Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Bad Convergence circuit board
I was told by my TV repairman that I could not get a convergence circuit board for my Mitsubishi's (model #V550805) 50 in. TV.
Is this true? Are there any rebuilt one's out there?
    Problem Solver:
  • 61 Answers
Rebuilt boards go to shopjimmy.com the have a lot of discontined boards
Posted on Nov 22, 2008
My Mitsubishi 1080HD model WS-55315 colors are not correct. The blue is good and the green seems to be, everything else seems to be a shade of light brown or tan. I thought maybe the red tube was bad but...
The tv have a problems known as a convergence pictures problems,it is dead.Tv have any colors lines like R,G,B mis alignments,also tv have any colors shaded shadows pictures or a 3D pictures look alike?Yes,than the tv have a convergence board problems and it is dead to causes all of these problems.The tv convergence board must have to repair like replacing 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence pictures problems.The tvs shops repair a DLP tv convergence board will cost u like $300-$350 for parts an labors.
Sep 12, 2011 | Mitsubishi WS-55315 55" Rear Projection...
Red and green doubled words on tv is this a bulb problem
No, it is convergence problem due to convergence output chips failure in rear projection tv.
Local tv repairman will fix it because it requires soldering work to replace bad chips in circuit board.
Thanks.
Mar 27, 2011 | Zenith R57W46 57" Rear Projection...
The picture has double images and looks kind of like it is 3D.
The tv have a problems known as a convergence problems,it dead.The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.The tv convergnece board,must have these parts changes on the tv convergence board to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Dec 31, 2010 | Panasonic PT-47WX49 47" Rear Projection...
Colors are seperated throughout screen. started in corners over a period of several weeks, and now colors are seperated by about 2 inches
u have bad convergence ic , for this repair i would recomend to hire a tv repair tech , this job require alot of soldering and aligments , $250 - 350
Nov 03, 2010 | Mitsubishi WS-55809 55" Rear Projection...
Red distorted color near top of screen not having much luck with trying to converge the lines on the tv set form. already tried factory reset
Reset will not cure a convergence problem.
this model (ws-65711) uses a single convergence chip located on the middle circuit board (see photo).
If convergence is skewed and will not adjust in customer menu the chip needs to be replaced.
Good news: I have start to finish, step by step instructions for this repair in this set. They tell you everything you will need and exactly how to do the repair.
No two sets with convergence problems will look exactly the same but I will also attach a few photos of this kind of trouble.
If the photos or what I have told you told you something you did not know and you want the instructions (free) rate this solution as very helpful as I do this here for free.
SD TECH
31e1a0a.jpg CONVERGENCE CHIP USED IN THIS MODEL.
3215424.jpgTYPICAL BOW FROM CONVERGENCE PROBLEM
ANOTHER SET WITH CONVERGENCE PROBLEMS
Sep 14, 2010 | Mitsubishi WS-65711 65" Rear Projection...
I was told by a repairman that my convergence module is bad on my ws 55511 or best buy model ws b55 was wondering what a convergence module cost. my power went off and when it came on the red images were...
Any shop with experience should be able to replace the convergence ICs which are the likely problem. This type of repair will cost less than the boaqrd replacment and won't require a conmplete reconvergence adjustment. The parts cost around $25-$40 each (there are 2).
I would look for someone that is able to change the ICs rather than the entire board.
Dan
Jun 22, 2010 | Mitsubishi WS-55511 55" Rear Projection...
Boe in blue dynamic convergence curcuitry. Swapped deflection yoke on two tubes but problem still remains. Unplugged convergence plug on yoke and bow disappeared but unable to adjust dynamic convergence....
what's the number of the board where you unplugged the conv yoke, should start with 930_ that is the board you need. Try the partstore.com with the part number or type in the brand and model when you have the number on the board, and they display price and availability.
Jan 15, 2010 | Mitsubishi VS-45609 TV
PCL5415R conv. board problem. Having trouble finding part number. I have the manual Samsung
I'll take a look if you want to forward them to me:
freetek@lycos.com
This convergence board problem seems to be very common and if they are not too model specific (firmware embedded) there may be service companies repairing them. I don't; haven't done a whole lot of service for years partially due to the difficulty of trying to pry stuff out of the hands (or shelves) of Asia.
Oct 13, 2008 | Samsung HCL5515W 55" Rear Projection...
Convergance circuit board
you don't need a convergence board the one you have could be fix the only problem is the alignment is not that easy and won't cost $ 500 unless you live in alaska and worth fixing it today you just get bad set made in chi???
Nov 25, 2007 | Sony KP-53HS30 53" Rear Projection...
My projection tv
never herd of a stabilizer sounds like your convergence amps are bad
Oct 29, 2007 | Mitsubishi WS-55807 TV
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
233 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
