Question about HP Computers & Internet
My fan went out and laptop went down
I ran first recovery disc ok 2nd disc had error message image file is invalid or corrupted.
How do I proceed
  • eddie elliot Nov 18, 2008
    Thanks a bunch. I had a fear that it was the motherboard as well as the fan. Don't know whether to spend the money on this one or buy a new laptop. I love this one.
  • 93 Answers
Check/clean the 2nd disc if any finger print on it. or clean the laser unit for CD drive if you can and have correct clean liquid in your hand.
Or do Low-Level format your HDD before doing recovery.
If you still can't keep doing recovery after you have done all three steps above, there are some thing else wrong with your motherboard.
Posted on Nov 17, 2008
Packard bell zh7, had virus did reboot ,now has message which reads,The computer restarted unexpectedly or encountered an unexpected error.windows installation cannot proceed.To install windows,click ok to...
You are going to have to use the restore/recovery process to get past this. The virus corrupted a major file and now it wont boot. I hope you made backups.
Oct 28, 2013 | Packard Bell Computers & Internet
E-recovery stalls at about 40%
Sounds like a problem with your hard drive. The original hard drive installed is 40Gb. The message "destination: \\harddisk0\partition2" indicates that your single HD has been set to 2 partitions. Chances are that the recovery files are saved in your 2nd partition D. If your laptop came with a recovery CD, try using that instead of the eRecovery ALT/F10. Alternately, you may want to use an OEM XP Home Edition Installer and choose the 2nd "Repair" option.
If things don't work out, you may need to re-partition the HD and reinstall fresh/clean. Of course this would erase any and all contents of the drive. Should there be important files, you need to back them up but that would mean removing the HD and using an external enclosure, connect it as a removable storage to a 2nd PC using the USB and proceed to copy all your important files assuming of course that the 2nd PC will be able to read the HD in question.
If even on the 2nd PC you are having difficulty accessing the laptop's HD, try running utilities (ScanDisk) to check the HD's integrity. Possible problems are bad sectors, missing partition, corrupt files and the likes. If there are bad sectors, you may need to purchase a replacement.
Hope that this be of some help/idea. pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Dec 08, 2007 | Acer Aspire 3624WXCi Notebook
Toshiba Equium A210-171 bootmgr missing
HDD is damage.. however sometime cause by memory failure. try to clean memoryand insert it back. if not hdd is damage. you need software to recover your files.
Dec 24, 2012 | Computers & Internet
Dropped my laptop. It didn't shut down or anything it ran just fine. When I turned it on this morning it would not start and prompted me to do a system restore. Started that but it didn't complete because...
When you dropped it you will have caused the Hard drive arm to contact the surface of the hard drive, damaging it.
Unfortunatly, it looks like it damaged the Boot files, Its worth a try with the recovery disc, you may need a new hard drive if it fails with the recovery disc
Sep 05, 2010 | Gateway Computers & Internet
Error: 0XC000000C; What's the solution?
My 0xc000000c problem seemed to result from disk surface damage on the restore DVD. I burned a new copy of the restore DVD and the restore then proceeded normally.
Using a DVD copy program that provides an aggressive read method to extract data from damaged disks might help you the most.
Nov 08, 2009 | Acer Aspire 5100 Notebook
When starting computer it shows invalid system disc
I presume that recovery disc is for that computer... in that case check that the disc is spotlessly clean and also if i remember right that is a two disc set so make sure you are putting disc one in first
Robert
Jan 16, 2009 | Toshiba Satellite P30 P35 Series Notebook
Can't extract files on System Recovery Disc 4 for Compaq Presario model 6350US
At this point, you can try to clean your disk # 4 and see what happen,
or try to make a copy of disk # 4 (if you can copy the disk) and try again.
or
1) Contact your customer support and ask for a new set of disks.(or only # 4)
or
2) Boot your computer with another OS disk (win XP)
or
3) Boot your computer with some utility disk
Oct 19, 2008 | Gateway MX6421 Notebook
Recovery Error
Do recovery again, when it asks you to insert disc 2, take out disc one and close the tray. Do not put the disc 2 yet. If you can see the error message again, then it is a RAM issue. You need to reseat the Memory module and try to do the recovery again.
If you closed the tray then no error message came up, it would be an issue with your recovery disc and order for a new one. You can contact Toshiba to have the recovery replaced due to corrupt media.
Hope this helps.
Sep 12, 2008 | Toshiba Satellite A105 Notebook
Installing windows XP - Error encountered
Can you reboot and get into windows or is now corrupt?
What do you mean by 'uninstalled XP'??
You cant uninstall it unless you format the drive, in which case the recovery discs are now probably useless as they rely on a folder on the HDD called i386.
Recovery discs normally dont have the OS on them, they rely on the I386 folder to gather info about the computer and then restores it to the state when it was new.
If you can acess the system, reboot and go into the bios and change the boot sequence to CD, then insert the first recovery disc. then save the settings and the computer will reboot and start the recovery process again, this should clear up the error.
If it does not it will be because the i386 folder is missing in which case you can either explore the recovery discs for it or you will have to buy a copy of Windows XP.
Aug 11, 2008 | Toshiba A105-S4054 Notebook
Computers & Internet Logo
71 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
