Question about Maytag MAH6700AWW Neptune Front-Load Washer
Nepune not spinng
Washed a load of very muddy cloths clogged up the pump cleaned the pump and lines to pump again but still no spin
  • dabawr1 Nov 20, 2008
    idid all of that but the pump workes fine, when it comes time to spin it spins very slo and starts and stops repeatedly i did the quick spin test in the mini manuel that came with the machine ,but the display only showed "00" and the slow spin was all it did
  • swimdaily Nov 29, 2008
    Thanks for any help. My washer sticks on the spin cycle at exactly 8 minutes. Only ends when I turn the whole cycle off, then load's not properly spun. Is worse with heavy items. Nothing in instruction booklet to help on this. The "spin only" cycle also sticks at 8 minutes. If I run the machine empty, it works properly (!) Machine purchased new 12/05.
    Genius:
  • 1,028 Answers
Recheck pump and hoses something may hung in hose then broke loose and clogged pump again..also ck pump impeller it may have come loose from motor shaft
Posted on Nov 18, 2008
Will not spin
The drain line is probably clogged. Maybe that a sock or other piece of clothing get between the clothes tub and the outer tub that holds the water. In this case it may then get into the drain hose that's attached to the pump.Remove the hoses from the pump and pull the item out. In case it clean there, check the outer tub port- open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then,try to remove the clothing through the port.
Jul 10, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
My washer spins but doesnt spin on the final spin and leaves the clothes all soaked. it stops at 6 minutes on the final spin
is the machine draining correctly?
the machine will oftin stop if not doing so.
you can try cleaning out the coin trap/drain pump hose.
Jan 12, 2010 | Frigidaire Affinity ATF7000E Front Load...
Washer does not spin all of the water out
first check the lock light while spinng
if it wont lock it wont spin
if your lock light works
i would go in the back and clean out the pump, sump, and drain line
by the by 1 tablespoon of soap
to much can cause problems
Oct 09, 2009 | Maytag Neptune MAH5500B Front Load Washer
I have a top loading kenmore 70 series washer. It
Sep 13, 2009 | Bosch Axxis WFL 2060 Front Load Washer
My Kenmore series 90 washer wont drain completely. It washes fine and spins but when I take the clothes out they are soaked. I heard a high pitched squeaking noise breifly and then it stopped. Then it...
Hi
Check the drain line for kinks or obstructions. You can take a flashlight, remove the hose from the pump and look into the suction port of the pump. Check for anything clogging the pump. (like the occasional stray sock). Also check the pump impellers for broken or missing blades and ensure that the pump impeller spins freely. If any blades are broken/missing or if you cannot get the impeller to spin freely, the pump is defective and will need replaced. Hopefully it is just a clogged pump or drain line.There is the possibility that the pump is gone or going on it, or maybe a lint clog of some kind, or even a small sock or something. You can check the lines and re-install. Check around all the seals if a front loader to make sure the drain holes are not blocked.
Or try to unplug unit and let it sit for 1 minute and plug it back in. See if this will reset the unit.
Or sometimes it is from an uneven load. Towels with t shirts, not a good idea....1 t shirt....maybe......4 or more with a load of towels not so good. Without an even load, the balance is thrown off and the load will not spin properly, therefore, leaving water behind in the clothes.
Thanks for contacting fixya.com
Sep 10, 2009 | Kenmore Washing Machines
Clean clothes
The E20 code indicates a drain problem. Check the drain hose for kinks and obstructions. Next, remove the hoses from the pump and using a flashlight, look into the suction port on the pump. Look for anything clogging the pump (like the occasional stray sock) and check the pump impeller for broken/missing blades and make sure the impeller spins freely. If any blades are missing/broken or if you cannot get the impeller to spin freely the pump is defective. Hopefully it is just a clogged drain line or pump. Hope this helps and best wishes.
Aug 31, 2009 | Frigidaire ATF6000ES Front Load Washer
Washert not draining
If your washer spins but doesn't pump the water out, the drain line might be clogged.  In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump. You already have replaced the pump motor and still no operation,  so check the power voltage to the pump during the drain cycle.   Verify the problem is not pump related as much as power to the pump being the problem.
Mar 15, 2009 | Frigidaire FWS445RF
Help
check:
1. the drain hose is not kinked or trapped.
2. look in the manual and see if there is a filter which you should have checked and cleaned in the last '3/4 year'.
It's unlikely to have anything to do with loading-a common misconception is that you can overload machines. It's much more common to underload, which causes out-of-balance spinning and walkies around the kitchen.
love, phil.
Mar 29, 2008 | Washing Machines
Kenmore Elite HE4T Front Load Washer
These machines have a filter you should clean depending on your usage. It is usually at the front bottom - a small door. This is a filter before the water gets to your outlet pump to be siphoned out; it is there in order not to clog up your pump.
Jun 12, 2007 | Kenmore 44072 Front Load Washer
Kenmore Washing Machine doesn't rinse
The drain line is probably clogged. Maybe that a small sock or other piece of clothing get between the clothes tub and the outer tub that holds the water. Check as well that pump spins and clean from any clogged. Good luck!
Oct 08, 2006 | Kenmore 43042 Front Load Washer
Maytag MAH6700AWW Neptune Front-Load Washer Logo
67 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
