Question about Briel Domus Due Espresso Machine & Coffee Maker
While making espreso, the machine leaks water from underneith.
My Briel Multi Pro-Serie EG 281 PG/ APG, (that's what it says on the operating instruction booklet).
While making Espresso, water leaks out from under the machine, and the pressure is lost. I have to push the start button many time to make a full cup. The MAIN problem is the leak. It leaks a LOT of water all over the kithen counter. Can you help me w/ this? How do I talk w/ someone? Do you have a phone #? Where can I take this to get serviced? I purchased this machine on 6/9/03. Please advise.
Thank you!
  • 37 Answers
Please email me with your request and I will send you info to fix it.
irene@smithagy.net
it is basically info on removing coffee oils from the Brew Head Screen.
if that does not work you can contact the service center at phone 201-439-1700 or email:
info@electra-craft.com
www.electra-craft.com
Thank you.
Posted on Nov 20, 2008
I have the briel multi pro EG 281 PG/APG. When I try make espresso, water comes from the frother and not from the brew head. Any suggestions on what the problem might be? Thanks!
sounds as though your brew head is clogged. when was the last time you descaled your machine? even if you've recently done it, it would not hurt it to do it again. descaling will eventually clean out the head and lines to the head and thus, your brew head should be despensing the coffee again. the reason it is having water coming from the frother is because under pressurization the water is shot into the areas that are open for releasing the pressure in the form of water. if one or the other outlets are clogged, then the next one available takes the pressure from it as it is re-routed to the only open source as your frother.
Feb 10, 2015 | Briel Coffee Makers & Espresso Machines
Coffee side died in my Briel ED271APG
well if the rest is okay then the wiring or the switch is suspect
Jul 07, 2010 | Briel ED271AP 10-Cup Multi-Pro Espresso /...
How do I use the Briel eg82, where do I get a manual?
Hi.
Briel is the Portuguese leader in building espreso machines and small appliances.
Briel had opened only recently to the international market. Their manuals are not available for download, and many models do not have an English manual available.
Check if a manual for Eg-82 is available by using this online form to contact Briel.
Regards.
Nov 17, 2009 | Briel Portofino EG-82 Espresso Machine
Water forced out around seal when making espresso.
1- Try cleaning the seal with a group brush if you do not have one you can get a hard toothbrush this will clean the coffee grounds on the seal, if the problem still occurs then the seal needs to be replaced.
Apr 26, 2009 | Briel Multi-Pro ES-200A Espresso Machine
Briel MultiPro Series The machine suddenly stopped heating. Everything works fine except that coffee comes out cold. There is no way to heat up water. Which part could be deffect?
Possibly bad heating element which is inside thermoblock. Can purchase for $75. Contact Fank at ElectraCraft Phone (201) 439-1700 to help you troubleshoot.
Mar 15, 2009 | Briel Multi-Pro ES-200A Espresso Machine
Lost User Manual
there should be one on the Briel USA website which is:
www.smithagy.net click Briel
If not, please email your request to:
irene@smithagy.net and it will be sent immediately.
Jun 18, 2008 | Briel Multi-Pro ES-200A Espresso Machine
Help!!!!
We believe what you call a"coffee holder" is in the language of the trade a called "portafilter" - this might make your search easier.
Now when you Google the model number and part name you moight get better data.
Ivans
Jun 15, 2008 | Briel Multi-Pro ES-200A Espresso Machine
Is Rancilio Silvia best for $400?
yes, you can get better quality from Rancilio silvia, if you try to get the maximum from it. i believe that in short tame you will be able to do it.
in the video she uses the machine but im not content about one detail, i give solution there.
video :
http://www.fixya.com/support/t422860-making_cappuccino_rancilio_silvia
May 26, 2008 | Briel ED271AP 10-Cup Multi-Pro Espresso /...
How do I contact the manufacturer?
Actually, the free video was discontinued some years ago, but you still purchase it along with any other part and technical assistance at;
Electra-Craft
41 Woodbine St
Bergenfield NJ 07621
phone 201-439-1700
fax 201-439-1701
Dec 01, 2007 | Briel Multi-Pro EG-281 Espresso Machine
Briel Multi-Pro Coffee / Espresso Maker
You have a leak in a connection or maybe the boiler. There is nothing you can do but find a repair shop to fix or replace the bad part.
Jul 30, 2007 | Briel ED271AP 10-Cup Multi-Pro Espresso /...
Briel Domus Due Espresso Machine & Coffee Maker Logo
214 people viewed this question
Top Briel Coffee Makers & Espresso Machines Experts
Dan Webster
Dan Webster
Dennis Fitzsimmons
Level 1 Expert
Are you a Briel Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
