Question about Sharp Aquos LC-32D40U Television
Sharp television and panasonic cinema system with hdmi connection
I have just purchased a panasonic cinema system and a hdmi lead.
I already have a sharp flatscreen with a hdmi portal. however when connecting the hdmi cable with the cinema system to television we only receive sound from the scart leads - as when we take out the scart leads no sound is produced from cinema system.
The hdmi cable is connected in ext.5 however sound is only registering in ext 1 and 2. SkyTV is connected to ext 1.
How do i make the TV to recognise the extension 5 as sound?
  • 33 Answers
Ok, here's the deal. You can have sound being putout from hdmi coming from one of those sharp units, but it just depends on how you are connected. If you are using a digital audio output, from the tv, it wont push out the sound the way that it should. You will have to downgrade to using audio composite cables to connect to your external speaker system from the audio ouputs, not the digital audio outputs. Its not designed to push out sound from an hdmi cable. The BEST way to have this setup is to run your sound directly from the cinema to the external audio source(leaving the hdmi cable in the tv).
Posted on Dec 12, 2008
Panasonic home cinema connection issues
What other audio/video outputs does the TV have? Does it have an HDMI port? If so, connect TV to your home theater using HDMI to HDMI.
Jun 07, 2013 | Panasonic SC-BTT490 5.1 3D Home Theater...
Connecting Panasonic SC-PT550 to TX-L42E5B
I have a pansonic tv that i brougt last winter ,All you have to do to get audio from it is use a optical cable,
Nov 26, 2012 | Audio Players & Recorders
How to connect leads through home cinema system and virgin emdia box
Either use a good quality HDMI interconnect make sure that its gold plated check out this FixYa Tip here for further help
http://www.fixya.com/support/r4565785-1080i_1080p_cable_hdmi_version_need
Some home cinema systems still have a SCART lead instead of the HDMI the latter being the better option.
Dec 06, 2010 | Panasonic Televison & Video
Sony BDV 370 home cinema system and Sony 40hx703 television. The home cinema plays disks etc. through the cinema speakers. But will not play television sound through the cinema speakers it is connected...
You need to use a HDMI 1.4 Cable and it needs to be connected to to an HDMI socket with an ARC (audio return channel). Alternatively you can connect using an optical cable (TOSLINK).
Aug 29, 2010 | Sony BDVE300 Theater System
How do i connect my non hdmi xbox 360 to my panasonic scbt205ebk home cinema and panasonic 42v10 plasma so that the sound comes from the home cinema system. i also have sky hd
If you use a component system (1 yellow video wire, 1 red audio wire and 1 white audio wire)
You will have to connect the audio wires to your cinema system and the video directly to your set.
The unfortunate part of this is that when you want to use your system, you will have to change the input of the TV AND the Cinema system.
The same would be true if you wanted to use the DVD connectors (YBPBR). You would connect the video to the TV and the audio to the Panasonic unit.
The system you have is meant more for just playing DVD's and not a total cinema system. This is why there are limited (extremely limited) video inputs. The system is mostly for output of sound and of a the built in DVD video.
Aug 05, 2009 | Panasonic Televison & Video
Help with connecting home cinema to xbox
if your tv supports this. go to ebay type in "hdmi" buy one for around $10.00 plug into xbox. set your tv to which port you have ,(if you have more then one). bingo,bango ,your done.
"no hdmi"? and you have com. on your tv. plug corrosponding color plugs for component ,L&R audio plugs .
change tv to comp.( not video) your done
Jan 30, 2009 | Audio Players & Recorders
Samsung series 6 tv & Samsung 2:1 home theatre problems
if you got all the lead you should have fibre optics which connects from dvd to tv and then set your dvd to digi in. you should get the sound. i have same cinema system and i have done the same
Jan 13, 2009 | Samsung HT-X20 Home Cinema 600W Theater...
No sound through the Panasonic cinema surround sound on TV
Had a similar problem mate. I solved it by connecting the tv to the PT460 system with a scart lead. You then have to have the AV channel selected on the PT460 system to listen to the tv. You will always have to have the AV channel on the PT460 selected to listen to any sound transmitted through the tv - be it playstation/xbox or any other device that you may connect in the future with HDMI leads or otherwise. Hope this helps
Jan 04, 2009 | Panasonic Home Theater System System
PANASONIC HDMI PROBLEM....
tengo un panasonic tc-32lx70L y no coje los canales digitales a que se debe
Jun 29, 2008 | Audio Players & Recorders
Having just bought a Panasonic TX-37LZD80 television and a panasonic sc-pt460EB-K home cinema system, I connected the 2 together using a HDMI Cable and all works well except that I cannot get the sound...
When I purchased the television iI was told that I would only need a HDMI cable to connect the devices together, this is not true as the HDMI only provides 1 way transmission, to get the sound to go from the television back to the home cinema you need to use either a Phono Lead or Optical lead, plug them in and Hey Presto it works.
Jun 23, 2008 | Panasonic Televison & Video
Televison & Video Logo
502 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
