Question about Reddy Heater-170,000 BTU Kerosene Deluxe
Wont fire turns off & on like its out of fuel, almost new
  • Anonymous Dec 07, 2008
    it will run for a few minutes then shut off . the FLAME indicater Light will then come on and I will be able to shut it off and it will restart
    Problem Solver:
  • 6 Answers
No solution. The electronic control monitors the flame in the heater using a photocell. The ligth intensity and frequency are monitored to insure that the heater getting a good burn and therefore not emitting a high level of toxic gasses.
Causes:
dirty photocell
bad fuel causing bad flame
Posted on Jan 07, 2009
1995 ford contour 2.0 L turns over but wont start put in new fuel pump and filter and still wants to start but wont what should i check now ?
If the vehicle is equipped with a timing belt, make sure it hasn't jumped throwing the valve timing off.
May 02, 2015 | 1995 Ford Contour
98 harley fatboy turns over but wont start
some after market ignitions don't spark on the first couple of turns but first take off your air cleaner twist the throttle and look to see if gas is spraying in the carb if not give it a little starting fluid if it fires but then dies then its carb issue. now other thing to check is if you have three posts on your coil then its single fire and your plug wires might be going to the wrong spot switch um around.
May 09, 2014 | Harley Davidson FLSTF Fat boy Motorcycles
1.8l 4 cylinder wont fire after replacing head cylinder?
rechk plugs firing order. chk soliniod and coil r ok, rechk fuel is getting into engine- choking usually determines that, u can smell the over choked engine. I f engine turning & choked hold throtel to floor while cranking and leave there until it fires. if no firing happends it must be electrical. rechk electrical connections. Cheers
Aug 29, 2012 | Cars & Trucks
It runs but after shutting it down it wont start for a few days
I have the same problem right now , if it wont start have someone turn it over and beat on the fuel tank with a rubber mallet if it fires up you gotta replace the pump, if it doesnt fire up check the fuel pressure, the test port is behind the motor. a fuel pump can be over $200 but I know where you can get 1 new for $60
Dec 02, 2011 | 1997 Cadillac Catera
Onece in a while turn over wont fire. runs great other wise
your injector or fuel pump may be going out, next time when you check the issue, check your distubutor again and making sure you getting sparks, if you do have sparks than it has to be your fuel problems.
Jun 25, 2009 | 1991 Honda Civic
1999 fire bird wont start
Sounds like a fuel problem, when was the last time the fuel filter was chg.? If that is not an issue, than a fuel pressure test is in order, It should have around 48 to 50 p.s.i.
Jun 16, 2009 | 1999 Pontiac Firebird
1985 chevy truck fires couple times but wont start
1985 1/2 ton delux. Wont start. New battery, wires, plugs. Alternator is good, tank is full, fuel and oil are good. Carborator is good. What could it be?
Jun 10, 2009 | 1985 Chevrolet Chevy
Wont start
ok you said it has fire from the coil but no spark? pull a plug if it wet put in all new and use one to ck fire at plug wire end
Sep 23, 2008 | 1994 Volvo 850
Reddy Heater-170,000 BTU Kerosene Deluxe Logo
129 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
