Question about Samsung RS2630SH Side by Side Refrigerator
Repairing assistance of my refrigerator
Reglating circuit(on-off) is not working properly-When my refrigerator starts freezing it goes on for a long time and when it stops,well it's for a long time also. When it starts freezing again, the tempareture is high and the food already began to rott
  • 237 Answers
Did you ever get any advice for this problem? Please repost if not.
Posted on Dec 23, 2006
My GE does not freeze nor does the refrigerator work all my food defrosts and goes bad. I unplugg it and plug it back then it starts freezing again. But after maybe two days it stops working again.
may have a faulty thermister device. This could be telling the freezer to go into defrost mode or it might be the timing circuit for the defrost cycle.
Worth getting it checked out by a licensed fridge repair person.
Mar 12, 2016 | GE Refrigerators
Frig side by side model glrs267zcq1 freezer cool but not frozen no ice
Hello friend, thanks for your post!
I see your Frigidaire refrigerator is not freezing in the freezer section but keeping your fresh food side cool. Some possibilities could be your refrigerator stuck in defrost mode, the control panel, or sealed system. I would recommend performing a reset on your appliance which would be flipping your household circuit breaker off for ten minutes. If that does not resolve your issue I would seek assistance from a professional to properly diagnose and repair your appliance. -Matt
Aug 17, 2014 | Frigidaire Refrigerators
Why my side-by-side refrigrator is not cooling and freezer is warm too.
Check your compressor if overheating.
Observe the running condition of the compressor.
Check if your compressor is running. If compressor is running then you have a freon leakage or insufficient freon.
If not check your thermostat if working properly. (Get a multi tester and check for continuity. at normal temperature the circuit should be closed)
If thermostart is working properly then check your OLP(over load protector) which is attached to your compressor. it should be closed circuit.
Aug 12, 2014 | GE Profile 26.6 cu. ft. Side-by-Side...
Refrigerator and freeze not cooling
Hi there! If your side by side refrigerator unit is not cooling properly there could be several causes. The damper door, between the two doors, is not functioning properly and not allowing the freezer's cool air to move into the refrigerator's side to cool everything down. You also could have a clogged sealed system line or faulty compressor. Do you hear the unit running as normal? Do you notice any side of the unit, or external area, that is severely warm/hot to touch? Make sure the unit is clear of debris underneath and around any coils or connections outside of the unit. You may want to power cycle the unit by unplugging it or turning the circuit breaker off to it for a few moments. If these steps do not prove to be successful, please contact a professional for further assistance.
Apr 01, 2013 | Frigidaire FSC23F7D Side by Side...
Model GSS25SGMCBS coil freezes.heater checkedout ok service man changed the circuit board for $312.After 3 days, same problem again. Freeze temp ok but refrigirator sectio quit working after coil freezes....
Control board is new, heaters ok, Check defrost thermostat and thermisters located on evaporator.
PC board not getting information to defrost properly.See site below
Also check the fill tube at ice maker . Iv'e seen these get loose and fill evaporator with water causing ice block
good luck
GE Refrigerator Repair Guide
Aug 16, 2011 | GE GSS25SGMBS Side by Side Refrigerator
Is there a work around for installing a new Temp Control circuit board in a GE Refrigerator Model # PSS27NGMA WW. Orig bd has 3 connectors and new bd only has 2 connectors. I am attempting to replace...
I have a feeling that the temperature control board is not the problem. The fresh food compartment has two thermistors that relay information to motherboard through your control panel. If thermistor is bad or covered by an item it will continue to cool and freeze fresh food. Your air damper between freezer and fresh food compartment may also be wide open. Click Here=> Service Manual Tech Sheet Click Here=> Tech Sheet If you need additional assistance please let me know here or HERE, Thanks, Sea Breeze
Dec 21, 2010 | Refrigerators
Refrigerator portion has quit working but freezer still works.
The problem is most likely either the defrost timer, and/or the defrost heater element(s) are faulty. The problem is that the defrost heater elements are not functioning properly and the evaporator core is actually freezing up and blocking the air flow through the evaporator core and also freezing up the thermal sensor, and when that happens there is no longer enough cold air being circulated through the refrigerator (that is actually how the unit operates and air must be able to flow through the evaporator core and then be circulated throughout the refrigerator to properly function) and as a result the refrigerator stops functioning and food can even thaw out in the freezer although the freezer seems to be iced up. (Usually at the rear wall where the evaporator core is located)
(Air flow through the evaporator core and cold air circulation and re-circulation through the refrigerator is performed by the air circulation fan and it also must be functioning)
Be sure to only use a blow dryer (with a towel on the bottom of the freezer) to thaw out the evaporator core and do not use any hard or sharp objects or the evaporator core can be damaged. The defrost timer can be located inside of the refrigerator itself, (see lower image) or it can be mounted outside usually either behind the air intake cowl or kick panel at the front base of the refrigerator, or most likely located behind the service panel on the rear of the refrigerator, and usually if the defrost timer is turning then it is most likely working, however the defrost timer can move very slowly and you can place a mark on the timer and the housing to check after about fifteen minutes to see if the position on the defrost timer has changed. The deforst timer on newer digital models can be built into the circuit board and is not a seperate timer mechanism.
Here are some images that should be similar to your situation to help assist you, and let me know if you require any further assistance.
Sep 30, 2010 | Amana Refrigerators
Ice maker not working ,refrigerator warm
Sep 28, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Ge fridge GSS25LFGww, fridge part freezing food
Hi, Change the controls back to normal settings. Make sure the freezer is getting 0 to 5 above. If the freezer is getting cold enough, try and turn the cold control to 1 and see if the refrigerator shuts off. It sounds like the cold control in not working properly and will need to be replaced. NOTE: The freezer temp has to be right temp or the fresh food side will not work proper.
I hope this helps. Please let me know if I can assist you further.
Vic
May 30, 2009 | GE GSS25JFM Side by Side Refrigerator
Frost in Freeze
Hi Frezer Frost.
It sounds like your defrost circuit in the refrigerator has gone south. This melts the ice off of the cooling coil in the freezer section every 8 - 10 hours of run time.
If you are old enough to remember the manual defrost refrigerators, that is why you had to defrost them occasionally. The ice layer on the coil acts as an insulator, preventing the coil from working properly.
Greg.
Aug 24, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Samsung RS2630SH Side by Side Refrigerator Logo
42 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
