Question about Ricoh Aficio 450 Copier
AFICIO450 SC7260-00 ANY INFO ON ERROR SC726-00?
  • Ricoh Master
  • 2,794 Answers
Finisher shift/lift motor error. Could be caused be the tray or belt not being in the home position, a sensor, or a cable issue in the finisher section of the copier.
Posted on Nov 18, 2008
My black ink button on my pixma mp495 printer is blinking. Why?
A B LED light denotes that the black ink cartridge is running low.
A C LED light denotes that the colour ink cartridge is running low.
If the alarm light is on (lightning bolt in a triangle) it should be accompanied by an error code.
Canon MP495 - Error Codes If the printer displays an error message, the following information should help to diagnose the problem.
The led screen on the printer will flash a letter E and will then be followed by two numbers:
Error Description More Info Error E02 The machine is out of paper or will not feed. Error E03 Paper jam or output tray is closed. More Info Error E04 The Cartridge cannot be recognised. More Info Error E05 The Cartridge cannot be recognised. More Info Error E07 Cartridge is not installed in the correct position. More Info Error E08 Ink absorber is almost full. More Info Error E13 The remaining ink level cannot be detected. More Info Error E14 The Cartridge cannot be recognised. More Info Error E15 The Cartridge cannot be recognised. More Info Error E16 The ink has run out. More Info Error P02 Carriage encoder error. More Info Error P03 Line feed error. More Info Error P07 The waste ink absorber is full. More Info Error P08 Print head fault. More Info Error P10 Print head fault. More Info Error 5100 Carriage Encoder error. More Info Error 5200 Print head fault. More Info Error 6000 Line feed error. More Info Error B200 Print head fault. More Info Error 5B00 The waste ink absorber is full.
Feb 24, 2015 | Canon PIXMA MP495 InkJet Printer
Lanier 5635 Sorter
Under user tools, system settings make all prints, copies to come out in internal tray, the front and rear covers have to come off to remove screw 1 each side the SC code is shift tray motor error
Dec 18, 2013 | Lanier Office Equipment & Supplies
I can't logiin
Try again later. A system error occurred that wasn't your fault.
Apr 23, 2017 | GPS
What does 'SC726 Problem with finisher' mean on a ricoh aficio 2022
sc726 is a finisher lift motor error. The lift motor could be bad, or the sensor that detects where the motor is might be bad. It could also be an overload problem, if something is in the way preventing the shift tray from lifting.
Aug 12, 2011 | Ricoh Aficio 2022 All-In-One Laser Printer
I am getting an area R jam followed by SC726-00 service code. The paper is cleared but the machine won't run with the service code notification. Turning off and on again recycles through the R jam and...
SC726: Finisher Shift/Lift Motor Error
Definition [B']
1) Tray shift does not finish within a certain time after the shift motor turned on.
2) The stack height sensor does not activate within a certain time after the shift
tray lift motor turned on.
Possible Causes
• Shift motor defective
• Shift tray lift motor defective
This is a problem with the finisher shift motor normally.
Feb 21, 2011 | Ricoh Aficio 450 Copier
Flip Ultra is not recognized by FlipShare!
make sure all your computers drivers are up-to-date. If they are then make sure you have the latest service pack for your particular OS.
Dec 28, 2009 | Pure Digital Flip Mino Digital Camera
Error code sc726 savin copier 2545
SC726 indicates a finisher shift tray malfunction.
Nov 02, 2009 | Ricoh Aficio 1035 Copier
Ricoh Aficio 1045 error message SC726
Hi
Thanks for using FixYa. Error Code SC726 means the Finisher shift tray 1 lift motor error. You need to enter service mode and reset the unit by following the instructions given below.
To enter service mode (SP): Press the clear mode key then enter 1-0-7 hold down the c/s for three seconds. To enter the special service mode you’ll need to hold the # key down while pressing Copy SP. Exit service mode: by pressing exit twice. It will reset the and cycling the power.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Sep 24, 2009 | Ricoh Aficio 1035 Copier
We have a Ricoh Aficio350. The sorter was knocked into the wall. Now we are getting error code "SC726-00"
Hello sir; The easy way to reset is turn power off and on, otherwise follow the procedure to reset; press "clear mode" enter 107 then press "clear/stop" key for 3 second then turn power off and back on, if still don't work then you have to replace shift/lift motorin the finisher.
Aug 29, 2009 | Ricoh Aficio 2020D Copier
Aficio 1035 ps
Finisher 1 tray lift motor error.
It should be looked at by a technician to see if the sensor or motor needs to be replaced.
If you want to use the machine for now and bypass the error. Turn the power off on the copier. locate the finisher cable in the back of the machine. Pinch and release the cable and turn the power back on.
Jul 11, 2008 | Ricoh Aficio 1035 Copier
Ricoh Aficio 450 Copier Logo
148 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
