Question about Nikon Coolpix 5700 Digital Camera
Nikon E5700 ''Lens Error''
Put in a new battery and compact flash card and still get Lens Error. Where can i send it to be repaired or is it worth it?
    Novelist:
  • 100 Answers
This is a fairly common problem with Nikon E5700 cameras. Sometimes, the problem is nothing more than the lens tried to extend, but bound on something and errored out. Removing the battery for a few minutes usually clears the problem. If it doesn't, you might GENTLY push on the lens -- like pushing it back into the camera body -- with the power OFF.
If that doesn't clear it up, you'll have to decide whether or not repair is worth it. I've seen the E5700 selling for around $300 on several websites. I paid $1200 for mine when it first hit the market. So, depreciation has set in. Nikon does a good job in repair and turn-around -- and they are not outrageously expensive. I had my E5700 serviced and back in 7 calendar days a couple years ago. They cleaned EVERYTHING -- and it's worked like a charm since then. Best wishes with the fix!
I hope this helps!
Regards,
CharlieJ
[Please rate this solution, if it helps you.]
Posted on Nov 17, 2008
  • singh_b34 Jul 10, 2010
    as you suggested it does not help.can you suggest something else.if i go to go to nikon service centre,how much it may cost me to get it bserviced.any idea.pl.ease tell me.
Lens error
The following blog outlines some repair options for a lens error. They won't work for all cases, but they're worth a try if the camera's no longer under warranty:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
May 27, 2010 | Nikon Coolpix S210 Digital Camera
Nikon coolpix s630, lens error, blurry, ticking sound
Apr 22, 2010 | Nikon COOLPIX S630 Digital Camera
Lens error message
It will cost more to fix it than to buy a new one. The parts are cheap but the labor is very high. You might send it to Nikon and see if they will send you a repair service unit for a low price. Always worth a try.
Dec 08, 2009 | Nikon Coolpix S210 Digital Camera
Can you replace prongs is camera so memory card will read
Wouldn't recommend that you try to replace the reader yourself, as you may likely cause more damage to the camera. If you wish the reader replaced, recommend professional repair (call 1-800-OK-CANON for genuine Canon service).
However, if it's merely a bent pin problem, there is a good chance that you may be able to unbend it/them. Please see the following, as it's worth a try before sending off for service:
http://camerarepair.blogspot.com/2009/06/fixing-compact-flash-memory-card-error.html
Jul 11, 2009 | Canon Digital Rebel / EOS-300D Digital...
I have a Nikon Coolpix 3100 and when I turn it on the flash indicator light and the light next to AF flash. Nothing else happens. I've put in new batteries and it still isn't working.
This indicates a lens fault. Either something is preventing the lens from coming out or the mechanism has already been damaged.
Unfortunately the damage isn't worth repairing as a perfectly good, boxed and virtually unused Coolpix 3100 can be bought on auction sites for under £25. The parts you'd need to repair your camera would cost more than that (in the unlikely event that you could get them) and would need professional fitting.
Dec 29, 2008 | Nikon COOLPIX Cameras
Nikon D70
Greetings,
It is actually an error message generated by your compact flash and means that the card is no longer readable. A lot of D70 owners have reported this error without being able to find another solution other than reinserting the card or changing the card to a different brand. In my D70s I use Sandisk Extreme III memory and, knock on wood, have not yet had this error. You could also try cleaning out the memory card slot and check to see that all pins are aligned and not bent.
Good Luck,
-WN
May 12, 2008 | Nikon D70s Digital Camera
Nikon coolpix 4600.
Hi I found this info on the Nikon Australia website:
"System Error" or "Lens Error" message in LCD monitor trnsp.gif Question My COOLPIX camera displays a "System Error" or "Lens Error" message. What should I do? trnsp.gif Answer Having a "System Error" or "Lens Error" message displayed on the camera's LCD monitor would generally indicate that your camera needs servicing. A System Error is a general error which can be caused by many things: lens problem, CF Card problem, general camera failure, etc. To troubleshoot, please try the following:
  1. Use the memory card that originally came with your camera (or a Nikon approved card).
  2. Remove and replace the battery.
On the other hand, a Lens Error generally means that an error has occured during the lens operation. To troubleshoot, please try the following:
  1. Turn off the camera.
  3. Turn on the camera.
If the above tips do not help, your camera must be sent to our Nikon Authorised Service Centres, there are no user serviceable parts in our Nikon COOLPIX cameras. We apologize for any inconvenience caused and we will do everything to repair your Nikon camera as quickly as possible. Click Here for our Nikon Authorised Service Centres details.
Seems you may just have to remove and replace the battery - sort of like a Windows Restart to fix a computer problem! - this would reset your camera's memory.
Hope this helps.
Apr 29, 2008 | Nikon Coolpix 4600 Digital Camera
Two cameras and two lens erros
I don't think either camera is worth the over $100.00 that it will cost to fix. However, look at my posts on this problem of lens errors. By forcing gently the lens in or out when you start the camera and shut it off, it may get the lens to work again.
This may damage the camera even further, up to you, and may be worth a try.
Apr 11, 2008 | Nikon COOLPIX L3 Digital Camera
Lens error/system error
I have successfully fixed the same error on a Nikon 2100 by dissasembling the camera and removing grit from the gears that drive the lens. However, if the camera has been dropped, I suspect that something has got dented or bent. It may be worth taking the camera apart to see if a gear has got dislodged.
I would warn you to be very careful not to get a shock off the flash capacitor inside the camera though. Also, it took me quite a while to put it all back together. It's not the easiest device to work on, a result of the very compact body (for its time!)
May 29, 2007 | Nikon COOLPIX Cameras
"System Error" message in LCD
Having a "System Error" message display on the camera's LCD display generally indicates a problem where the camera will need to come to Nikon for repair. A System Error is a general error which can be caused by many things: lens problem, CF Card problem, general camera failure, etc. Before sending the camera in, check these: Use the memory card that originally came with the camera (or a Nikon approved card) Remove and replace the battery If the error is still displayed, contact Nikon's Service Department (below). If the above tips do not help the camera must be sent to Nikon Service, there are no user serviceable parts on Nikon Coolpix cameras. We apologize for the inconvenience and will do everything we can to repair your Nikon camera as quickly as possible.
Aug 30, 2005 | Nikon Coolpix 3200 Digital Camera
Nikon Coolpix 5700 Digital Camera Logo
293 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
