Question about HP Office Equipment & Supplies
I HAVE AN HP PSC 1510xi ALL-IN-ONE, PRINTER, SCANNER, COPIER WITH EMPTY INK CARTRIDGES. BUT AFTER REPLACING THE CARTRIDGES, I'M GETTING BLINKING LIGHTS TELLING ME THAT THE COLOR CARTRIDGE IS NEEDING REPLACE IT BECAUSE IT'S EMPTY...AND THEREFORE I CAN'T PRINT ANYTHING. I GOT BLACK # 92 AND COLOR # 95. aRE THOSE THE CORRECT #'S FOR MY PRINTER? I CAN'T FIND MY OWNER'S MANUAL. THANKS! BECKY PONDA
disastertech
  • 62 Answers
SOURCE: Paper really jammed into my printer
Please take it to the nearest service centre, if the paper is so tight, it needs to be open up to release the paper
Posted on May 11, 2008
SOURCE: HP psc 1350 HP 57 print cartridge
Same problem with me.
So:
I openede the whole box ( 4 screws ) in the corners. Then I presed the tiny belt on the left side to its socket, cleaned the contacts of the cartridges (56,57) with water and made them dry.
Then I reched the position of the small door which is ment to be opened once you wnat to replace the cartridge.
After this the printer works again.
Posted on Jun 25, 2008
hemantraj
  • 638 Answers
SOURCE: I just changed the ink
clean the brown dotted circuit of both the printer and your cartridge.it will work.or may be the cartridge is faulty,get it checked in some other printer of same model number.
Posted on Aug 16, 2008
SOURCE: Changing cartridges
I just turned on my hp psc 750 and an error message appeared. Incorrect black cartridge installed
I just used it yesterday, what is wrong???
Posted on Aug 24, 2008
SOURCE: downloading hp psc 1510xi
asdfghjklñ
Posted on Sep 24, 2008
I want to use only my scanner without cartridges, what should i do ?
You can use it but Cartridges should be in the printer ( atleast low on ink message )
If you want to scan ( with empty ink cartridges ), the printer should be aligned first
Jun 16, 2010 | HP PSC 750 All-In-One InkJet Printer
Blinking check print cartridge light and "E" for copies
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink or toner cartridge?
Please consider the following:
If you are using a refilled or third party cartridges that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks or toner causing problems with print quality or damaging the physical printhead or photo conductors.
If you are using factory new ink or toner cartridges, then please call the manufacturer’s Technical Support for assistance with the warranty on the cartridges
Don
Feb 19, 2010 | HP PSC 1410v All-in-One Printer
HP PSC1510xi (all in one) Like to use the printer only as a scanner. Ink has gotten way too expensive. I cannot go to scanning mode because the HP is focusing on aligning print heads! Any ideas to be able...
I'm not sure, but if the device shows up as both a printer AND a scanner (two separate devices), maybe you can just go into device manage or Printer & Faxes and disable or uninstall the printer portion.
Oct 24, 2009 | HP PSC 1510 All-In-One InkJet Printer
Ink light of my tx101 keeps blinking
Hello, Amit.
From FixYa, give this a try:
Lift up the scanner bed (top part) of the printer to expose the cartridges.
Push the red triangle button once. Wait for the cartridge carrier to move to the middle. On the housing of the printer (the non-moving part), there is an arrow that will point to the empty cartridge.
Push the red triangle button again to see if the next cartridge is empty. Repeat this step, noting which cartridges are empty, until the cartridge carrier moves to the right. Now you can replace each cartridge that is empty.
After replacing the empty cartridges, push the red triangle button again, and the carrier will begin moving back and forth (cleaning itself). Once it stops, it should be positioned on the far right side.
Lower the scanner bed to "close" the printer. The ink light should go off and you should be able to print.
Hope this helps.
Oct 04, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Printing problems
The light will stay on if the cartridge is not inserted correctly, check if it is in correct if you still have the problem remove both cartridges and insert the both of them back the same time.
Nov 02, 2008 | HP PSC 1210 All-In-One InkJet Printer
May 05, 2008 | HP PSC 1510 All-In-One InkJet Printer
mukhtar21 shaikh
mukhtar21 shaikh
