Question about Mitsubishi VS-55707 TV
Jumping screen on a mitsubishi vs-55707
I have a 54" mitsubishi VS-55707 projection tv and the screem is very jumpy and there are alot of line on the screen also the color is very dark how do i fix this problem?
  • 67 Answers
Check the high voltage leads on the multiplier flyback transformer for leakage
Posted on Nov 17, 2008
Purple static lines and a jumpy picture
Your picture tube is about to go.
If it's still under warranty,take it back.
Hope this helps.
Nov 26, 2013 | Mitsubishi VS-45607 45" Rear Projection...
Can i buy a new tv screen for mitsubishi vs-55707 tv
Yes, You can buy another screen for Your mitsubishi television, You can get it from any part dealer store, also, You can get it from someone whose television is having a different problem than a faulty screen. There are some television that develop other kinds of fault, therefore, they are moved to stores where they can be disassembled and sold in parts.
Hope this information helped. Thank You for using FixYa!!!
Jan 15, 2011 | Mitsubishi VS-55707 TV
Mitsubishi VS-60609 60 in. no pix /has sound
My Mitsubishi TV model VS 60609 is showing double vision on the screen.
Feb 24, 2009 | Mitsubishi VS-60609 60" Rear Projection...
Screen Jumpy on various Inputs
This unit had a very bad problem with the pip bord
Several caps have to be replaced on the board
I would have a tv repair shop do it for you
You have to remove surface mount caps and replace them which is hard to do
Feb 10, 2009 | Mitsubishi VS-55707 TV
Mitsubishi vs-55707 or vs-50707????? bouncing horizontal lines weird color
If the picture looks like a 3D then you have a convergence failure.
I would suggest to visually inspect the STK Ics for dry or crystallized solder joints.
IC8C01 - STK392-110
IC8C02 - STK392-110
Dec 11, 2008 | Televison & Video
Screen gets horizontal lines and jumpy screen.
Your problem is capacitors CP204 and CP205 by the 9 volt regulator on the main board. Cp204 is a 47 microfard @ 50 volt and the other is 100 microfard@ 16 volts
Nov 13, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Vs 7070 no blueuntilwarm and has dark picture
Might be it is worth the buy a new TV,but it is not worth the money to fix it. It is a serious problem!
solutiondoct
Nov 10, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Rolling screen
my screen on my mitsubishi won't stop rolling
Aug 22, 2008 | Mitsubishi VS-50607 50" Rear Projection...
Mitsubishi VS-45607 45" Big Screen
Good Day, Delano1981;
It may cure the problem but I would suspect the 9 Volt source
CHECK C2P05 100 UFD 16 V OFF PIN 3 OF IC2P01 AND
IC2P01 PART # 270P466020 (9-VOLT REGULATOR). BOTH
ARE ON THE SIGNAL PCB.
This should resolve your TV"s condition.
Good Luck, big IRISH.
May 27, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Vs 4561 weak picture
Good Day, Techwanab;
Look for this to be your problem: CHECK FOR OPEN L2C50 PART #325C146030 ON THE SIGNAL PCB, OR BAD CONNECTIONS AND LEAKY CAPS IN THAT AREA.
Hope this was helpful and not too late.
Apr 10, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Mitsubishi VS-55707 TV Logo
259 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
