SATA drives not recognized by BIOS
I've installed two new SATA drives. I double checked the connections. My BIOS just doesn't see the drives. The m/b is an ASROCK K7VT6
What am I missing?
  • 1 more comment
  • Debra V
    Debra V Nov 17, 2008
    you want me to reset my CMOS jumper? How will that make the BIOS see the SATA drives? Try again.
  • Debra V
    you can't log on to the BIOS as admin or anyone else. The boot up aka POST doesn't see the drives.
  • Debra V
    Debra V Nov 18, 2008
    after much googling, I figured out the problem on my own.
    When installing a SATA2 (3.0gb/s) drive into an 'older' system that only knows SATA (1.5gb/s), you may need to set a jumper to 'slow' down the data rate/communication.
    I installed two Western Digital SATA2 drives with a jumper on each on pins 5 and 6. BIOS saw them immediately. That was all I did. Little jumpers. No fussing with resetting anything.
  • 101 Answers
You mean the CMOS jumper? Reread my problem. Try again.
Posted on Nov 17, 2008
    Genius:
  • 1,124 Answers
Reset the BIOS, remove the jumper on the board.
  • 1 more comment
  • Pablo Csaky
    Pablo Csaky Nov 17, 2008
    1) If your BIOS is not seeing your drives, Make sure the S-ATA ports are activated on your BIOS,
    You have to log into your computer as administrator to see enable this feature.
    2) If after that you can not see the drives, you have to reset your BIOS but removing the CMOS battery not always reset the bios, cause this action is not possible due a lock jumper. That jumper avoid that the previous setting has been overwritten.
  • Pablo Csaky
    Yes, you can. Some Boot Cd log you directly as User into the Bios, and after that you can not modify any settings on your BIOS.
    In your case see this manual, pages 13, 20, 21, 22, 23 y 24.
    http://www.asrock.com/manual/K7VT6.pdf
  • Pablo Csaky
    Pablo Csaky Nov 18, 2008
    Ok, good for you. With the manual everything is possible my friend.
My dard disc wont detict
When installing a new hard drive, a PC may not recognize the hard drive. Incorrect cable installations, jumper settings and BIOS settings may cause the computer to be unable to detect your hard drive. Due to the vast differences in hard drive types (IDE versus SATA) and brands, motherboard brands and types, and BIOS types and configurations, please download or acquire your motherboard and hard drive manufacturers' documentation prior to acquiring a hard drive. Make sure that the type of hard drive you plan to purchase is compatible with the motherboard.
Shut down the computer. Unplug all cables and peripheral devices. Clip the anti-static wrist bracelet to a metal object, and attach the bracelet to your wrist. Remove the computer's side panel. (Cases vary. Some will require a small Phillips screwdriver for removal and others feature screwless designs. Please see your case manual if you are unsure.) Locate the newly installed hard drive. Check that two cables are running from the hard drive to the motherboard and to the power supply. If you see only one cable or if either of the cables are not securely seated, plug in the appropriate connector(s). Leave the case's side panel off for now. Reconnect the power cable, monitor cable, and keyboard and mouse connections. Restart the computer. Enter your BIOS immediately. (Your BIOS usually alerts you to the key required to adjust settings. If your screen does not show this information or if you are unsure, consult your motherboard manual.) If it is an IDE hard drive, enter the IDE settings. The BIOS should show the hard drive. Configure it as primary or secondary, according to your computer's configuration. (If you have only one drive, set this to primary. Otherwise, set as secondary.) Save your settings, and exit the BIOS. Once you are certain that the the PC is recognizing the hard drive, replace the side panel. Detect a SATA Hard Disk If you have connected a SATA (serial ATA) hard drive to your computer but are not able to access the files on it, then your system may not be detecting the drive correctly. On either a PC or Mac computer, you can manually detect and mount a hard drive that is locally connected. Once properly detected, the drive will become available for file transfer.
Plug the SATA hard drive firmly into your PC computer and ensure that the drive is powered on. Open the Start menu and click on the "Control Panel" icon. Open the "Administrative Tools" folder and double-click on the "Computer Management" icon. Go to the "Disk Management" tool on the left side of the control panel window. This brings up a list of all drives currently connected to your computer. Right-click on the SATA drive that you want your computer to detect and choose "Change Drive Letter and Paths." Click on the "Add" button and then select the drive letter that you want to be assigned to the SATA hard drive. Click "OK" to save the settings and detect the SATA drive. b> Mac Instructions b> Plug the SATA hard drive firmly into your Mac computer and ensure that the drive is powered on. Open a new Finder window and navigate to the "Utilities" folder, which is located in the "Applications" section of the Mac hard drive. Double-click on the "Disk Utility" icon. Highlight the SATA hard drive that you want your computer to detect from the list of connected drives on the left side of the window. Click on the "Mount" button at the top of the window to have the system manually detect the SATA drive. Hope this helps.
Dec 29, 2012 | Seagate Barracuda 80GB SATA 2MB HDD 80 GB...
My pc is not detect MJA2160BH
You are talking about a 160gb Fuji SATA Drive. (5400rpm 2.5")
There's a couple of things here...
Assuming you've removed the old drive, and simply plugged this one in..
SATA drives are "standard"-- kind of like USB. They WORK, or they don't. If your drive isn't recognized by BIOS, then its either connected wrong (VERY HARD, connections have directional connnections) or it's simply bad.
If your machine does NOT see the device in BIOS (if it does..insert your OS CD and install the OS)... then it's simply bad.
Return it..get another..and if I may add $.02... 160bg SATA vs price of say... 750gb sata...is next to nothing..go bigger.
Oct 16, 2012 | Fujitsu - MJA2160BH 160 GB SATA Hard Drive
I have a Compaq Presario Desktop Computer SR1150NX. I've added a new WD SATA 1 Terabite HD. but the system does not recognize it. I updated the Bio's but see no way to activate the SATA ports. The...
The problem is that XPinstallation CD does not have a SATA driver, unless you have a SATA drive on adisk etc. and can install the driver when XP asks for a hard drive driver then,XP cannot detect the hard disk and therefore won't install XP. The FIX. Go into the BIOS anddisable the SATA drive (enable IDE emulation), this will make XP think it is aIDE/PATA hard disk. Then you can install XP normally. When Windows hasbeen installed then install all the device drivers (including the SATA driver),then shut down and boot up and got into the BIOS and enable the SATA drive.
Aug 11, 2011 | Computers & Internet
I installed the HD to double the storage capacity of my Dell Dimension 4700 computer. My computer does'nt recognize the new addition or format the new HD. I connected the new HD data cable but did not...
No power cable = no power to the board of the HD = no way to communicate with the motherboard = the motherboard doesn't know the hd is in there.
Plug the power cable.
Jul 16, 2011 | Hitachi 1TB HDS721010CLA332 SATA2 U300...
Sir, i have an msi n1996 (vt8237r & km400 8237) mother board. My sata 160 gb hdd is not getting recognized in bios. Pl. help. (it is reported somewhare on the net that i have to enter into the...
I enabled SATA support on my BioStar M7VIZ-SATA MOBO (it is km400 and 8237r, like yours) by first installing the VIA SATA RAID drivers. At this point, Windows recognized the device controller but not the 120GB drive. The problem was that the system doesn't support "newer" SATA drives, so I installed a jumper on the disk drive to set it to "150" mode... SATA version 1 compatibility. After that, Windows immediately recognized the drive and mounted the filesystem.
I think it was a Western Digital drive. Other manufacturers have a different name for the same jumper. Also, I read that one type (Samsung?) can only be set to the old SATA standard by getting the drive running in a SATA 2 environment, then using a utility program to adjust the drive's microcode setting.
Good Luck to you.
May 28, 2011 | MSI : MS-7061-020 VIAKM400/A&V&L/SATA...
Xp installation problem
“No Hard Disk” error displayed on XP install (SATA drive versus ATA/IDE drive) The two most most popular types of hard drives in personal computers are ATA (also known as IDE hard drive) and SATA hard drives. Many newer computers have SATA hard drives installed, but your computer may have either an (older design) ATA/IDE hard drive or a (newer design) SATA hard drive installed.
After removing Vista, when you reboot your computer, a “No Hard Disk” error may be displayed if your computer has a SATA drive installed. To fix the “No Hard Disk” error, you may need configure your computer’s BIOS settings so that it can recognize the SATA drive installed in you computer. Reconfiguring your BIOS is typically not required if your computer has an ATA/IDE hard drives installed.
Step 1: Activate your computer’s BIOS menu. The first or second screen your computer displays on status may display which key (or keys) you must press to activate your computer’s BIOS menu. You can also look in the index of your computer’s manual for “BIOS” or you can try passing the [Del] or [F1] key when text is first displayed after powering on your computer.
Step 2: BIOS menus vary by computer, but there are seldom more than a few menu categories. Review the “Main” and “Advanced” menu categories to locate your hard drive setting. When you locate the hard drive setting, be sure to note the original drive setting in the bios so that you can restore the original drive setting if your new configuration doesn’t work.
Step 3: Change the drive setting to “IDE,” then save the BIOS settings (usually by pressing the [F10] function key then restart your computer.
If changing your BIOS hard drive setting to IDE doesn’t work, return to step one and restore the original hard drive setting
If it is ok , Please vote for me...!!!!
May 31, 2010 | Computers & Internet
Gigabyte 945 gzm s2 doesn`t recognize HDD Western Digital 320 GB
You might need to change your bios settings from ide to sata. Have you already checked the bios settings? If everything is in order you might have a bad board. What have you tried so far?
Nov 20, 2009 | Gigabyte GA-945GZM-S2 Motherboard
Doesn't recognize new SATA disk. Have checked that disk is goodand can be accessed with a USB controller. Also, the SATA card BIOS does come up but shows no device on either channel.
Check all your bios settings, make sure SATA is enabled. Also see if the drive can be installed on another machine.
Make sure your OS version can support SATA also.
Good Luck.
Sep 16, 2009 | SIIG SATA II-150 PCI (SCSA0012S1) Serial...
Computers & Internet Logo
257 people viewed this question
David Payne
David Payne
