Question about Westinghouse 24 in. MDP531 RF Free-standing Dishwasher
Door springs broke
Have frigidaire dishwasher and the door just falls down i am not sure how to change them
  • 258 Answers
I have just changed mine and posted the solution with pictures here http://www.howtofixanything.co.uk/howto-260.html
Posted on Mar 08, 2009
How do i fix a broken spring on a dishwasher door
You will need to pull the dishwasher out about 12" to 18" to be able to get to the springs & rope links. Many dishwashers use a "rope link" to connect between the spring and the door hinge; and in others, the door springs connect directly to the door hinges. Once you pull the dishwasher out, you will easily see what broke and what you need to fixe it.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Jan 20, 2015 | Frigidaire Dishwashers
Problem with door falling open too far
Hello friend, thank you for your post!
I understand that your Frigidaire dishwasher door is falling open too far. It could be a potential issue with your hinges or door. I would highly recommend reaching out to a professional for further assistance in properly diagnosing the issue with the door. If you have any further problems please feel free to reconnect. -Matt
Oct 05, 2014 | Frigidaire Dishwashers
Door spring rope broke on door , door falls when opened like to fix it need part and diagram of unit
http://www.bosch-eshop.com - enter the correct model number: SHE43P05UC in the search box on the right side, select which dishwasher you have from the results list. Click on the number of the part you need, it should show the manuf. par number on bottom.
or go to http://www.searspartsdirect.com and check there.
Once you get the manufacturer's part numbers - go to http://www.repairclinic.com - they have pictures of most parts.
Vlad,
First Choice Appliance, Sacramento
Jul 06, 2012 | Bosch Dishwashers
Front door opens too fast. it just drops. should there be a spring attached to the door?
If I remember correctly, there should be a spring underneath that regulates the door from just falling down. It has been a while, but here is what I remember. Take off the floor plate then the bottom cover. Usually two screws hold each (either 1/4", phillips, or 5/16" (8mm), depending on model). You can see under the unit from there. It should be a coil spring. If the loop has slipped off the door bracket, then just rehook it. If the loop has broken off, us some needle nose pliers and make the next coil a new loop. This is how it used to be done on older dishwashers, but haven't done any new ones.
Hope this helps
Jan 21, 2011 | Frigidaire Dishwashers
Apparently the springs on my door are either not connected or they need to be adjusted. If I were to open the door and not hold it with my hands, it would immedaitely fall wide open. No tension exists on...
I had the same problem on my Dishwasher . There should be 2 screws underneath the top front part of the dishwasher. They hold the unit in place. Easy to get to. Open the door and look up. Pull out the 2 screws that are screwed into the underneath of the front cabinet.
This should allow you to pull (slide) out the unit just enough to see the springs ( aprox 1 ft ) on both sides on the bottom of unit. Inspect the springs. Mine had broke on one side where it clips into the holder.
I just inserted the spring in the proper tension hole to match the other side . I spun it around 1 turn as to hold it in place and then connected the top of spring it its proper place. This gave equal tension on both springs and the door works fine now.
Eventually I will buy a new spring and replace it but at least it works fine for now.
If even one spring has been disconnected the door will fall with out any tension what so ever. I'm guessing maybe just one spring has either come out or broke where it clips into the hole.
Aug 30, 2010 | Frigidaire FDB520RHS Full Console...
My dishwasher door just falls straight down.
There are some cables that connect the door to the springs, the most likely suspect is that one of the cables has broke, The link below has information on the parts needed to make the repair. Let me know if it is helpful.
http://www.fixya.com/support/r4675991-door_sqeaking_or_falling_down
May 11, 2010 | KitchenAid 24 in. KUDP01FL Built-in...
Have problem with door on Frigidaire Electolux dishwasher. Door "falls open" rather than eases open.
there is a spring that connects to the side of the door (both right and left) than connects to the holes on the bottom of the dishwasher frame. These springs have either fallen off or broken. To see the area where they connect you will need to remove the very bottom panels below the door. Look at the frame where the leg height adjustment screws are and you will see several holes in the frame the springs will most likely be right there and just need to be reconnected to the frame itself. If the springs are not there then the springs will more than likely be right at the bottom left and right side of the doors. These springs should be set in the 3rd hole back from the front if the door drop is still too fast set the spring further back on the frame.
Hope this helped
Dave
Feb 04, 2010 | Electrolux Frigidaire Professional Series...
The door to the dishwasher is very hard to close. The door also falls down to the floor which makes the carriage/basket fall down as well.
sounds like one or both of your door links are broken check your hinges. you should ahave a large spring and a piece of rope that attaches to the door. let me know if this helps you
Jan 05, 2010 | Frigidaire PLD2855RFC Dishwasher
Mdb7601aws dishwasher door drops down
hi there,
go to www.whirlpoolparts.ca to get the exploded view for your model #. it will be the located under Repair Parts.
May 31, 2008 | Maytag 24 in. MDB7600A Jetclean® II...
Dishwashers Logo
167 people viewed this question
Top Westinghouse Dishwashers Experts
 Paul
Paul
Level 1 Expert
richie46
Are you a Westinghouse Dishwasher Expert? Answer questions, earn points and help others
