Question about Water Heaters
Boiler shuts down repeatidly
Hi, baxi 80e gets up to full temp then shuts down,temp drops to 40 degrees and it fires up again until temp reatches 80 degrees then shuts down again.this happens continuasly as long as boiler is turned on,this is also causing problem to downstair rads which are luke warm and upstairs are hot,i have just replaced the temp sensor and safety thermostat and have just put in a new pcb.has anyone else had this sort of problem that can give me some advice,any help or advice would be greatfully appreciated.
    Master:
  • 452 Answers
Sounds like ur circulating pump is giving up in the end of pump theirs a screw un do this and check that pump isn't seized up if its ok u will see it turning if not change pump, after u change pump test again if boiler starts to over heat again u will need to de scale heat-exchanger ,hope this helps ,any more probs give us a call Joe
Posted on Oct 12, 2013
    Problem Solver:
  • 17 Answers
I think you will find that instead of modulating as demand requires the boiler is overheating and then re operating after the safety thermostat has operated.
i wilud put some de scaler into the main heat exchanger circuit or add it to the radiators and let it circulate for a while.
also make sure the pump is operating properly to ensure proper water flow.
Posted on Nov 29, 2008
Hi my baxi 105he dhw has stopped heating the water flow rate is ok,when i try ch the temp led,s rapidly rise up to 80 degrees then the boiler shuts down
Indicates low water flow. possibly bad electrical connection to flow detector in dhw pipe or seized dector in pipe or blocked up heat exchanger. certainly a blockage somewhere in the pipes
Oct 11, 2017 | Water Water Heaters
Water pressure good, thermostat calling for heat boiler ignites , heats to 80, turns off, drops to 40 reignites - keeps this cycle going. temp sensor? return sensor? any help appreciated
the thermostat has an upper and lower setting at which point to turn the unit off and back on
most have a 10 degree variation between off and on so that a steady temp is maintained
check to see if the lower setting can be raised closer to the 80 degrees
if not consider a new thermostat with closer settings
Feb 13, 2016 | Water Water Heaters
Vailant ecotec plus 837 - Water pressure and temp is too high
Pressure inside the tank will rise along with the water temperature. As the water inside cools the pressure will wane until the heating element turns on and reheats the water with a subsequent rise in pressure. Running the hot water at the same time will draw heat energy from the boiler and lower the internal temp and pressure as well.
Jan 21, 2014 | Water Heaters
My boiler(baxi luna HT330) keeps going into E1 fault mode.
After you pressure system do you bleed the rads then top up again .
Jul 19, 2017 | Water Heaters
Modena 80e starts up itself
doe's your blr have pre heat option if so it would be normal for it to fire up then go off
Jul 29, 2009 | Protech Systems FasNSeal FSWMKE4 4" Vent...
Boiler coming on,on its own
Sounds likely. But check the timer selector switching [on/off/24hrs] & if you have a room thermostat wired in
Jun 13, 2009 | Protech Systems FasNSeal FSWMKE4 4" Vent...
I need a protherm 80e manual, any idea where I can download one from? The baxi site does not do support manual downloads. :(
This is the manual for 80E. It isn't a manual for the 80e, it's a manual for the 80E, dunno if they are the same or not.
http://www.protherm.cz/upload/1117176168.pdf
If that's is not it, you can browse here =>
http://www.protherm.cz/component.php?cocode=download&dcid=4
Dec 30, 2008 | Protech Systems FasNSeal FSWMKE4 4" Vent...
Water Heaters Logo
740 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
