Question about Microsoft Xbox 360 Console
Error code 0013
Hi, my xbox360 has the error code 0013 it is said here that it means "over heating" so i had left my xbox360 rest for about 3 days and i know that it has cooled down enough and it still shows the same thing with the same error code can someone help me. Thank you =)
  • Anonymous Apr 23, 2009
    i got 2 flashig red lights i cleaned it an everything an it still show so if anybody knows somebody help
  • 101 Answers
Take your metal case, and drill holes big enough to fit 5m diameter x 16mm tall screws. Put them all up through the holes and add 4 steel washers to each post. then add 1 nylon washer. >>>make sure you do the penny fix before you place your motherboard inside the case<<< Place your motherboard inside of the case ( you can use tape on the back side of the metal case to hold screws in place; may want to do that before you add washers) add 1 nylon washer then 1 steel washer to each. Take off microsoft's bolts from the heat sinks and re-apply a ssmmmallll amount of thermal paste (size of a piece of rice for the big ones). Attach everything and you will be good to go.
Take 2 pennys, wrap them one way with electrical tape, then turn 90 degrees and wrap them again so no copper is showing. >>You will need 4 sets of 2 pennys<< Flip your motherboard over and peal off the white things with band-aid looking squares on top of them. Peal the band-aid looking squares off and apply your tape-wrapped pennys.
Note: If you do not have these puddy-looking things on your ram chips, Use some hot glue, not a lot though.
You may also need to "bake" your 360. When you are all said and done with applying and bolting things. Take your 360 and put everything in except the fan. Take the fan plug it in its spot, then lay it diagonally from its plug, ontop of the tall cpu heatsink. Turn your xbox on for about 15 minutes. Let it over heat good so it can reset itself flat. Turn if off and let it cool down for about 20 minutes. Put everything back together and enjoy your console as your paid for it! error code 0013 - smile.gif
Posted on Aug 21, 2009
Fix code 3141 3151 b200 0700 c000 0013 help me fix please .
Did you download the 12625 update from Microsoft and try it from USB? More info please, was the box modded in any way? The update you need is not the latest by far. Download update 2.0.12625.0 here
1 Plug your USB flash drive into a USB port on your computer.
2 Download the update file.
3 Click Save to save the console update .zip file on your computer.
4 Unzip the file. If you are using Microsoft Windows XP, Windows Vista or Windows 7 or 8, double-click the .zip file to unzip it.
5 Copy the contents of the .zip file to the root directory of your flash drive.
6 Unplug the USB flash drive from your computer.
7 Plug the flash drive into a USB port on your Xbox 360 console.
8 Restart the console.
When the console restarts, the installation program starts automatically. Select Yes when you are prompted to update the new console software.
Hope this helps
http://download.digiex.net/Consoles/Xbox360/Dashboards/2.0.12625.0.zip
Jan 29, 2015 | Microsoft Xbox 360 Console
Code(0013)
Error code 0013 means your ram is overheating. This is either cause by a bad fan, which can be replaced for cheap, or a bad solder point, which means you will have to have someone who is an expert at soldering do a reball or rework the chip.
Apr 12, 2014 | Microsoft Xbox 360 Console
Netflix error code 0013
Reinstalled Netflix app for android then error 0013 went away
Mar 22, 2014 | Android HD Wifi Smart IPTV Box - Watch...
22FB-3151-b200-0700-c000-0013 Put in an xbox mag disk and it screwed up the xbox and gave me this status code
1. Anote second hex data 22FB-3151-b200-0700-c000-0013 and go to http://easycalculation.com/hex-converter.php
2.
Convert it to decimal and get the update number:
Hex:
3151 - Decimal: 12625 Update
3. Go to http://dl.console.se/index.php?dir=Xbox360/uppdateringar/ and seek the correct update. Download it.
if not try to locate it on google)
4. Extract $Systemupdate and put it into root of a pendrive formatted in fat32 or a CD
5. Turn off the console and plug the pendrive or insert the CD
6. Turn on the console and wait
7. Enjoy!
Apr 22, 2011 | Microsoft Xbox 360 Console
Hi, I'm getting system update stopped message with the status code 3080-3143-B200-0700-C000-0013 I cant get rid of this message......pls help me.
This can usually be solved by clearing your system cache. Follow the instructions on the link given to do so. http://support.microsoft.com/kb/971755
Mar 14, 2011 | Microsoft Xbox 360 Console
Xbox 360
Hi! This error code responds to Hardware failure and possibly the GPU failure(Graphics processing unit). This is also called as 3 rings of death. The issue is heat, and what you need to do is take your system apart, clean off the GPU and motherboard, and put a spacer (like a washer) between the heat sink and the motherboard. This will allow "breathing" and keep the motherboard cooler.
(Remember this will void your warranty if its under warranty)
Or else You can visit the link below-
http://www.jasonwong.net/2007/12/27/xbox360-0020-error-code-fixed-attempt-2/
http://thisisfordevices.blogspot.com/search/label/Microsoft%20Xbox%20360%20Console
Jan 06, 2009 | Microsoft Xbox 360 Console
System error 0013 benq DC E610 DIGITAL CAMERA
i had the same problem but now i have solved it.........its not a software problem..... the lens in fornt of the camera is not able to come out......just hit the camera 3-4 times on a table it will start working.......hope your problem is solved
Mar 01, 2008 | Nikon Coolpix 3200 Digital Camera
The problem of 3 lights and freezing games with my xbox
Error Codes XBOX360
http://www.llamma.com/xbox360/repair/Xbox-360-error-codes.htm
Jan 18, 2008 | Microsoft Xbox 360 Console
Xbox360 error code
Here is how you interpret the LEDs to get the code number:
  • All four lights flashing - 0
  • One light flashing - 1
  • Two Lights flashing - 2
  • Three lights flashing - 3
0001 power supply problem
0002 Network Interface problem
0003 Power problem could be the PSU could be the GPU/CPU, somehow the console isn't getting clean power from the power supply.
0010 over heating
0011 over heating - If you are receiving this error after disassembling your console make sure to all 8 of the heatsync screws are tightened securely to the board/heatsink holes.
0012 over heating
0013 over heating
0020 (Not yet known, possibly overheating)
0021 DVD Drive Time out - Can be caused by problems with a firmware flash. This is also speculated to sometime be caused by a problem with the southbridge chipset on the motherboard.
0022 GPU Error / GPU Overheating
0023 (not yet known)
0101 (not yet known)
0102 unknown error
Oct 12, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
3,803 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
