Question about HP Officejet 5610 All-In-One InkJet Printer
WILL NOT PRINT COPY FROM COMPUTER TO PRINTER
WHEN I FIRST INSTALLED PRINTER IT DID WORK. THEN IT STARTED TO PRINT THREE ,FOUR ETC. COPIES AT A TIME THAT WERE STORED IN PRINTER. IT JUST KEPT MAKING COPIE OF OLD FILES I TRYED TO PRINT BEFORE. NOW IT JUST WOUN'T PRINT COPIES ..... AT ONE TIME IT MESSAGE CAME UP CAN'T FIND SERVER.....
  • 89 Answers
To me it sounds like you may have to uninstall the printer software then reinstall it make sure mark that printer as your default printer .
Posted on Nov 20, 2008
Will not print but it will scan and copy
Some times printer manufacturer provide print and scanner drivers separately, did you try to find "print driver"?
Or... some times when you plug your device prior to start installation agent, it do not work until... you re-connect your printer in to other USB port. Try it!
Aug 22, 2012 | Lexmark X4530 InkJet Printer
Blue Color On Copies
Check your settings for copying through your printer software.You might have accidentally messed up some copy settings there (Contrast, etc.)
Rollers do not have anything to do with this because your regular prints and copy prints are fed through the same roller.
Try removing your printer from Device Manager. Completely remove your printer software and reinstall all this stuff like you're installing a brand new printer. There is a 90% chance that your printer will be find after this.
Hope that helps.
Feb 19, 2010 | HP Officejet K60xi-Printer/Fax/Copy/Scan -...
Blank copies
You need to turn off "Print Separator Page" from printer setup/properties. This usually fixes it.
Feb 11, 2010 | HP Officejet 5610 All-In-One InkJet...
How to print a regular document from Microsoft Word, Excel.
Instead of pressing the start button to print, you need to press the small ON/OFF button. The start button works to copy/scan. But to print, you will need to turn the printer on first. Once the printer is on, the computer should recognize it fine and allow you to print from your applications.
Jul 13, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Printing page order
under print settings make you have "collate" option checked. There are different ways to find this depending on which operating system you are using.
May 26, 2009 | Brother HL 1440 Laser Printer
Hp Photosmart C4100 series (copy 6) printer missing!
Uninstall all those printers first. restart the computer and reinstall the drivers again.
May 25, 2009 | HP Deskjet F4180 All-in-One InkJet Printer
Hp scanjet will not copy to print
FROM HP, searched and found after three or four weeks of unresolved solutions .. and that's fixed the problem !!
Solution Follow the steps below:
  1. Click Start , then Printers and Faxes .
  2. Right-click the system default printer and click Properties .
  3. On the General tab, right-click the default printer and click Copy .
  4. Click Cancel to exit.
  5. Click Start and then click Run .
  6. In the Run dialog box, type regedit and click OK . WARNING: Using Registry Editor incorrectly can cause serious problems that may require you to reinstall your operating system. Hewlett-Packard cannot guarantee that problems resulting from the incorrect use of the Registry Editor can be solved. Use Registry Editor at your own risk. It is strongly recommended that you make a backup copy of the Registry before you edit it. For information about how to edit the Registry, view the "Changing Keys And Values" help topic in Registry Editor (Regedit.exe) or the "Add and Delete Information in the Registry" and "Edit Registry Data" help topics in Regedit32.exe.
  7. In the Registry Editor window, click Edit , then click Find... , and search for the following key: HKEY_CURRENT_USER\Software\Hewlett-Packard\DigitalImaging\hpfccopy .
  8. Double-click Printer in the right pane.
  9. In the Edit String window, paste the printer name as it appears in the Registry under Value data (for example, hp photosmart 8400 series) .
  10. Click OK and close the Registry Editor.
  11. Press Copy on the scanner. The default printer connected to the system should normally print the scanned document.
Cause This issue occurs when the default printer or the list of printers is not recognized on the hpfccopy function in the Current User section of the Registry.
Mar 28, 2008 | HP Scanjet 4370
Printer will not print- blank returns
make sure carts are placed well and secured.
press menu then start bk copy then four times arrow-up (tel. index). machine switches to maintenance mode. press 7 then 6 then 4 then start bk copy. machine will refresh ink in tubes and ph and do some cleaning. after that press 7 then 6 then 3 then start bk copy. machine will do a power purge. after that leave mode by pressing 9 then 9. Run a quality test print by pressing ink etc.
If you still cant see any colors the ph has dryed out. If you see some blocks try a manual cleaning (pressing ink shift to cleaning etc.). If the next test print out still is bad the ph is clogged due to generic ink and cant be cleaned anymore. In both way ph needs replacement.
Dec 08, 2007 | Brother MFC 420CN All-In-One InkJet...
Will Print, Won't Copy
Make sure the drivers have been loaded properly by uninstalling them and completely installing them again restarting the computer and printer several times.
Aug 01, 2007 | Dell 924 All-in-One InkJet Printer
HP Officejet 5610 All-In-One InkJet Printer Logo
mukhtar21 shaikh
mukhtar21 shaikh
