Question about OKI MICROLINE 320 Turbo Matrix Printer
Form won't line up
Im trying to print a bill of lading, multiple copy form, it's 7 x 11 and I can't get it to line up. It will print one page fine but then the next page doesnt line up right
  • mkirkwood Nov 20, 2008
    I am having the same problem with a duplicate 3 1/2 X 8 form. I am using a Oki-data Microline 320 - 9 pin printer.
  • 162 Answers
Your feed assembly needs to be replaced, the gears wear out on them and the next thing you know, it's moving on it's own.
t
Posted on Nov 23, 2008
Preprinted 4 part paper crunching up when being printed in epson lq680 printer
Mustafa:
The printer is not meant to use multi-copy carbon invoices. The cause of your problem is the double-feed prevention pad below the paper pickup roller. When the first form is fed, the double feed prevention pad will stop multiple paper feeds. With multi-page carbons, the paper feed roller is trying to feed the form, and is pulling the top page of the form into the feed rollers while the double-feed prevention pad is stopping the bottom form from feeding and the top and bottom pages are sliding because of the carbon paper between the sheets. The only solution that I know of is to buy a printer with a tractor feed and pre-printed fan-fold forms with tractor feed strips on the sides of the forms.
Oct 13, 2012 | Epson LQ 680 Matrix Printer
The printer is used to print a Bill of Lading on a multipart form. It prints the entire BOL fine except for 1 field on the top/ right side that the invoice number prints in. It will print real small 1...
I would suspect the problem with the field at the top right of the page is being printed incorrectly because the printer receiving an escape command (control code) the printer either does not recognize or performs a wrong function on the 2280+.
If the printer was printing correctly and has suddenly started printing incorrectly it may be best to investigate what has changed ie have any of the following changed;
  • Printer driver or setup on the host computer system
  • Connectivity method
  • Printer settings may have been changed (check the emulation setting)
If the printer is a new setup and has not yet printed this document correctly it may be worth doing the follwing;
  1. If the printer is connected via the parallel interface (either directly to a computer system or via an external print server ) disable Cx-Bid
  2. If you know which driver or type of escape commands are used on the computer system ensure the emulation setting on the printer matches the host system.
  3. If you are not sure of the system setup perhaps try setting IBM for the emulation setting.
  4. If the above actions do not rectify the problem and you are able to select drivers etc on the host system ensure the 2280+ driver (or a compatible Epson or IBM driver is used ie either Epson LQ2550 or IBM ProPrinter XL24)
Further to this it may be nessesary to investigate the data file being recived by the pritner, by performing a hexdump to identify the cause of the problem and also identify a suitable soluion.
Mar 11, 2011 | TallyGenicom 2280 Matrix Printer
Will not print bottom of page im printing water bills 3 bills to page will not print bottom 4 lines of bottom bill
You must see the size of paper is the same of the indicated in the printer driver or program.
Feb 22, 2011 | Lexmark T 640 - printer - B/W - laser
Im trying to get it to print copies only blanks so far
You can make multiple copies by loading them print side up into the upper feeder you'd use to fax, then entering the number of copies on the keypad and hitt the copy button for color or black
or you may lift up the carriage and place a page on the scanner glass, close the carriage select the number of copies and hit the copy button for color or black
Oct 30, 2009 | HP OfficeJet 7410 All-In-One InkJet...
Default paper size for all the time
Hi Sabharish,
This setup works fine. But, if you run crystal report from application still is defaulting page size as Letter only.
Can you help me to solve this.
Thanks! Rajesh.
Oct 09, 2009 | Epson LX-300 Matrix Printer
Can't print continuous feed forms or labels without wasting paper
did you get this done.? I have the same problem, Lafayette,Indiana Realtor
Jun 24, 2009 | OKI Pacemark 3410 Matrix Printer
Everything I scan has two vertical lines and lots of horizontal
OK Im warning you before hand this is an old out of warranty printer for hp and there may be some hardware malfunction so i would request you to call hp at 18004746836 and simply ask for an upgrade but heres something that you can try for troubleshooting(copy and paste this link in the address bar of your web browser):
Number 1 troubleshooting Link
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00307511&cc=us&lc=en&dlc=en&product=428800
Number 2 troubleshooting Link
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00308545&jumpid=ot_recdoc/c00307511/en_us/c00308545/loc:1&custom_solutionid=rd_c00307511&lc=en&dlc=en&cc=us&product=428800
Lastly I hope your not using refilled cartridges cauz that causes the malfunctioning of the hardware of the printer
Jun 15, 2009 | HP PSC 1510 All-In-One InkJet Printer
Won't print multiple copies
If this is a WW10 II using the code and Q will increase the impression. If this dosen't help some WD40 on the front of the print solenoid may help.
DickyO
Jan 02, 2009 | Lexmark Wheelwriter 10 Series II...
C5280 won,t print
I had a problem with my C5280 installing another copy of itself when I restarted my computer. Check to see that you don't have multiple copies installed and are possibly trying to print to the wrong one.
Aug 28, 2008 | HP Photosmart C5280 Printer
Feed and Tear Off position problem
You can give this a try. This will alter the top of form setting.
http://www.profitmonster.com/printers/ml320tb.html
Let me know if this helps.
Mar 27, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
OKI MICROLINE 320 Turbo Matrix Printer Logo
190 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
