Question about ElectroVoice Audio Players & Recorders
How will i know if the horn has blown on my ev zx 5 speaker?(there is no top end at all) thanks.
    Scholar:
  • 131 Answers
First,try switching to a different output(if this is the left speaker,switch it to the right)if it does the same thing,then we need to pull the back off the speaker.to make sure the crossover is not bad your gonna want to unplug the horn & put a signal to it from your source(do this at a low volume with the bass turned down & trble turned up)if you have sound then there is a problem with the crossover(this is the pc board in the enclosure that connects to the speakers)if not your horn is gone.hope this helps,thanx for using fix.please rate all replys
Posted on Nov 17, 2008
How much cost Electro voice EV S6o speaker system?
Sorry we do not provide pricing information here.
Jul 23, 2017 | The Audio Players & Recorders
I have 3 behringer b615d and all of them the horn speaker have spot playing. do you know what could be the problem
Generally, there are two possible problems- The horn diaphragm is blown or the power amp to the horn is broken. The diaphragm being blown is more likely. Remove the driver and run a voltmeter across the terminals. If it doesn't show continuity, replace the diaphragm. If it does show continuity, take the cabinet to the repair shop.
Oct 03, 2014 | Behringer EUROLIVE B615D 15"" Active PA...
Mackie srm450 v2 no top end.
Check the aspect of the crossover filter for the speakers, inside. Sometimes they fry.
Apr 14, 2014 | Mackie SRM-450 System
I have a Volfenhag ZX 4810 subwoofer, and it didnt come with any instructions, specification sheets, or literature of any kind. I want to build a custom box for it, but I need all the specs.I've googled...
I know this is really late. Hope it might help somebody. I just purchased a zx4810. For a sealed enclosure, 38L is recommended. Now I've got to convert litres into cubic feet.
Apr 03, 2011 | Volfenhag ZX-4810 10" High Power Car...
Hello there i have a mackie srm 450 speaker system and im not getting any high end tweeter sounds just bass only what coule be the problem manay thanks Paulie
The most common cause of this is a blown horn. A replacement can be ordered from Mackie directly. Remove the screws that hold the plastic horn in place. At the rear of this part will be the tweeter assembly that unscrews from the horn. This needs to be replaced.
Another possibility is that the tweeter driver has broken from the horn itself and is inside the cabinet. Remove the horn and you may find that the aluminum part has broken. Replace the horn which comes with that part and you should be fine.
Dan
Aug 12, 2010 | Mackie SRM-450 System
Horn won't work what would cause this
1 Defective horn button
2 horn froze up needs to be adjusted on the side screw
3 Fuse blown
4 horn relay bad
5. Steering wheel inner button or split ring worn out.
6. Steering wheel wireing harness worn out (Least Likely)
If you need help to check these let me know and thanks for using fix-ya
Jul 01, 2010 | 2001 Lincoln LS
Wiring diagram for horns in a speaker ev eliminator i dual 15's
hi can you please tell me on a ev elimenator horn which out of the wires is the live?
Nov 02, 2009 | Audio Players & Recorders
Blown horn
Remove blown horn speaker and take it to a electronic shop and asked them to check with special speaker meter to see the condition of speaker widings.
Jul 26, 2009 | Behringer Eurolive B212A Speaker
No sound from EV SH-1502 ER 15" driver
Either the 15" speaker is dead, or the passive crossover inside the unit. The simplest way to identify your problem is to remover the speaker that isn't working from the enclosure, and exchange it with the speaker that is working. If there's no sound still, it's the speaker itself that is the problem. If it works in the other cabinet, then put the "working" speaker in the cabinet you took the "bad" speaker out of, and if it doesn't work, then there's a problem with the crossover in the first cabinet. I believe you can buy a replacement crossover from EV. If it's your speaker, do a google search for "speaker re-coning" in your area - it's cheaper to re-cone the speaker than buy a new one.
Jun 18, 2009 | ElectroVoice . Speaker
Eltax speaker problems
I agree, NE Speaker is the BEST repair speaker shop in the eastern half of the USA. I have an EV 12" speaker re-built there and its better than it was before it was blown. Great job NE Speaker!!!
Leo B.
Jun 23, 2008 | Eltax Audio Players & Recorders
Top ElectroVoice Audio Players & Recorders Experts
Michial Gueffroy
Vito Vacirca Jr.
 Grubhead
Grubhead
Are you an ElectroVoice Audio Player and Recorder Expert? Answer questions, earn points and help others
