Question about Olympus DS-2 Digital Voice Recorder
I don't know how to erase the recorded data on my DS-2 recorder.
I lost my instruction book and now I don't remember how to erase the meeting information I have on several of my recordings. Please help me.
  • Anonymous Mar 25, 2014
    I recorded data in a meeting in an attempt to upload in pc it was gone. Replaced by data deleted months ago
  • 145 Answers
Select the file, then press erase and follow the display. If you hold down erase, you should get an erase all option. Also you can select Format in the menu.
Posted on Nov 18, 2008
How to recover erased file from panasonic digital recorder
Hi, there
First things first: DO NOT take any more videos or audio with the recorder that you want to recover files from in case you may quite possibly ruin your chances of voice memo file recovery.
Then connect your recorder to a PC with a recovery program installed. Photo Recovery Software (also recover Voice memos, audio and video files) is right what you need to use if you are running Windows. If you are Mac OS X users, turn to Data Recovery for Mac.
But you should remember - the more you use your recorder, the less likely you may be able to recover the deleted files back! So STOP using the device ASAP. Best regards!
Dec 04, 2010 | Panasonic RR-US500
How can I format? I lost the intenal files
Hello Press the FOLDER button to choose a folder
Press and hold ERASE button for 3 seconds or longer.
The ERASE indicator will flashes
Press the ERASE button again.
Done blinks for two seconds and the deletion will be complete
Note AN erased file cannot be restored.
During this process don’t remove batteries. Otherwise data may be damage.
The recorder should be formatted using only by using the internal FORMAT function found in the recorder's Menu. Formatting using the computer may corrupt system files needed to run the recorder, so computer formatting is not recommended
Apr 23, 2010 | Olympus WS-100 Digital Voice Recorder
On my Olympus DS-2, although I have erased all my files the recorder shows that that there is little or no room for recording. This is the first time this has happened to me.
The amount of room available on the Olympus DS2 are determined by two things:
1. Avaiable Memory
2. Recording Mode
With that said, if you have formatted (erased) the files on the recorder and there is little recording room left, you will need to change your recording mode. I would recommend changing it to SP mode.
I hope this helps.
Feb 26, 2010 | Olympus DS-2 Digital Voice Recorder
Lost my DS-40 audio files after upload. Can I recover them?
you can use card recovery software that helped me before
1. Do not save any new file to memory card.
2. Connect your card to computer. You should see memory card shown as a drive letter (like H:) in My Computer.
3. Download recovery software, recommended one is this photo recovery (simply because i was using it and it worked)
http://www.asoftech.com/adr/
4. Install and open the data recovery program, select your memory drive, and click 'Next' button to start scanning process which will find your deleted files.
Sep 08, 2009 | Olympus DS-40 Digital Voice Recorder
Recovering deleted files from olympus VN-4100PC voice recorder
Chances are there to recover such kind of deleted files from your Olympus recorder.
Then connect your device to a PC, and have a try of Photo Recovery (also recover audio, voice memos, video files etc), a data recovery program which is good at recovering media files lost. If you are Mac OS X users, turn to Data Recovery for Mac.
Lastly, I hope you good luck. Again you should remember - the more you use your recorder, the less likely you may be able to recover the deleted files back! So STOP using the device ASAP.
Jan 21, 2009 | Olympus DS-30 Digital Voice Recorder
Olympus ds-30 deleted file recovery
Lastly, I hope you good luck. Again you should remember - the more you use your recorder, the less likely you may be able to recover the deleted files back! So STOP using the device ASAP. Regards
Nov 26, 2008 | Olympus DS-30 Digital Voice Recorder
Problems with memory on Olympus DS-2
I've had the same issue. The surefire solution is to go into the Sub Menu and FORMAT. It wipes the entire internal memory clean -- so be sure you've offloaded everything you need. You'll also need to reset the recording quality, if you have a custom setting, because it defaults to the highest quality. But you'll have all your space back.
I believe when files are deleted via computer, the DS-2 doesn't update itself to recognize the space is freed up. That's why data is gone but memory is not freed.  Good luck.
Mar 07, 2008 | Olympus DS-2 Digital Voice Recorder
OLYMPUS DS-330 Drivers
Hi Aklas.
Olympus DS-330 voice recorder drivers (xp/vista/win7/win8/mac) can be found at driverupdate us
It will take 2 mins from you to install...
I hope I have helped you...
enjoy
Nov 05, 2007 | Olympus DS-150 Digital Voice Recorder
Olympus DS-50
No, you can't do this on the Olympus DS-50 , its not a dictation machine, you can do this only by Olympus DS-2300, DS-3300, & DS-4000 which they have the Editing Features : Insert,Overwrite, eraseing and Partial erase
Oct 26, 2007 | Olympus DS-50 Digital Voice Recorder
Voice recorder 5007A
press the erase button, it should flash delete at you, if you let it do that to long it will go back to the way it was before you hit the erase button. to delete, hit erase on the folder you want then hit erase and hold it untill it deletes the file. continue this proccess untill all files are deleted
Jun 17, 2007 | RCA RP5007 Handheld Digital Voice Recorder
Olympus DS-2 Digital Voice Recorder Logo
167 people viewed this question
Top Olympus Audio Players & Recorders Experts
Are you an Olympus Audio Player and Recorder Expert? Answer questions, earn points and help others
