Question about Frigidaire 12 cu. ft. / 340 liter Upright Freezer FFU12C2A
Sqeak noise, not all the time, comes from top of reezer
Where is the unit located in this freezdr
    Sergeant:
    Champion:
  • 311 Answers
Fan inside needs to be replaced. Behind metal cover inside. I cannot see your repyl due to some tech issue w/ the site, so it may be a day or so before I can reply again. Please leave feedback for me if appropriate. Thanks
Posted on Nov 28, 2008
Danby DFF282WDB stopped cooling - light comes on - any troubleshooting we can do?
Hello;
My name is Peter. I am a retired field service refrigeration technician.
You are locked into the defrost mode. This is when every 8-10 hours your unit will shut down for 20-30 minutes and your defrost heater comes on and defrost your freezer cooling (Evaporator) Coil. During this cycle everything shuts down except for the light.
Your controls are usually located on the top of your fresh food section. On the bottom of your controls, near the front, left hand side there is a round hole. This is where your defrost timer is located.
With a large flat head screw driver turn clockwise. You will hear a clicking sound. Turn slowly one click a time until your unit turns on. This unit will have to be replaced. Until it is replace manually turn it off every 10 hours for 20 minutes.
Note the round stub on the left.
Feb 23, 2015 | Danby DFF282WDB 10.0 cu. ft. Freestanding...
There is a light in my freezer. but, it doesn't get cold
Hello;
You are locked into the defrost mode. This is where every 8-10 hours your unit will completely shut down except for the lights. At this time your defrost heater turns on for 20-30 minutes to defrost the evaporator (Cooling) coils in your freezer.
You can manually turn your unit back on, until you get a new defrost timer. If you have a up right freezer your defrost timer is in the lower back. It is mounted on a metal plate.
With a flat head screw driver turn the stem slowly one click at a time until your unit turns on. Once a day repeat this process to put your unit back into defrost until the timer is replaced.
If you have a top freezer the defrost timer is located on the top of the fresh food section on the left. Do the same thing. The cost of the timer is about $30.00.
Send me your model number located on the side front wall of your fresh food section and I will proved you with the part number and walk you through the repair.
Feb 19, 2015 | Freezers
My freezer 6151 has build up ice on top of the unit. please help?
start by verifying that the defrost time clock works. Located in the top of the unit. Let me know if we need to go any farther.
Oct 07, 2010 | Delfield Freezer 6151XLSR Stainless steel
Freezer model FCF88W when started up for the first time it sounded like it was gurgling. It gave the impression that water was running Setting is on number 4 for initial start up and the unit got up to...
well i hope when you got this unit and put it in the place were its going to live in for its life you let it stand for a good fuw hours before you powerd it up??? thay need to stand to let the compresor oil and freezer gas find there way to the bottom of the unit,,,if not,,,well naughty you!!! smack your legs!!
but dont worry about the noise its normal for it to gurgle,,,,its the freezer gas being pumped around the unit,, if its freezing its working ok,,and not that it is you can run it at were ever you like,,,up to flat out if you wont to make ice sheets for mountains????
and by the way some times mine sounds like a very hungry hippo,,,especilally in the middle of the night,,, and it keeps me awake!!!
Jun 27, 2010 | Franklin Freezer Chef FIM70 Commercial Ice...
MY HOTPOINT FFA52 FRIDGE FREEZER HAS MADE A LOUD BUZZING NOISE A COUPLE OF TIMES BUT IT APPEARS TO BE WORKING OK. AT FIRST I THOUGHT THE BUZZING WAS COMING FROM THE TOP NEAR THE THERMOSTAT UNIT BUT I,M NOT...
If you can pull the unit out from the wall, find the motor compartment. There, you'll find a black can with the motor and compressor inside it. This usually creates vibration when running. Check the compressor's mounts, to see if they need tightening or have rubber grommets that have rotted away. The sound could also be coming from a fan somewhere in the machine. There might be a fan in the motor compartment. Find the vents inside the unit that blow cold air. Check the guards to see if a foreign object could have made its way into the vents and jammed a fan. Make sure you unplug the fridge before you stick any hands or tools someplace they wouldn't normally go. You may want to let the unit run while peeking in with a flashlight to locate the source of the vibration, but beware of moving parts and a shock hazard.
Apr 03, 2010 | Freezers
I hear a popping/clicking type noise from the freezer and I don't think the fan is coming on. It doesn't have an ice maker. The contents are still frozen each day, but I notice a thin layer of frost on...
if temps are still good, with settings at normal, that popping noise you hear is likely the resulting temperature change when the defrost heater comes on. when its in defrost, you may hear the clicking of the defrost timer, which you wouldnt normally hear when the unit runs.
You say there is a thin layer of frost on certain items, where are these items located in your freezer? are they near the top, the bottom, the back, the front, combination thereof? Are you having any problems with the door not closing well? check your door gaskets, are there any tears, rips or gaps. if you place a dollar bill between gasket and frame, does the bill move, ON ITS OWN. Of course you will be able to move the bill, but if you close the door on the bill and it falls out or shifts position by itself, you have a seal problem. Do you have too much food inside the unit? If you only noticed the frost recently, perhaps you cleaned it out and something is obstructing door from closing completely, on its own. Or if you went shopping, perhaps you bought just a little too much food. check the bottom drawer if yours has one, is it pushed all the way in?
Mar 24, 2010 | Freezers
It makes a very loud noise most of the time
First determine if the noise is from inside or outside of the freezer. If it is louder inside, and you have a frost free freezer, it is usally your evaporator fan motor. If the noise is behind and underneath you unit, then you need to pull the backing plate off, if it has one and determine if the noise is coming from the condensor fan motor, ( if it has one), or from the compressor itself. It usually is compressor and is definitely not worth repairing unless it is under a 5 year sealed system warrantee. Good Luck
Dec 10, 2009 | Hoover Freezers
Brand new unit, compressor noise.
Since I could get no one to tell me about new freezer compressor making buzzing noise while on, I had the store come a pick it up and give me my money back.
Apr 28, 2009 | Frigidaire 12.8 cu. ft. Chest Freezer...
I just bought a frigidaire upright freezer a week ago. I can't get a repair person to come look at it until monday. The freezer is cold on the bottom and warm at the top. I put water on the center tray and...
Since this is a new freezer it should be serviced by the people who sold it to you in order to avoid any warranty conflict. The fan blades of these units are of a slip fit onto the motor shaft. It is possible that the fan blade has come off the motor shaft.
Nov 28, 2008 | Frigidaire 20 cu. ft. / 566 liter Upright...
Freezer making noise & left side of the freezer (on outside is very warm to touch)
Sounds like the freezer evapurator fan... they make noise on and off at times when bears are wore... Thats about the only thing that can make noise inthe area ur talking about.. if noise comes back listen where the freezer fan is.. is most liklly the problem
Nov 02, 2007 | Freezers
Frigidaire 12 cu. ft. / 340 liter Upright Freezer FFU12C2A Logo
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
John Tripp
John Tripp
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
