Question about LaCie (300787)
Drive not mounting
My lacie drive is switching on but then doesn't want to mount and there is a continuous clicking/whirring noise as it tries to mount. I then get a message asking me if I want to initialize the drive. Is the drive dead now? Have I essentially lost all the work that is on it or does it sound like something that can be fixed just so I can get all my work off of it? Any help or advice would be greatly appreciated. Coco
  • 84 Answers
It sounds like the drive is toast. There may be some information that is salvageable, but you will need to purchase SpinRite to see if it can restore any of the data on the drive.
Posted on Jun 19, 2007
Mac doesn't read the drive. Time Machine reads 'delayed' then 'failed' because it can't read drive. Won't backup. Drive doesn't show up on screen.
- Open the disk utility application found in the applications folder, then open the utilities folder
- See if it detects the LaCie drive by looking on the right hand side where it lists all the available drives including your optical drive
- If it is just greyed out you might only need to re-format the drive or possibly repair the disk.
- If it does not appear in this list the drive has most likely failed and is not economically repairable
May 17, 2011 | LaCie Rugged All-Terrain (301017) Hard...
Drive making a clicking noise and not mounting
Not good... Sounds like a hardware failure in the drive. That clicking sound is the solenoid inside the drive. Hope its under warranty.
Apr 27, 2010 | LaCie Design by F. A. Porsche 160 GB Hard...
Lacie Hard Drive won't turn on properly
A clicking noise is a sign of hard drive failure.
If its a metal clicking noise, could be a physical damage.......hard to get data back from it.......and very very expensive.......sorry
Don't forget to rate this answer if it helps
Dec 24, 2009 | LaCie (301074) 80 GB Hard Drive
Lacie external hd designed by f.a. porsch won't mount
I am sad to say that it's probable that this drive has failed. But if there is critical information on it, please unplug and discontinue use immediately.
You do stand a chance of recovering data if the drive has failed, but you lessen those chances as you continue to try to use it.
Definitely take this drive to a qualified repair outlet who can help with data recover if you need the information off of the drive.
Mar 20, 2009 | LaCie Design by F. A. Porsche 160 GB Hard...
Cannot find the lacie driver on my mac
Chances are the drive is bad. Try taking it to another computer- if it doesn't work there, then the prognosis is poor. Data recovery services are available, but pricey.
Feb 05, 2009 | LaCie d2 Extreme (301033) (301033A) 160 GB...
La cie hard drive mount issues
I had the same problem and surprisingly, after many attempts to get the drive to mount with different connections, etc., the problem turned out to be the power adapter. If you've got the same kind of adapter on another drive, switch it out and see if your drive shows up. Good luck.
Nov 09, 2008 | LaCie Big Disk Extreme with Triple...
Trouble seeing my lacie drive possible mounting issue
Not sure if this is the exact same issue, but I couldn't get the drive to mount with different connections, etc. The problem turned out to be the power adapter. If you've got the same kind of adapter on another drive, switch it out and see if your drive shows up. Good luck.
Aug 13, 2008 | LaCie Big Disk Extreme with Triple...
Drive won't mount and makes slow clicking sound
A power supply failure can cause this; I've just been through it myself. If you have access to another LaCie drive, try its power supply on the "failed" one and see if it works.
Mar 10, 2008 | LaCie External USB 2.0 500GB 7200 RPM 500...
Lacie drive won't mount
I solved the problem. It was a power supply problem. It seems after searching boards on the net, this is a common problem with the lacie hard drives. Just replace the power if your hard drive is clicking and not mounting. I think many people must be throwing the drives away thinking they are lost when it is just the power supply. Try this first before trashing it or spending a lot of money on data recovery programs/
Nov 13, 2007 | LaCie 250GB Ext/Firewire 7200 250 GB Hard...
LaCie (300787) Logo
130 people viewed this question
Top LaCie Computers & Internet Experts
pankaj rautela
pankaj rautela
Marvin
Marvin
Alun Cox
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
