
Jun 02, 2011 | Vizio SV320XVT 32 in. TV
TV turns off by itself
Most likely your power supply is damaged (blown capacitor), if it's under warranty it's a quick half hour onsite fix.
Aug 10, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
Power light stays red and nothing comes on on my RCA L37WD12 Flat Screen what is the problem? I guess it's getting power because of the red power light, but TV is not turning on! Please HELP
I just had my Vizio which blew up and the power light stayed on and you could not turn it off on the tv you had to unplug it and then when you plug it back in same thing all over again, no picture at all , My TV made a loud pop before this happened, paid 1700 for TV and repairs were 900, bought new TV instead, never buy a Visio, there customer service totally sucks, you get a warranty and they try to screw you with an old piece of junk refurbished TV, they tried anyway, after 2 months they finally gave me my money back and I bought a totally awesome, SAMSUMG, THE WAY TO GO!! It sounds like the same deal and if it is a Visio just do a google search and see how many people it has happened to that own a visio..steve
Jun 13, 2009 | RCA L37WD12 37 in. LCD HDTV
Visio LCD TV - Partial Picture blacked.
Hello! I have a 32" Vizio LCD...within 30 minutes of the tv being turned on, black lines start running through the bottom half of the screen and eventually blacking out the bottom half of the tv screen. It also doesn't have anything to do with the ratio as I have tried that. HELP!
Jan 06, 2009 | Toshiba 42HP66 42 in. LCD Television
Visio TV and Direct TV remote
I bought a 42" Visio LCD from Costco and used code 10030 and it worked. It is the code for Goldstar TV.
Nov 17, 2007 | Televison & Video
Vizio L30WGU 30 in. HD-Ready LCD Television Logo
1,321 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
