Question about KitchenAid KESC307 Electric Kitchen Range
Oven elements will not work
Broiler does not work, Oven does not work Oven light works.  As far as I can tell everything else on the stove works.  What could be the problem?
  • 833 Answers
Several possiblities:  If the burners work properly, it is not the power.  Then, move on to the element itself.  Most elements have a single screw or snap assembly which hold them in.  With the power off, remove the element and use a multimeter to see if the unit is conductive.  If it is damaged in any way, replace it.  If the connectors are corroded, clean them with fine sandpaper.  If the element is good, your switch is bad.  If the unit has a relay package running the element, it will likely be the cause.  You should be able to see this information from the diagram on the back of the unit.
Posted on Nov 20, 2008
My stove top works but oven and broiler will not heat
Good Afternoon friend, thanks for your post!
I see that your oven and broiler will not work on your Frigidaire range. It could be possible that your elements are bad or the thermostat may have shorted. I would suggest performing a reset on your range and you can do that by flipping the household circuit breaker off for roughly ten minutes. If that does not help resolve your issue you may need to have a professional technician come out to pinpoint the issue within your range. Best of luck! -Matt
Feb 16, 2015 | Frigidaire Stove / Oven / Range Glass...
Why won't my oven and broiler work after replacing the bake element in my Tappan tef361esd?
There are usually no fuses in the stove. Sometimes there is a thermal fuse but it is usually not tripped from a burned out element. the problem may be a burned contact in the oven control or thermostat or a burned wire. Sometimes the contact will burn when the elements burn out.
Sep 21, 2014 | Kitchen Ranges
Why would there be no heat from frigidair oven elements?
Make sure the oven timer is set properly, if its turned off, the oven will not go on. Also check if the oven has separate fuse, it may have blown.
Aug 24, 2014 | Frigidaire Stove/Oven/Range Black Glass...
Where are the fuses for the oven broiler on model # 9752834A
naps is asking oven element is not working or starting dosen't light up
Dec 07, 2009 | Stoves Ovens
Electric stove elements stopped working
Circuit breaker is tripped duel breaker 1 of them is tripped, maybe an electrical problem causing this.
Feb 20, 2009 | GE Kitchen Ranges
CPES389AC3 - Frigidaire Gallery Oven - Element and broiler
The element has blown in the oven you will need to fit a new one,and possibly the broiler one as well.
Plz rate this solution.Thanks.
Dec 20, 2008 | Frigidaire FEB30S5DC Electric Single Oven
MAYTAG STOVE PROBLEM...NEED HELP
the broiler came on automatically??? not a sensor issue. sounds as if you have a broken wire perhaps, or a faulty control panel energizing the broil element w/o being prompted to. does it say its broiling when element comes on??
Mar 05, 2008 | Kitchen Ranges
KitchenAid KESC307 Electric Kitchen Range Logo
123 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
