Question about Whirlpool GS563LXSS - stainless Steel Gas Kitchen Range
Warranty has expired on whirlpool GS56LXSS range.
Oven is not working on above noted gas range. Seems like there is not gas getting through. Electric part seems to work. Top of stove burners are working. Can we light the pilot?
  • 1462 Answers
SOURCE: Electric Oven doesn't cook evenly
back plate inside oven may be distorted or some of the vents blocked with crud
Posted on Apr 03, 2007
SOURCE: whirlpool oven doesn't work model gs563lxss
We had those same symptoms with our range out of the box. It was a problem with the PC board and it was fixed under warranty.
Posted on May 28, 2008
huuum
  • 750 Answers
SOURCE: whirlpool electric range burner power light stays on but no heat
Hello givemeanidth.
Welcome to Fixya
You said, have a Whirlpool electric range (model rf363pxpt0) with standalone burners - the burner power indicator light stays lit whether the heat control knob is on or off, there is no heat coming from the burner on or off. You pulled the burner from the receptacle and one of the tabs broke off and stayed in the receptacle. You removed the tab and made sure no pieces remained in the receptacle then bought a replacement burner, no change. You put the replacement burner in the back burner of the same size and had heat within 10 seconds. You changed out the burner with the one that had been in the back of the range, no heat. As long as the breaker to the range is on the power light stays lit but no power to that one burner only.
What is the model number and the age of your range?
Waiting for your reply.
Huuum
Posted on Oct 03, 2008
  • 7 Answers
SOURCE: Whirlpool 465 Gas Stove conversion from propane to gas?
Do not use the stove until its properly converted back to natural gas. It's a serious carbon monoxide hazard.
Most ppl throw the orifices away, sometimes they are stored under the stovetop in the back, or behind it. The original natural gas orifices are the only parts you need. All orifices are labeled by a tiny stamp on the side. It will state the size and type, example: 10 LP.....meaning number 10 size and propane.
A nature gas should be labeled something like 12 NG.
Call a local parts dealer or order online the NG orifices for you model number.
I assume you do not have the setup instrctions that come new with the unit. Heres what you need to do:
1) Change the orifies to NG (the bigger the burner the higher the size number) so if you have two #10 size, one #12 and one #14...then common sence will tell you where they go.
2) convert the regulator. This is the part to which the inlet connects. Remove the vent cap,(a plastic cap, you'll see it) unscrew and flip the insert over and reinsert it (You'll usually see 'NAT' on one side and 'LP' on the other). Reinstall the cap, and that's done. The word NAT should be facing you where you can read it.
3) Then, find the brass orifice that supplies the bake burner (usually under the range, behind the drawer), and if included, the broil burner (usually inside the oven). These are adjustable, and, like adjustable top burners, are simply 'snugged' down clockwise with a 1/2 inch wrench. You need to screw these back up for natural Gas.
You know when the oven is correct, you should get a nice blue flame on top as well as in the oven. Flames with yellow tips are wrong!
Posted on Oct 28, 2008
SOURCE: Whirlpool Super Capacity 465
I have the same problem intermittently on my Super Cap 465. After reading the following quote from another site, "There have been cases where radio waves, electronic signals and sometimes something as strange as dimmers in lights have caused some weird problems with some computer panels in stoves like these", I tries turning off lights that might be on the same circuit and wouldn't you know it, the oven igniter circuit worked.
Posted on Jan 04, 2009
Top burners OK. On convect bake the oven will heat up to set temperature then shut off and cool down. Normal bake function seems to work ok.
PDF]BUILT-IN ELECTRIC CONVECTION OVEN - Whirlpool
https://www.whirlpool.com/.../Use%20and%...
Whirlpool Home AppliancesBUILT-IN ELECTRIC CONVECTION OVEN. Use & Care Guide ..... To Turn TonesOff/On: Touch and hold COOK TIME until a tone sounds and the lower oven ...
Teach me how to use my convection oven - Chowhound
Jan 01, 2016 | Maytag MES5875BAS Slide-In Electric Range...
My whirlpool oven will not heat up or bake or
Should still be under warranty! Call the dealer. Make sure you have the model # and serial # from the tag on the oven first. It is the ONLY way they can check warranty status. If not covered, it is probably the selector switch
Mar 31, 2010 | Whirlpool GS445LELS Gas Kitchen Range
Whirlpool SF36 Gas Oven - F3 F2 ERROR above 350 degrees
Unplug the range.
The oven temperature sensor has failed and must be replaced.
Remove the racks. Remove the temperature sensor located up high on the back wall of the oven.
It is a short thin round piece of metal.
Feb 13, 2010 | Whirlpool SF369 Gas Kitchen Range
oven senor not working right . it may have carbon that need removing or it may just need changing due to breakage
Feb 13, 2010 | Whirlpool SF367 Gas Kitchen Range
WHIRLPOOL Sup Cap 465 oven turns on for 3 sec, then shuts off
The flame sensor is dirty or bad.
When the unit does not sense flame after ignition, the gas valve shuts down the system.
They can become corroded or dirty, but usually just need to be replaced.
Contact whirlpool for warranty info. If the unit is under warranty, they should send you the parts for free. If not, they can direct you in how to order the part.
http://www.whirlpool.com/custserv/email_form.jsp
Sep 26, 2009 | Amana AGDS902 Gas Kitchen Range
Oven does not heat, except for broiler
wat ur oven electric or gas, if electric the 1 posible coz is damage the thermostat
or the heating element,if ur oven is upper & lower heating element,check if the two element is not heating the coz is thermostat, if gas many coz of problem, 1 pilot ligth,2 gas valve, hard to replace the parts if gas oven also dangerous to replace if u are not the technician or have some idea to replace it,much better to call the person that have an expireince to repair.one again do not try to replace if gas oven.
tnx gerbee
Jun 23, 2009 | Frigidaire FEF336BC Electric Kitchen Range
Whirlpool Gold electric range control panel not working
I live in a new 500 home subdivision. The contractor ordered all Whirlpool Gold products including Electric and Electric/Gas Ranges. Many of my neighbors' panels have gone out! I'm talking about epedemic trouble. My son has had his oven panel (separate from stovetop) fail within the first year. Thank God it was under warranty...this is not a cheap replacement (he had the sensor touch pad. I just had my oven pad fail. I tried to set the clock for Daylight Savings and found out half my panel is out! The fix is a replacement of the panel. Depending on which model (push or sensor) look to spend at least a couple of hundred bucks. We have the Whirlpool Gold microwave panel and so far so good. My neighbor and my son's both went out! They just tossed the two year old products and replaced them with another brand. Sorry to break you the news...class action anyone?
Mar 04, 2009 | Whirlpool GY396 Electric Kitchen Range
Frigidaire Electric Range model FEF366EC - Oven disabled
You probably have a short that is causing the stove not to heat up or you not to be able to control temperature settings. The stoves are made only to last as long as the warranty, and when it expires, the stove all of a sudden wants to break down. You might have to get a whole new stove.
Jul 14, 2008 | Frigidaire FEF366EC 30" Freestanding...
Whirlpool GS563LXSS - stainless Steel Gas Kitchen Range Logo
60 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
