Question about Kenmore Elite 45986 Front Load Washer
Code lr appears on washer
Trying to use the "clean washer" cycle using bleach and it starts up and then stops with this lr code appearing
    Genius:
  • 1,028 Answers
Use normal cycle instead of clean just follow say instructions ..lr is code for remove clothes from tub for clean cycle problem even with no clothes they still show code ..it's a program problem that whirpool is aware of last i heard they were working on solution but instructing cust to just use normal cycle instead
Posted on Nov 18, 2008
How do I get rid of small pieces of mildew that appears after washing. Cleaned everything on washer I can see. Ran the cleaning cycle 3x, sanitizing cycle 1x
Mix vinegar and bleach put in spray bottle,wear rubber gloves,spray on the mildew,scrub it,then run a rinse cycle.
Jul 15, 2015 | Kenmore Washing Machines
I have the Kenmore front load washer HE2. How do I use the clean washer cycle.
Hello, welcome to FixYa.
In order to perform a "clean" on the HE2 is as follows...Read these instructions completely before beginning the cleaning process.
**If necessary, the cleaning cycle may be interrupted by pressing STOP. This will stop the cycle. A RINSE/SPIN cycle must then be run to thoroughly rinse the remaining bleach from the unit. Failure to do so will cause damage to the unit and clothing added to the next cycle.**
Begin procedure
1) Open the washer door and remove any clothing or items from the washer.
2) Be sure the door is closed.
3) Open the dispenser drawer and immediately add 2/3 cup (160 mL) of liquid chlorine bleach to the bleach compartment.
NOTE: Do not add any detergent to this cycle. Use of more than 2/3 cup (160 mL) of bleach will cause product damage over time.
4) Be sure dispenser drawer is closed.
5) Select the CLEAN WASHER cycle.
6) Press START.
NOTE: The basket will rotate, then the door will unlock, lock again, and then the cycle will continue. The machine will not fill, but the basket will rotate while the washer runs a short sensing cycle. This will take approximately 3 minutes.
7) The cycle will determine if clothing or other items are in the washer. a) If no items are detected in the washer, it will proceed to step 8. b) If any items are detected in the washer, all cycle lights will flash and "rL" or "F/34" will be displayed. Associated LED status lights will remain lit. The door will then unlock. Press STOP to cancel the failure code. Then repeat steps 1, 2 and 6 to start the cycle again.
8) Once the cycle has begun, allow the cycle to be completed.
9) After the cycle is complete, leave the door open, slightly, to allow for better ventilation and drying of washer interior.
Good Luck and thank you for choosing FixYa. Please take a moment to rate the info I provided and a short testimony is appreciated.
Regards,
Macmarkus :)
Aug 14, 2011 | Kenmore HE2 Plus Front Load Washer
May tag Neptune showing codes
Error codes appear when there are problems with the door, the inflow and drainage of water and the motor.
Do
Your Maytag Neptune washer displays the "do" help code when the washing machine is trying to start a cycle, but the door is open or not locked properly. If this message is displayed, close the door securely and restart the washing cycle.
FL
The "FL" code indicates that the washing machine was unable to lock the door after you closed it. Open and close the door tightly, then restart the washing cycle.
Sd
The "Sd" code indicates that you have added too much detergent to the washing machine and your laundry has too many suds. The machine will stop displaying this code if it has successfully run the suds recovery cycle, which removes the excess suds from the wash load. If the code remains, reduce the amount of detergent in the load. Use less detergent for similar loads of laundry in the future.
PF
The "PF" code indicates that a power failure has occurred. Restart the wash cycle. If the code still appears, check that the washing machine is still plugged in to the electrical outlet.
Nd
The "nd" code indicates that your Maytag Neptune is not draining as it should. Check that the drain hose isn't kinked and that the stand pipe isn't clogged. If you find either of these problems, fix them before restarting the washing cycle.
LO
The "LO" code appears when the washing machine has finished the selected wash cycle, but cannot unlock the door. Verify that the door is closed properly, push the "Off" button, and wait two minutes. The door should unlock and the error code will disappear. If the error code remains, unplug the washing machine, wait two minutes and plug it back into the electrical outlet.
Lr
The "Lr" code indicates that the washing machine's motor is not running as it should. Have your Maytag Neptune washing machine serviced by a certified Maytag repair professional. Maytag Neptune Priority One Service: (888) 462-9824
NF
The "nF" code appears when the washing machine has tried to fill with water and has failed. Verify that the inlet hoses aren't kinked and that the faucets are fully open.
Od
The "od" code appears when you must open the washer door. The Maytag Neptune washer requires that you open the door between cycles.
Other Codes
* If your Maytag Neptune washing machine displays any codes that are not listed above, contact Maytag Neptune Priority One Service for assistance. Maytag Neptune Priority One Service: (888) 462-9824
Hope this helps (remember to rate and comment this answer).
Apr 03, 2011 | Maytag Dryers
If you get the FL how do you get the door to open??
  1. Your Maytag Neptune washing machine displays error codes, also called "help codes," to identify specific problems with your washer. Once you close your Maytag Neptune's door, the machine locks the door, goes through the selected wash cycles and unlocks the door when the laundry is finished. Error codes appear when there are problems with the door, the inflow and drainage of water and the motor.
  2. Do
  3. Your Maytag Neptune washer displays the "do" help code when the washing machine is trying to start a cycle, but the door is open or not locked properly. If this message is displayed, close the door securely and restart the washing cycle.
  4. FL
  5. The "FL" code indicates that the washing machine was unable to lock the door after you closed it. Open and close the door tightly, then restart the washing cycle.
  6. Sd
  7. The "Sd" code indicates that you have added too much detergent to the washing machine and your laundry has too many suds. The machine will stop displaying this code if it has successfully run the suds recovery cycle, which removes the excess suds from the wash load. If the code remains, reduce the amount of detergent in the load. Use less detergent for similar loads of laundry in the future.
  8. PF
  9. The "PF" code indicates that a power failure has occurred. Restart the wash cycle. If the code still appears, check that the washing machine is still plugged in to the electrical outlet.
  10. Nd
  11. The "nd" code indicates that your Maytag Neptune is not draining as it should. Check that the drain hose isn't kinked and that the stand pipe isn't clogged. If you find either of these problems, fix them before restarting the washing cycle.
  12. LO
  13. The "LO" code appears when the washing machine has finished the selected wash cycle, but cannot unlock the door. Verify that the door is closed properly, push the "Off" button, and wait two minutes. The door should unlock and the error code will disappear. If the error code remains, unplug the washing machine, wait two minutes and plug it back into the electrical outlet.
  14. Lr
  15. The "Lr" code indicates that the washing machine's motor is not running as it should. Have your Maytag Neptune washing machine serviced by a certified Maytag repair professional.
Dec 06, 2010 | Maytag Neptune MAH5500B Front Load Washer
How much bleach do you add during cleaning cycle?
If the model number is correct, to run a "Clean" cycle on this model washer you need to follow these steps:
1. Make sure wash tub is empty and close the door.
2. Open the dispenser drawer and remove the plastic divider in the MAIN DETERGENT compartment.
3. Select the following options:
a. Select the POWER button.
b. Select RINSE/SPIN.
c. Select LOW SPEED SPIN.
d. Select WARM/COLD water temperature.
e. Select END OF CYCLE SIGNAL to SOFTER.
f. Press EXTRA RINSE button 4 times within 5 seconds and the
will begin.
4. The washer will run a short sensing cycle for about 3 minutes.
5. The washer will beep 4 times and a code will appear on the front panel display.
a. If "Ab" (Add Bleach) appears - skip to step 6.
b. If "Rl" (Remove Load) appears - the door will unlock and you
need to double check the wash tub for any items. Close the
door when complete and press the START button.
6. Add bleach. If this is the first time running the clean cycle add ONE CUP of bleach to the detergent compartment of the dispenser drawer. If this is a monthly routine, add only 1/3 CUP of bleach.
These instructions are listed on page 18 of your owner's manual. If you no longer have a manual, yo can obtain a FREE copy at managemylife.com. Just type in your model number under their "Manuals" link and you will find it listed in .pdf (Adobe) format that you can download or print for free.
If you have questions, please post back and let me know. I hope this helps you.
Aug 17, 2010 | Whirlpool Duet GHW9150P Front Load Washer
How do I go to clean cycle-Frigidaire affinity ATF6000fs
I was doing a search for infor on how to clean my affinity front load washer, and came across this infor and this did not work for me either, but when I turned my dial to rinse and spin then hit clean the clean option appeared.
Jan 21, 2010 | Frigidaire ATF6000ES Front Load Washer
Error code Lr
locked rotor you need a new motor control
Oct 01, 2009 | Maytag Neptune MAH5500B Front Load Washer
Lr code appears. machine stops.
replace or, replace the lid lock switch,solenoid or, bent lock lever
Jun 10, 2009 | Maytag Neptune MAH5500B Front Load Washer
Getting error code#06 Lr Locked Rotor
I too had the Lr problem on my Maytag MAH5500B. We had it fixed once when it was still under warranty but when it appeared again this summer, I was told that it would cost at least $500 to repair -- in other words, get a new one.
With nothing to lose, I simply unplugged the unit, opened the front and reset (as in pull out and re-insert) the jumpers to the control unit on the bottom right. It's been working fine since and I run it at least twice a week. I noticed that the Lr error would appear when I interrupt the wash cycle once it begins. When the error message appears, I simply unplug it, wait a few minutes and start it up again.
It is after all, a computer...and all computer could use a reset once in a while.
Feb 24, 2008 | Maytag Neptune MAH5500B Front Load Washer
He4t - monthly bleach cleaning cycle
Washer Monthly Maintenance Procedure:
This cycle uses higher water volumes in combination with liquid chlorine bleach to thoroughly clean the inside of your washing machine.
  1. remove any clothing or items from washer
  2. CLOSE door (duh)
  3. open dispenser drawer and remove the detergent compartment and set aside. No laundry products will be added at this time. You will be required to add only liquid chlorine bleach at a later step.
  4. For Kenmore Elite HE products press a specific combo of buttons.
  • Select Rinse/Spin program
  • select low spin speed
  • select warm/cold water temp.
  • select 2nd rinse option
  • push the "end of cycle" signal button 4 times within 5 seconds to start the cycle
The machine will fill and run a short sensing cycle. This will take about 3 minutes.
Step 5
  1. The washer will provide 4 short tones. Check the: ESTIMATED TIME REMAINING display for the codes indicated below:
  • if "Ab" (add bleach) displayed in the estimated time remaining window (you'll hear 4 short tones) proceed to Step 6.
  • if "rL" (remove load) displayed in the Estimated Time Remaining window an error tone will sound. The door will unlock.
    -open the door and remove the items from the washer.
    -continue the cycle by pressing the START button.
    NOTE: The water in the unit will dispense for a moment, then the door will unlock, lock again, and then the cycle will continue with another check for items in the washer.
    The machine will fill and run a short cycle to determine whether any items have been left in the washer. This will take approx 3 minutes.
    the washer will repeat Step 5 until it can determine that there are NO items n the washer and will display "Ab" (add bleach).
6. Add liquid chlorine bleach.
  • If using the maintenance procedure for the first time, open the dispenser drawer and immediately add 1 cup liquid chlorine bleach to the Main Wash detergent compartment. The liquid bleach should immediately flow out of the dispenser.
  • If doing a monthly maintenance procedure, open the dispenser drawer and immediately add 1/3 cup bleach to the Main Wash detergent compartment. The liquid chlorine bleach should immediately flow out of the dispenser.
    NOTES:
  • Water will be flowing into the dispenser drawer when the bleach is added ... this is normal.
  • Do not add any detergent to this cleaning cycle. Use of more than 1 cup of bleachw ill cause product damage over time.
7. Once the cleaning cycle has begun, allow the cycle to complete. An est cycle time will appear on the display.
8. After the cleaning cycle is complete, leave the door open, clightly to allow for better ventilation and drying of washer interior.
9. Replace the detergent compartment divider.
Feb 04, 2008 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
226 people viewed this question
Sal De
fordexpert
 Brian Main
Brian Main
