Question about Kodak EASYSHARE 5100 All-In-One Printer
When I turn on printer green light display for a few seconds and then turns yellow and shuts itself off, however blavk ptint cartridge light still flashes red. When printer is trying to stay on and cover is opened cartridge head does not return to replace cartrdidge. there are no green lights on panel at all.
    Problem Solver:
  • 7 Answers
Yellow light indicates a "non recoverable error" try bypassing your surge suppressor and connect your printer to other ac outlet then try again if you still have a yel light contact support at 1 800 421 6699. If not try removing and reinstalling the printhead
Posted on Nov 18, 2008
P1102 reser counter
  • I take it you are refilling the toner cartridge...
  • Switch the printer off.
  • Press and hold the green button on your printer and turn the printer on. You will see that the lights flash for a moment and then turn off. After a few seconds, the attention light will turn on followed by ready light and the green light. Keep pressing the green button. In a few seconds, the attention light and the ready light will turn off.
  • Push the toner rotate button while you continue pressing the green button. As you briefly push the toner button, you will see the light flashing. Release both the toner button and the green button.
  • Repeatedly push the red button (cancel button). Now all the working lights on the printer will turn off.
  • Open and close the lid of HP printer once. The light will start blinking.
  • Press the green button. Your HP toner cartridge chip will be reset.
  • Apr 25, 2014 | HEWLETT-PACKARD Hewlett Packard P1102...
    Is not working more
    Jan 29, 2013 | HP DeskJet F4280 All In One Printer InkJet
    How to fix error code 5200 on canon printer MP258? what is 5200 mean?
    Here's the procedure. This code is normally encountered after refilling an ink cartridge and replacing the cartridge. Turn off printer. Hold down Stop/Reset button with one hand and turn printer on with other hand. After green light comes on for the ON button, press the Stop/Reset button two times and you should see the green light blink off and the orange alarm light blink "on" with the first press and then the green light comes back on for the power button and the orange light goes off with the second press (if you did it correctly). Now, you need to hold down the ON button about five seconds, then let go to shut OFF the printer. When you turn it back on, the printer should be back to the factory original condition. Make sure you set all your printer properties the way you want them again from your printer properties dialog boxes because some of the settings may have been stored in the printer's EEPROM, which you just reset to get rid of the offending alarm code.
    Feb 01, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
    Printer stops when printing should begin with red light in status
    There is a few reasons that cause the status light to turn red, paper jam, paper empty, toner cartridge empty, cover open and waste toner cartridge full. The PC Smart panel utility should give you an exact fault condition. Hope this helps.
    Jul 08, 2010 | Samsung CLP 300 Laser Printer
    Canon MP510 wont print. Error message B300 or
    May I know the exact error messages in the printer screen. If it's green and yellow lights that are flashing you need to push more the two cartridges that you replace....also try to clean it using the printer program installed in your computer....good luck and hope it will help....
    Mar 31, 2010 | Canon PIXMA MP510 All-In-One InkJet...
    The yellow light blinks and it won't print
    I also started having problems with my HP 870Cse when I began using refilled cartridges and had ink leakage (cartridge contacts corrupted). Check for this problem. If so, remove cartridges and gently clean the spillage. Then try using HP brand cartridges and see if this doesn't remedy the problem.
    Jan 21, 2009 | HP Deskjet 870cse Printer
    Keep getting 10.00.03 supplies error, have tried turning the machine off and on several times.
    10.00.03 - The printer cannot read or write to the yellow print cartridge memory tag.
    Solution:
    Turn the printer off and then back on again.
    If error returns, remove all print cartridges and turn off the printer.
    Cold reset the printer:
    Turn on the printer.
    Watch the control panel.
    When the memory starts counting, press and hold the green (Select) button.
    Continue holding the green check button until the Ready, Data, and Attention lights flash once, and then stay on steady.
    Release the check button when the Ready, Data, and Attention light are on steady.
    The control panel will display SELECT LANGUAGE.
    Press (Down Arrow) button once. The control panel will display COLD RESET.
    Press (Select). The printer will perform a cold reset and then continue its power-on sequence.
    Wait for the printer prompt to install each print cartridge.
    This should return the machine to operating condition. If you still get the error, replace the yellow print cartridge.
    Jan 15, 2009 | HP LaserJet 4600dn Color Printer
    Xerox 8200 will not boot
    If it takes a long time to cycle, then shuts down. I suspect the drum heaters are defective.
    Best way to find that out is, turn off yout room lights, then turn the machine on.
    There is a fan exaust on the right side of the printer where there are sloted openings.
    When you turn the machine, look in that fan slot and see if you see lights inside the printer. There should be a candesent type of glow you see about 20 seconds to a minute after you turn on the machine. Leave it on for a couple of minutes, but if you see no lights the heater or heaters are bad. They are standard 120 volt 150 watt halogen lamps. Tricky to change. But it can be done.
    Dec 28, 2007 | Xerox 8200/DP Thermal Printer
    Kodak EASYSHARE 5100 All-In-One Printer Logo
    102 people viewed this question
    Top Kodak Office Equipment & Supplies Experts
    Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
